Question about RCA HD61LPW42 61" Rear Projection HDTV
Replace lamp on 50' rca dlp and still no working.
I think I have a problem with my ballast, I just got a replacement lamp for my rca hdtv replaced it, but still no picture (but there is sound), sounds like the lamp is struggling to power up. The power indicator light blinks five times, stops and repeats over and over again, it then blinked continuously for about a minute. Does this sound like a ballast problem? or is there some special lamp replacement procedure that i didn't do? What exactly is the function of the ballast and what are the common issues when one needs to be replaced. Any solution would help so much. Thank
I just replaced the lamp in rca m61wh185yx1, and the tv is doing the same thing----blink---blink----blink---flashes-steady
what-else could it be
Posted on Feb 21, 2010
  • 668 Answers
Before replacing the Ballast I would look at the power-supply and see if you notice any of the electrolytic capacitors tops being bubbled. It is not uncommon for the capacitors to go bad as the lamp draws more current as it ages and fails. If you do see capacity's bubbled, Replace them or have them replaced and the set will probably work fine afterwards.
Hope this helps,
Skyassoc
Posted on Jun 29, 2009
2 Suggested Answers
ladywinn
  • 5138 Answers
SOURCE: rca lamp replacement, still no picture, power light still blinks.
Ballast Board #261629 Ballast is what turns Lamp on, Also Check your Lamp Fan if it is defective Lamp will not Light!
Posted on Dec 30, 2009
Power light blinking red..tv won't come on after replacing lamp
DLP TV Repair Tutorial - DLP Bulb Won't Turn On - YouTube
? 14:13
https://www.youtube.com/watch?v=5frOnh58Z6M
Jun 26, 2013 - Uploaded by ShopJimmy.com
DLP TV Won't Turn On Common How to Replace Ballast DeadTV ... solid green power light plus sound ...
• New Lamp Doesn't Turn On? Try This! - Fix Your DLP - FixYourDLP.com
www.fixyourdlp.com/forum/viewtopic.php?t=19
Mar 12, 2009 - 50 posts - ‎36 authors
Mine did the same thing after replacing the lamp. ..... TV won't turn on and Color Wheel is GOOD, Temp sensor is GOOD, Ballast is GOOD, and ... • NEW Bulb- still not working
Jan 14, 2010
• Resetting the Samsung DLP Lamp Counter/Hour Meter
Mar 20, 2009
• Samsung Dead Lamp, Black Screen, or Intermittent
Mar 12, 2009
More results from www.fixyourdlp.com
Samsung DLP: replaced lamp however tv won't turn on - HDTV ...
Dec 09, 2015 | Televison & Video
RCA Model M50WH187 DLP TV - lamp cuts out
The lamp ballast supplies power for the lamp, and it is probably going out. You can probably find one on eBay or ShopJimmy for under $100. It looks like a little box and it will be near the lamp.
May 01, 2017 | RCA Scenium M50WH187 50" HDTV
Replaced lamp and still doesn't light up Tv
tanyapetti2,
Did you replaced the cover for the lamp? If not, the TV will not power on. When the cover is replaced, it closes the switch and allows the set to power on.
Ken.
May 27, 2010 | RCA HD50LPW175 50" HDTV
I have a 50'' RCA HDTV lamp goes off and on every couple of hours
Ck the Lamp Fan if it is OK Ballast Board is what powers Lamp on. Encompass Parts Distubtion should List Parts /Prices for this set.If you need anymore help just let me know.
Mar 24, 2010 | Televison & Video
I have a rca 50 dlp hdtv and i replace the blub but the ligh isn't coming on does this tv has fuse
I assume you replaced the lamp since it had gone out. If the previous lamp looked ok, I would hang on to it as it may be ok. If it blown, then it can be recycled. You likely have a defective ballast board which supplies voltage to ignite the lamp. This may have failed on its own or could have been damaged if the original lamp blew out. There are other possibilities also, but that is the most likely. You also would want to try re-seating the lamp and be certain the lamp door is fully closed.
Nov 20, 2009 | RCA D52W23 52" HDTV CRT TV
Dlp 50 inch
sounds like the DM3 isnt powering up the ballast to light the lamp or the ballast may be faulty. i would suggest trouble shooting the DM and ballast voltages.
May 28, 2008 | RCA HDLP50W151 50" Rear Projection HDTV
Replaced lamp still not working
Power issues (Tv True True (``````````` (``````````` 0 95250 95250 clip_image002.gif not turning on) were typically due to faulty ballast. While the TV reports a bad lamp it is the ballast itself causing the issue. Samsung True True (``````````` (``````````` 0 95250 95250 clip_image002.gif is well aware and will replace both the ballast and the lamp (since the lamp can be prematurely aged but the bad ballast). After replacment most people stop having issues.
Jan 16, 2008 | Samsung HLN5065W 50" Rear Projection...
Rca 50 dlp hd50lpw175
Yes but did you find a fuse open and changed it?
Jan 08, 2008 | Televison & Video
RCA HD61LPW42 61" Rear Projection HDTV Logo
689 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
