Question about Lincoln Welding Tools
Wire feed not working wire feeds through the gun freely motor does not advance the wire
  • 850 Answers
Does it have a feed adjuster ? its like a clamp over the wheel that applie pressure to the wire in order to push it through the line!
always deburr the line when feeding it into the tube!!
cheers rob
Posted on Aug 15, 2009
Miller 130 wire advances, fan runs, but will not arc as wire comes out
Most of these machines (would have to have serial number to be sure) will not feed if their is no output voltage, since part of the motor voltage comes from the arc voltage.
So, I would suspect broken wires, either in the work lead or the gun. If it arcs just a little, probably the gun. One place the work lead breaks is right at the back of the clamp. Pull on the insulation and see if it "stretches". If so, the wire there is broken.
Feb 21, 2015 | Miller Welding Tools
Miller S-64 wire feeder won't feed wire
Just a thought, have you tried feeding the wire manually to see if there aren't any obstruction through to the handle or nozzle? Hope this helps
Feb 02, 2018 | Welding Tools
I have a bostitch n80c that has a nail feed problem.
If the driver part of the gun works well, check the feed parts. First check the feed pawl where the nails lay. The teeth should be proud enough to catch and hold the nails firmly and it should work freely in its channel. Next you have to check the parts that drive the feed pawl in the cylinder on the side of the gun. There are seals and a spring and piston that should be checked. Replace any worn or broken parts.
Mar 03, 2013 | Tools & Hardware - Others
Nv45ab won't advance nails
The allen screw/s that you mention are there to plug holes where automatic equipment would normally connect (such as automatic nailing machines) . This is only a plug and should not be driven in too far. I have also seen allen screws installed in the head to repair small crack/s.
Jan 22, 2013 | Hitachi Air Tools & Compressors
Our Lincoln Pro Mig 175 won't feed the wire. The trigger clicks and the motor works but will not feed the wire. There's a burnt resister or capacitor on the pc board and the only numbers that we...
Hi:
If your wire feed motor turns, then your problem is one of the two:
The gun's liner is kinked and no longer is allowing the wire to pass freely, or Your outlet wire guide/drive rolls are all worn out.
Easy fix will be to star with changing the liner and new contact tip. But if all that is working is your fan motor, then check your gun's trigger, if gun's trigger is OK, then change the pc board. Good luck!
Aug 29, 2011 | Lincoln Welding Tools
I have a century mod 11705093 wire welder. I have replaced the trigger switch. Even before this though, when you pull the trigger without wire in it the feed motor spins freely, when you put wire into it...
That sounds like a direct short short to me. My mig has 1 nylon guide tube,one in front of the feed wheel and one just before it inters the liner.They are both insulating the drive wheel from the wire.If the teeth marks are deep enough they will act like a saw and cut right through the nylon tubes and short out on something.You may need a new liner ,the liner is carrying the current instead of the wire.That may be problem. Thank You for choosing FixYa.com
liner.jpg In addition to guiding the wire, the back end of the liner, shown here, contains o-rings and seals to ensure the shielding gas doesn't escape the gun cable.
May 28, 2011 | Century Welding Tools
Hello, I would like to purchase 3035 spool gun and attach it to my self made welder. Could somebody to tell me which power supply I have to provide for spool gun motor? DC voltage, amperage ? Can I use...
the spool gun is a 12volt motor, i usely hook it to the power feed for the feed motor in the welder. it is also 12 volt . i have heard of some welders that have 110 volt feed motors but have not seen one yet but just to be save i would test the power feed to the feed motor before i made the connection.
Mar 11, 2011 | Hobart Handler 210 Wire Feed MIG Welder
Trouble feeding new wire through tip
1. Make sure that the new wire is properly locked down in the advance roller. There are grooves in this and the wire must fit in the groove.
2. Make sure the wire is properly lined up to enter the gun cable (after the roller)
3. Remove outer shield on gun and the center tip and then advance the wire until there is a few inches sticking out, then slide tip back over the wire and install the tip and shield.
Jun 02, 2009 | Century 80GS Flux - Cored Wire Feed Welder
Relay clicks, but wire feed motor wont operate
check for power to drive motor,if power is there when you pull gun trigger then motor is bad.if no power look for bad wire connections then relay.
May 09, 2009 | Welding Tools
Welding Tools Logo
342 people viewed this question
Top Lincoln Welding Tools Experts
Steve
Robert Monigold
Robert Monigold
Are you a Lincoln Welding Tool Expert? Answer questions, earn points and help others
