Question about Craftsman 10" Table Saw
Craftsman 10" - blade turns, albeit slower, but cannot cut.
The blade turns at a much lower RPM and cannot handle any load. Stops spinning when it touches the wood. Is there a clutch?
    President:
  • 1,723 Answers
Capascitor is bad.
Posted on Jun 30, 2009
10 inch Jet Bandsaw, cannot resaw hard woods, blade stops
if blade stops tunring then it's one of two adjustments need to be made , 1st blade tension this is set with hand screw on left side of top part ,2nd the speed of cut is too great , adjust the speed control for the hydraulic clyinder that holds top carrage to bottom , just behind the middle of unit to alllow for slower blade desent , these pistons do go bad ive replaced mine before ,
Jan 21, 2015 | Jet J-7040M 10-Inch by 16-Inch Three Phase...
Blade not cutting. How can I adjust? Craftsman model 358.796480
When the blades are engaged do they turn? It could be a belt is loose tha causes the blades not to spin. Check the handle that engages the mower deck to see if it goes into the proper slot which would cause the blades to spin.
May 18, 2014 | Garden
Sears Craftsman rider mower bought in 2001. Still runs really great. However, lately it will not cut the grass when I lower the deck to positions 1-3; the blades seem to stop; no cutting action at all. As...
Do the blades need sharpening? Check the belts for tightness and the spring that holds the tension. what stops? The blades stop, but the belt is still turning? Check to also make sure the blades turn freely with the belt disengaged. you may have a spindle problem too.
Jul 23, 2017 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
10" tablesaw just started to
Hi, W/D here.
Unplug the saw first. Raise the plastic around the blade on the table and look first for material around the arbor, particularly slivers of wood. These can sometimes act as a "brake" and cause the machine to rotate slower. Clean out all sawdust and wood slivers. You can get most of it with a vacuum. While you have access to the arbor, rotate the arbor by hand, feeling for excessive resistance. You can lubricate the arbor with a light machine oil. Look at the belt, and test the tension by squeezing the belt toward the other side, in the middle between the pulley on the motor and the pulley on the arbor. It should squeeze in (deflect) about an inch or so, and be tight in it's position. If the quality of the belt is not up to par; if you feel that it is stretched, or is cracked or otherwise deteriorated, replace it. You can get replacement belts from auto parts stores, at a significantly lower price than ordering through Sears. They'll match you up. While the belt is off, blow the windings of the motor out with compressed air. Sawdust infiltrated into the motor can also cause the motor to run slower. Lastly, take a very close look at the blade. A dull blade will cut slower, and this is especially noticeable in wetter and harder woods. Examples of wetter wood would include treated lumber; harder woods would include species like oak. If the blade is dull, have it sharpened, or replace it.
Best regards, --W/D--
Mar 03, 2011 | Craftsman 10" Table Saw
My Craftsman riding mower runs fine but when I try to cut thick or tall grass the blades slow down and stop cuting, I replaced the belt thinking the belt was worn only to find I still have the same...
well yep it is,,,look at the deck first to check its not tight to turn look for sezed up bearings,,,then check that the drive belt/s are tight and not flopy and slipping also it would be a good time to check the cutting blades they need to be sharp and not blunt or they strain the belts and start them slipping too also the engine wont like the extra load put on it
Jul 28, 2010 | Craftsman Garden
Craftsman 18hp riding mower runs & stalls when engage the blades
motor off= deck engaed turn blade should turn motor and belt fairly easy, NO remove the belt from the motor pulley with deck engaged blades should turn freely.
most decks have breaks on the pullies so if the deck is not engaged the break will be on
May 27, 2017 | Craftsman Garden
My Craftsman 8 1/4 Radial Arm saw
tighten retaining bolt if still spins remove bolt and add a washer to the out side of blade between the bolt head and retaining washer and retighten
Jan 29, 2010 | Craftsman Saws
Craftsman 10" Table Saw Logo
169 people viewed this question
Top Craftsman Saws Experts
Craig Butler
Craig Butler
Are you a Craftsman Saw Expert? Answer questions, earn points and help others
