Question about Cuisinart Coffeemakers
Not completely brewing
The coffee maker will not brew all the cups of water that you have put in. So if I put in 8 cups, it will make 2 and you have to start it again, where it will make another two and you have to start it again
  • 4 more comments
  • Phil321 Nov 10, 2007
    I have the same problem. The coffeemaker makes approx. 2-3 cups and then stops. It usually take around 30 minutes of turning the machine on and off in order to brew a pot.
    The coffeemaker started this about 6 months ago (almost at the 1 year mark of ownership). It brews really good coffee, however this is a very annoying problem!
    Please let me know if there is a fix. Thanks!
    Note: I have tried cleaning it with vinegar and no luck. I am guessing it is an electric problem...
  • jyl21 Jan 02, 2008
    pot takes 3 or 4 times turning off and on to complete brewing.
  • rrdsr Jan 03, 2008
    dcc390 about 2 years old started stopping about six montha ago then could not turn off now brew light comes on but nothing happens
  • Shannon Jones
    Shannon Jones Mar 28, 2008
    I have the same problem with my grind n brew - brews about 3-4 cups, then beeps like it's done, but there's still water in the resevoir. I guess I'm luckier than most - mine only started doing it when it was about 3 years old.
  • MisterJoad Apr 03, 2008
    Same problem here, and it seems to be getting worse. Coffee Maker is only 4 months old and this came on rather quickly. Like everyone else, this is unacceptable. Has anyone called the manufacturer about it, and if so what is there response?
  • Anonymous Apr 17, 2008
    My Mr. Coffee is doing the same thing all of you are talking about.  It will not go through a complete brew cycle.  I put in 10 cups of water and it will only brew one or two.  This is the second machine I've had in less than 6 months.  I returned my first on to the Customer Service Center, waited three or four weeks and a new one arrived via UPS.  This new one has worked for even fewer weeks than the original...... I'm disgusted!
I called Cuisinart, and they suggested if normal cleaning does not work as described in the prior post, unplug the machine, and let the cleaning solution sit in it for one hour. Plug the machine in and let it clean. There is a sensor in there that senses when to shut down. Unplugging helps re-set the sensor and the cleaning removes minerals from it so it will sense properly. It worked for me, and hope it works for all of you as well. Good luck!
Posted on Apr 17, 2008
I tried cleaning my maching.... a number of times.  It won't go through the complete cleaning cycle either!
OK, everyone, I cleaned my grind & brew, and the problem seems to have improved. This makes sense, because I didn't have any problems the first few years I had the machine - when I was using the little filters in it and cleaning it regularly. In the past couple of years I stopped using the filters and have not been good about cleaning it, then this trouble started.
To clean the machine, run 1/3 carafe white vinegar and 2/3 carafe water through machine. After the cycle finishes, run a full carafe of clear water through the machine. If this doesn't thoroughly solve the problem try cleaning it again a couple of days later.
See if it works! Shannon J.
Posted on Apr 12, 2008
!0 Cup home Bunn. Does not brew the number of cups of water coffee (water) in craft. 8 cups of water 6cups of coffee.
If you don't brew often enough you will loose a small amount of water in the tank due to evaporation while the tank heater comes on and goes off to maintain the proper brewing temperature, so if it has been a while since you last brewed, without coffee in brew basket put a carafe of water thru the brewer, you will get less than a full carafe out because it fills the evaporated space in the tank first then uses the rest to brew. Once your tank heater shuts off usually 5 minutes on less you will get out all the volume you put in.
Oct 11, 2014 | Bunn 10 Cup Home Coffee Brewer
Slow brewing
The coffee maker has three contributory factors for brewing experiences. First, putting enough water in container prior to brewing is expected to dispense in to coffee capture cup. Second, installing the component parts after inserting coffee leaflets should not hinder brew seepage into the cup. Third, allowing enough time for the brew to dispense is a requisite means to coffee impressions. Furth, coffee leaflets require appropiate numbers inserted at the container area lest the machine takes time to sock and dispense. However, refer to the device user guide for appropiate manufacturers instructures to user as expectations during brewing. Also, refer to the user guide to ascertain any conditions that may be signs of damage preventing fast brewing.
Jan 22, 2011 | Oster HDX23 12-Cup Coffee Maker
KeurigB50 Coffee Maker will not brew. Gets to the
1. Power off machine.
2. Using a metal paperclip, insert it into left side of top needle. It must insert at least 1" deep. Insert it into slot on right side and again from back of needle.
3. Remove KCup cradle. Separate bottom from top. In the top section, insert the paperclip up into bottom needle from the bottom upwards. It will not go all the way thru and this is normal.
4. Reassemble KCup cradle and reinsert it back into coffee maker.
5. Power on machine.
6. Brew a cup of water only. There may be coffee grounds in the water and these should eventually clear during the remaining steps. NOTE: A large cup brew cycle should output a full 8 ounces (235cc). Less means there is still a blockage
7. Empty reservoir and fill with undiluted distilled white vinegar. Repeatedly run brewing cycle until Add Water light comes on.
