Air conditioner tary is full of water & won't cool, emptied once & it started to cool, but tray filled up again & it stopped cooling, what to do?? ??
    Scholar:
  • 103 Answers
I'm assuming the air conditioner is a window intallation. Some Air conditioners need water in the botton in order to maintain the condensator coil cool, other have a hole to drain the water. Check inside your equipment, I mean inside, open it and remember all the steps for reassemble. It is more likely inside is stuffed with dust. If its the case, use patiente, toothbrush and hose and carefull not use too much water pressure and mantain electronics and motor DRY!!!
Posted on Jun 28, 2009
Just bought used portable ac. it blows great cold air then blows warm air for a while then back to cool andcold... is this normal? if not hwo to fix?
Yes it's normal in most cases. There should be a knob to turn so it cycles on more often. If it's not a window unit, & is a free-standing unit, you might have to empty a water pan or tank on it. As condensation collects on the cooling coils, it collects in a container near the bottom. If it's full of water, it will cycle the cooling off until you empty the water container or some of the water in it evaporates.
Jul 08, 2015 | DeLonghi Heating & Cooling
It is saying FE with a triangle error, and won't turn on???
Actually, what you're seeing if "FL". It indicates that the water collection tank is full and needs to be emptied. Once that's accomplished the unit will operate again, as it should. Be sure to turn the unit OFF & unplug it, before draining the tank.
Hope this helped you and thanks for choosing FixYa.
Aug 27, 2011 | DeLonghi PACA110 Portable Air Conditioner
Danby dpac 10071 air conditioner is not cooling. a red light is on next to an icon with a full cup. Does anyone know how to make it cool?
That indicates that the water collection bucket is full and needs to be drained. Once the unit is turned OFF, unplugged and drained, the unit will start up and start cooling again. The drain hole is on the rear of the unit, just above floor level. You can either drain it in a shallow sided pan capable of holding 1 quart of water. Or roll it to a floor drain or outside to drain it.
Hope this helps you and thanks for choosing FixYa.
Jul 29, 2011 | Danby DPAC10061 Air Conditioner
There is no drain pipe for the unit I have. It has a cap on the back but no hold, how does the condensation.
Self Evaporating Technology - During the cooling process, water is extracted from the air into the unit. Most of this water is then recycled and used to cool the unit and make it run more efficiently. Approximately 65 to 70% of water condensed is evaporated out with the exhaust air, reducing the hassle of emptying the water tank constantly. This unit has a built-in water tank (not removable) with a drain outlet, and a water tube. When the tank fills, the compressor stops operating and the power light will flash. This indicates that the tank should be emptied.
Jul 21, 2011 | Amcor ALTL-12000E Portable Air Conditioner
New air conditioner turns itself off two minutes after starting
this sounds as if you have an over amping compresser or blower motor......you'll need an amp meter to be sure. as they over amp they heat up and go off on internal protection until they cool back down in which case it may try to run again and again and again and again and again......should I continoue...good luck
Jul 08, 2010 | Sharp CVP10NC Air Conditioner
PORTABLE AIR CONDITIONER (EVERSTAR BRAND)MODEL MPA08CR NEED HELP TO OPERATE THIS ITEM
IF ANYONE NEED TO SEE THE OWNERS MANUAL FOR THE
EVERSTAR PORTABLE AIR CONDITIONER MPM2 , MPM210CEBB6
MODELS # MPM2 - 10CE - BB6
MODELS # MPM2 - 10EE - BB6
MODELS # MPM2 - 10CR - BB6
MODELS # MPM2 - 12CE - BB4
MODELS # MPM2 - 12EE - BB4
MODELS # MPM2 - 12CR - BB4
YOU CAN E-MAIL ME AT - RICHCPZ@YAHOO.COM
I'LL SEND IT TO YOU IN A PDF FILE
(AS LONG AS I DON'T LOOSE IT IN MY COMPUTER )
Jun 21, 2008 | DeLonghi PAC85 Portable Air Conditioner
Is this thing working?
I had the same problem...I was going to get rid of the unit...I notice that tha red light on the little screen on the top was on...then I closed the tray (all this time I though it was closed) all the way and the red light went off and the unit started cooling! I hope this may help you.
May 18, 2008 | DeLonghi CF210 Portable Air Conditioner
Won't cool below 80degrees f
If you have had this unit for a while may need to geet the refrigerant checked
Jul 30, 2007 | DeLonghi CF210 Portable Air Conditioner
Water coming out of the vent
Assuming this is a window unit, make sure it is level. If so, the drain tube between inside & outside may be plugged. This is often visible with the front panel off, & the tube can be cleared with a piece of coathanger wire. The tube is usually only a couple of inches long. Check for damage to the water tray under the cooling coil as well.
Jun 21, 2007 | DeLonghi Pinguino PAC-02 Air Conditioner
Heating & Cooling Logo
175 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
