Question about Motorola Mobility RAZR V3c Cellular Phone
BLACKBERRY PIN TRYING TO FIND THE PIN TO CONNECT MY BLACKBERRY TO MY LAPTOP
  • 541 Answers
To find the Pin Number of the Blackberry Handset
Perform these Steps
1.In your Handset Press Menu Key.you can see all the Icons on the Screen.
2.Select Options Icon,
3.Under that Select STATUS option.
you can find PIN number.
Posted on Aug 12, 2009
  • 69 Answers
Go to options (the wrench) then to "status" your pin is in there
Posted on Jul 30, 2009
    Problem Solver:
  • 13 Answers
You can find the PIN by looking behind the battery or by goin to Options and then status
Posted on Jul 14, 2009
  • 45 Answers
If you need to know your PIN you can either create a new message and type mypin or do the following:
Menu > Options > Status - your PIN will be inside here
Posted on Jul 11, 2009
My blackberry is asking to put a pin code to my d-;ink router before i can connect to my wifi. were can i find to put the pin in my d-link router?
Connect a LAN cable from the D-Link to your laptop/computer'sLAN port, open the browser on your laptop/computer and enter the D-Link'sconfiguration URL..
http://192.168.0.1
The default login = admin
The default PW = blank (just press Enter) You can now change the default admin password.
You can now configure the wireless settings ie. WEP, WPA, or WPA2 and the SSID Now configure the wireless card in your Blackberry, computer/laptop withthe router's wireless settings.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Sep 10, 2011 | D-Link Router
IM TRYING TO CONNECT MY JWIN BLUE TOOTH TO MY BLACKBERRY CURVE 8530 AND IT WILL NOT LET ME CONNECT. IT SAYS THAT NO BLUE TOOTH IS FOUND. HOW CAN I PUT MY BLUE TOOTH IN PAIRING MODE AND THEN CONNECT IT TO...
When the bluetooth is off press it's button and keep it presed until the led is lighting red. Then the bluetooth is in pairing mode. Relase the botton and start the search for devices on your blackberry and use pin 0000 to connect. Good luck.
Jan 27, 2011 | Jwin BLUETOOTH HEADSET Wireless Headset
I have a blackberry 8520 that i have enter the pin wrongly into 10 times. It says "reload software: 513". How do I do that?
Your phone has suffered a severe software failure and may need professional attention, but you have nothing to lose by trying the following steps (courtesy of GaryCutri on blackberryforumscom.au):-
1. Download the latest firmware from carrier's website - FULL LIST
2. Install the firmware onto a PC running BlackBerry Desktop Manager. DO NOT CONNECT YOUR BLACKBERRY TO THE PC YET!
3. Open Desktop Manager > Select Applications Loader > Select Update Software > Leave the Device PIN\Password prompt on screen.
4. Connect the device and when the PIN appears (or even if it says PIN: UNKNOWN) press OK. If the PIN doesn't appear connect the device with the battery removed and when the PIN appears press OK.
5. Once the device is detected it will show you a list of the firmware to be installed. If this is only a short list select Advanced (or Options on some version) so you can see the full list of software. Ensure you select all the required components.
6. Continue through the wizard and the device will be reloaded within 45 minutes. Please ensure you do not interrupt this process.
7. Once the device is reloaded you will need to resend your BIS service books or if you are on BES (Corporate users only) you will have to reactivate the device (you will need the I.T. department to assist you with this step).
Oct 01, 2010 | RIM BlackBerry Curve 8520 Smartphone
My Blackberry asks me for a passkey when trying to connect to my labtop but I have no idea where to find that key. Rainer
I believe you are trying to connect your Blackberry with your laptop through Bluetooth. You need to disable the Authentication option in order to avoid the Passkey. Or you can generate the passkey from the Laptop also.
May 31, 2010 | Computers & Internet
Blackberry curve 8320 phone does not turn on but red let goes on then turns off. not the battery
you need to reflash you OS on to the phone...
you can connect the phone using the usb cable to the laptop/pc/mac that you are using then open your desktop manager (blackberry).....open apploader then click on software update and upload the OS back to the phone this should work...it has for every phone i fix that just have a red led blinking...also if the DM does not see your PIN, remove the battery from the phone then connect it again you should see BB PIN:UNKNOWN just click next and you should be good to go.
Oct 09, 2009 | RIM Blackberry Curve 8300
Blackberry Messenger
This is what you need to do to correct this issue
Most likely you have conflicting sofwtare so
You need to reflash the OS on the phone you should take the battery out first then connect it via the usb cable to the laptop/pc you are using then open the blackberry desktop manager,click on the apploader, then install the OS.
pls not that when u click on the apploader the pin should be PIN:UNKNOWN you make need to do this like 4x before the pc sees the pin:unknown but it will work once it see the pin:unknown you can re-insert the battery and continue with reflashing the phone
Oct 01, 2009 | AT&T Blackberry Curve 8300 Smartphone
Blackberry 3550
You need to connect it to a PC and reload all the Operating System back onto the device.
Its JVM errors.. it means the operating system got messed up, AT&T has walked me through that one before. If you have a BB software CD (comes in the box) you can do it.
Sep 13, 2009 | AT&T Blackberry Curve 8300 Smartphone
Describe your AT&T Blackberry
try these steps to correct the issue
Sep 08, 2009 | AT&T Blackberry Curve 8300 Smartphone
JVM Error 545 - Blackberry Pearl 8110
to correct this issue try this method
Aug 23, 2009 | AT&T Blackberry Curve 8300 Smartphone
Motorola Mobility RAZR V3c Cellular Phone Logo
115 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