8. Make sure Auto-OFF is NOT set and let last cycle of vinegar remain inside machine for 4 hours.
9. Refill reservoir with fresh water and repeatedly run brewing cycle until the water is clear and odorless.
10. Set Auto-OFF, if preferred.
Jan 01, 2010 | Keurig Ultra B50 1-Cup Coffee Maker
Unit does not brew all the water from the resevoir
This usually means that you need to get a new coffee maker.
Nov 19, 2009 | Mr. Coffee 072179228578 12 Cup Coffee...
MR COFFEE FTX49. Brewing starts, then stops
Mine just started to do the exact same thing. So I decided to clean it using the "Clean" program and just water. I put the brewer through the cleaning program 3 times - each time it would brew water from 12 cups to 8 cups, I'd tap the brewer on the countertop, it would brew from 8 cups to 4 cups, tap it again, and it would brew the remaining cups. So, I called the Mr. Coffee help line (800-672-6333). The most-likely problem is that the hose is no longer attached in the water reservoir. The help line suggested that I take it in to a service center. I live in Urbana, IL and the closest service center is in Oak Lawn, IL - 2 hours away from me!!
Here is my solution:
1) Buy another coffee brewer.
or
2) Smash your current Mr. Coffee brewer into a million pieces (this relieves stress) and go buy another coffee brewer (probably stay away from Mr. Coffee products).
Hope this helps.
Frustrated in Urbana
Oct 11, 2009 | Mr. Coffee 12-Cup Programmable Coffeemaker
When I put 12 cups of water in the container, only 8 cups brew. Also, it takes 30-40 min. I ran vinegar through it twice and am getting the same results.
the coils are super heating, and condensation of your water is vanishing faster than it's brewing. It sounds like your coffee pot is ready to go to mr coffee heaven
Aug 08, 2009 | Mr. Coffee 072179228578 12 Cup Coffee...
My brewer will not let me change the brew size.
I had the same problem, contacted Keurig and they suggested the descale procedure, which did not work. I was able to resolve the problem however.
First I went through a gallon of white vinegar, without results. Then I did the following:
Went to Walmart and bought "Brew Rite". Tried 8 cup mixture (8 cups of water, two tablespoons of mix), did not work. Being persistant, put in another 8 cup mixture, and when the reservoir emptied of the mix I unplugged it and let it sit 2 hours with the mix in it and then put in clear water. By the time I got half way through with the clear water, the device started working properly, no problems since.
Jun 10, 2009 | Keurig B70 Coffee Maker
GE 169164 Coffee Pot Not Brewing
Loosen the charcoal filter. You only need to GENTLY place it in. Your problems will all be solved. I just did it 5 minutes ago and i just brewed a 6 cup pot of coffee completely.
Jan 07, 2009 | GE 106591 Coffee Maker
Incomplete brew
Sometimes you have to do the decalcification two or three times. Then, monthly after that.
Cuisinart Coffeemaker Decalcification Process
Run 2 cups distilled white vinegar and 2 cups water through the system - brew it like it was regular coffee. Then run plain water through the coffemaker to rinse the vinegar out and make sure the decalcification was successful. Repeat as needed. Don't forget to remove the charcoal water filters first.
-Tha Mp3 Doctor
Jan 01, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Directions on how to use my Black and Decker Espresso Mio coffee maker
Be sure the red rubber gasket is in place and clean (ridge side in) and bottom water cup is screwed firmly on to avoid leaking.
HOW TO USE:
1) Fill the bottom water cup with cold water up to the inside lip.
2) Set funnel into bottom water cup
3) Fill coffee basket with expresso grind coffee and level off. (Do not tamp or pack). Make sure it's filled to the top.
4) Place filter onto coffee basket and set coffee basket into funnel
5) Place brewer over bottom water cup and screw firmly into place.
6) Place unit with lid in the center of a microwave oven set on high for 1-1/2 minutes. If boil over occurs, reduce the brew time in 10-second increments until no boil over occurs.
7) Grasp handle to remove unit from microwave when finished brewing.
8) Remove lid and check the level of espresso in the brewer cup. Standard brew is at least 2 oz. If you don't have this level brew, replace lid and microwave on high another 10 seconds. Wait 20-30 seconds for bubbling to stop.
CLEANING/ADDITIONAL BREWING:
1. Under cold running water, unscrew the bottom water cup. CAUTION: It is normal for some water to be left in the bottom water cup. Both the coffee basket and any water in the bottom water cup will be extremely hot! If you prefer, allow the unit to cool for at least 3 minutes before unscrewing it.
2) To brew additional espresso, rinse Funnel, coffee basket and filter, then repeat brewing steps 1-8 above.
3) Parts are top rack dishwasher-safe -- hand washing filter is recommended.
Mar 10, 2008 | Coffee Makers & Espresso Machines
Cuisinart Coffeemakers Logo
127 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
