Question about Whirlpool GU2400XTPS Built-in Dishwasher
Whirlpool Gold dishwasher water overflowing and will not shut off
Dishwasher is started, normal cycle. Water begins to fill and then overflows. Cancel does not shut of water supply, but it does being to drain. Water must be shut off under sink. HELP!!
    Sergeant:
  • 163 Answers
There should be a dome shaped float switch on the inside bottom of the washer. Make sure it is free to move up and down, or is able to float (possibly cracked or broken).
Posted on Jun 28, 2009
Whirlpool dishwasher just keeps filling? help please
check on the floor of the dishwasher on front left side. There should be a round float that is the overflow cut off. \make sure that it will go up and down. This is what shuts off the water.
Mar 07, 2014 | Whirlpool Dishwashers
Whirlpool ADP 4404/5 when left unused but connected to water supply it slowly fills up until it overflows and runs onto kitch floor, i.e while on holiday. I reckon it slowly fills to overflow in about...
Hello there and thank you for choosing fixya
Yes you are about right normally when the unit fills with water and you dont want it to this means that the water inlet supply valve has seals that are weak in it and the water is leaking bye it or the valve itself is failing or may even have debris in the valve keeping it from fully closing so you may want to pull the unit out and inspect the valve and you may even have to remove the outer panels to get to the valve to inspect it and some of them are even located under the left side as you look from the front of the machine ok so check these and if you need more help please post me a comment and i can further instruct you on repair procedures ok?
Hope htis is very help ful for you
Best regards fMike
May 25, 2011 | Whirlpool Gold 24 in. Built-In Dishwasher...
Over flows water on to the floor when operating
as the question states, the floor drain overflows a little (but enough to be annoying) when water is run any where in the house. I rented a motorized snake machine and did that, pulled up some stuff but didn't fix the problem. We have had a ton of snow lately and it is starting to melt. Could this be part of the problem or do I need to call the plumber? Thanks in advance.
Apr 03, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
New Whirlpool Dishwasher filler overflows.
New Whirlpool Dishwashers will NOT accept the same "volume" of water that was desired by the same products of 25 years ago. Therefore the old 3/8" ID copper supply is too large and will overflow the tub filler/aireator (out the air vent holes). I just installed a new dishwasher supply kit consisting of a new 3/8" OD stainless braded hose with an ID of about 1/4". This delivers less volume than that recommended (in the installation manual) and therfore does restrict the flow a bit. However, the flowrate is adequate and the new dishwasher now works perfectly with no water overflow on the floor . . .
Dec 26, 2009 | Dishwashers
Item: Whirlpool Ultra Dishwasher Age: 3 yrs Problem: Not enough water to effectively wash the dishes. State: When the dishwasher is started, the fill valve opens as normal. Only about 1/2 the amount of...
Larry,
The float is generally for overflow conditions and will interrupt power to the fill valve solenoid.
If you are not filling completely in the time allowed by the timer, it is most likely a flow restriction in the water supply. Barring other obvious restrictions, the fill valve has filter screens on the inlet side of the fill valve, which is generally the cause of your symptoms. Be careful if you attempt to clean the screens, as the fill valves are very sensitive to debris, and can become stuck open if sediment gets past the screen. I usually replace the fill valve to avoid future problems.
Hope this helps.
Oct 30, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Blanco dishwasher overflows at end of cycle
There is a float connected to a switch that controls water level. It is usually round and will move freely up and down by hand. But your problem might be a levelling related one. The dishwasher must be level to operate correctly. Use a torpedo level in the tank base to check front to back level and side to side level. Adjust the front legs to level the unit.
Jul 30, 2009 | Frigidaire 24 in. FDB126RB Built-in...
The clean water fill will not shut off and water overflows from the dishwasher onto the floor. We had to turn off the water supply to the dishwasher to get it to stop.
Fill valve is shot , new one required
Ps
Does it still run when you remove the power if so the above applies
If it shuts off then the problem sits with the pressure switch
Jul 03, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
No water running through cycle once filled....making humming noise once clicks into cycle
pump should be checked for restriction of movement,is there something blocking it?does the capacitor smell?if it does its blown(or meter check-more accurate),hope this helps
May 27, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
I have a whirlpool dishwasher (gu2500xtpq6) wont fill up
water level should be approx 1/4--1/2 inch below the heating coil.. this is normal fill level
Apr 28, 2009 | Whirlpool 24 in. GU2500 XTP Built-in...
Open Questions:
See all Whirlpool GU2400XTPS Built-in Dishwasher Questions
Whirlpool GU2400XTPS Built-in Dishwasher Logo
394 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
