Question about Crown XTi 2000 2-Channel Amplifier
I need the schematic for the crown amplifier xti 1000 crown xti 1000 2-channel amplifier
  • mckimani May 15, 2017
    I have xti 2000 flickering displaying " low line" message.. Can't even turn on. Any idea what is faulty?
  • 4,234 Answers
These are available for purchase from Crown. Generally they are not available on the web. Is there a specific problem that you are having?
Posted on Jun 29, 2009
I need crown iT4000 semantic
Schematics are easy to find, just enter: schematic crown it4000 in the Google search engine. I cannot find any semantic
Nov 04, 2014 | Crown XTi 4000 Amplifier
I use the crown xti 6000 for 2 double 18s pd186 for bass per channel
Send a signal from the mixer to the amp directly, seems as if you have a distorted signal from your crossover
Dec 23, 2013 | Crown XTi 2000 2-Channel Amplifier
My xti 6002 crown amplifier ch2 shows thermal protect and fan is in full speed .what is causing the problem kindly give some tips to repair it
Crown utilizes small signal transistors as thermal tracking devices but i think that this is not the main issue with the amplifier, it could be in the output stage with some power transistors failure, does the other channel works fine?
Oct 11, 2013 | Crown XTi 6002 1200w Stereo Power...
Tengo un ampificador crown xti 1000 pero el probema es que al prenderlo si funciona pero a momento de picare a un boton de los que trai para ampificarlo dice lock asi si pueden ayudarme por favor gracias
RESPUESTA : Utilisa el Software que biene para Controlar el Amplificador con el PC o Laptop (BAND MANAGER) si no lo tiene lo baja por Iinternet. lo Instalar luego lo Abre y Busca EDIT se abre una ventana y en la parte de Abajo Dale clis a ...(RESTORE DEFAULT VALUES) Lo que esta haciendo es reiniciar el equipo, todo vuelme al estado original de fabrica.......
Jun 23, 2011 | Crown Xti-1000 Amplifier
How do I unlock my XTi 2000 amp?
Pressing & holding the prev/up & next/down buttons at the same time will toggle the lock on or off.
Mar 12, 2010 | Crown XTi 2000 2-Channel Amplifier
Crown Xti 2000, signal to both channels, no sound out of one, swapped speakers, connectors, etc. , still no sound out of one channel
common problem with xti series... all the amp needs is a soft ware update contact crown and they can sort it for you... you dont have to send the amp back to them. it was a verry common fault with all the early xti amps..
Aug 24, 2009 | Crown Audio Players & Recorders
My XTi 2000 is very distorted intermintently. Sometimes the volume drops by at least half. I tap gently on he top of the amp and it comes back up to normal. I heard Crown has had some issues. What's the...
From your description, I would suspect some poor solder connections inside. If you know how to work on these, check for bad connections near the voltage regulators. That is the mode common area.
Jun 30, 2009 | Crown XTi 2000 2-Channel Amplifier
Hooking up in Stereo
You'll need to use one of the four stereo inputs on the mixer and make sure you wire the speakers separately to channels one and two of the amplifiers. Assuming both of your amps are xti series amps, that's all you have to do.
Good Luck,
May 14, 2009 | Audio Players & Recorders
I have two xti 2000 amp running with electrovoice speaker 600w
This is most likely to be a heat issue where the amps overheat and shut themselves off then cool down and turn back on. Please check that the amps have proper ventilation and that any air ducts are clean.
Feb 26, 2009 | Crown XTi 2000 2-Channel Amplifier
Crown XTi 2000 2-Channel Amplifier Logo
840 people viewed this question
Top Crown Audio Players & Recorders Experts
Are you a Crown Audio Player and Recorder Expert? Answer questions, earn points and help others
