Question about Ardisam Inc Earthquake Mini Cultivator
I raised the tires on my earthquake cultivator now i can't lower them
  • 112 Answers
You need to remove the axle bolt and tap the thumb style nut loose its corroded to the shaft, lay parts out as you remove them to get reassembly correct.
Posted on Jul 15, 2009
Tines
Either clutch is bad or teeth are striped in bottom gear box. remove tines run engine and see if you can feel movment in lower gear box, if yes the gears are gone. If no remove engine to expose clutch.
May 20, 2013 | Ardisam Inc Earthquake Mini Cultivator
How easy is it to replace clutch cable on earthquake mc 43 tiller
Remove the 4 to 6 screws holding the engine to bottom gear box and lift eng off. clutch is right there. It could be the teeth on the lower branze gear are stripped. lay machine on its side and with tines off remove gear box cover.
Apr 08, 2013 | Ardisam Inc Earthquake Mini Cultivator
My mtd yard machine bogs down in the tilled /cultivated dirt. the belly support is only less than 2 inches to the bottom of the tires! when I till the next row the tires just turn freely and I have to...
Sounds like a depth adjustment or a leverage problem.
Check your manual to see if you are able to lower the tines to a deeper position.
There usually is also a handle adjustment to raise the handle to get more leverage. (Not all Models) By pulling back on the handle it forces the tines into the soil and raises the tires. This allows the tines to agitate and do the work while at the same time walking the machine forward. When you push up on the handle the rubber tires provide traction and forward movement and less digging on the tines.
Method: Possibly by allowing a little space between passes your wheels won't hang up in the previous dead furrow. You can then go back over the skipped spaces or cultivate from the other direction and a criss cross pattern.
Best wishes,
TF
Jun 02, 2011 | Mtd Garden Tiller (Mtd)
Have been on the computer all morning many diff sites getting a nervous breakdown want tine geat & shaft part for earthquake mini tiller all sites are impossible to use help help help
Select the model on this website and then the part. The link below is for MC43E Mini Cultivator http://www.getearthquake.com/foundations/store/partsblowup.asp?product=MC43E
Jul 19, 2010 | Ardisam Inc Earthquake Mini Cultivator
I need a primer bulb for an earthquake cultivator.
search amazon.com w/ your model #should be numerous retailers w/it also you could carry it to your local power equipment dealer and they can match it up there are only a few carb manufacturers.
Apr 11, 2010 | Ardisam Inc Earthquake Mini Cultivator
Rewind on earthquake mini cultivator won't rewind
Call 1-866-598-2128 for parts, they are in Appleton, Wisconsin.
Jun 28, 2009 | Ardisam Inc Earthquake Mini Cultivator
I was wondering what the correct gas/oil mixture is for the MC 53 earthquake cultivator
I mix all my two cycles stuff at 32 to 1, it smokes alittle but runs forever.
Jun 04, 2009 | Ardisam Inc Earthquake Mini Cultivator
Ardisam Inc Earthquake Mini Cultivator Logo
75 people viewed this question
Top Ardisam Garden Experts
Jay Finke
Jay Finke
lnbn1975
Wade Mobley
Wade Mobley
Are you an Ardisam Garden Expert? Answer questions, earn points and help others
