Cellular Phones
Problem for Cellular Phones
Generic problem for all Cellular Phones
Unlock samsung sgh e250 to any network
By badboy69 on Nov 07, 2007
its on o2 but i want to put my orange sim card in it so i need the unlock code
Same Problem
Apr 28, 2009
-   i turn on my phone after puting in the full reset code and it still comes up with phone freezed, then it says enter password, can i have that password ( its not 00000000 (8zeros), plase help me -   fast_death88
Mar 04, 2009
-   hi i have a samsung sgh e250, i need the network unlock code, is locked to virgin, optus n i want to use vodafone. -   peirced069
Feb 01, 2009
-   i entered my new phone lock code and now its say sim lock and it asking for a password...anyone have a solution?????????pleaseeee help me -   Guest
Dec 15, 2008
-   im the same-   Guest
Dec 09, 2008
-   i CANT UNLOCK IT -   Guest
Best Solution
posted on Feb 08, 2008
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Solution #2
posted on Jul 22, 2008
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Solution #3
posted on Apr 27, 2009
Helpful)
jonny_heap
Rank: Apprentice
Rating: 88%, 2 votes
*2767*JAVA# Java Reset and (Deletes all Java Midlets)
*2767*MEDIA# Reset Media (Deletes All Sounds and Pics)
*2767*WAP# Wap Reset
*2767*CUST# Reset Custom EEPR0M
*2767*FULL# Reset Full EEPR0M (Caution)
For example : *2767*JAVA# would be keyed in as *2767*5282#
Note : Not all codes will work with SGH-C100.
Other Samsung Codes
*#06# IMEI code
*#9998*4357# Help Menu
*#9998*5282# Java menu (GRPS/CSD settings for JAVA server)
*#9999#0# Monitor Mode
*#9999# or *#9998*9999# Software Version
*#8888# or *#9998*8888# Hardware Version
*#9998*746# or *#9998*0746# or *#0746# Sim Infos
*#9998*523# or *#9998*0523# or *#0523# Display Contrast
*#9998*842# or *#9998*0842# or *#0842# Vibration On (until you push OK)
*#9998*289# or *#9998*0289# or *#0289# Buzzer On (until you push OK)
*#9998*288# or *#9998*0288# or *#0288# Battery & Field Infos
*#9998*377# or *#9998*0377# Error log
*#9998*778# or *#9998*0778# or *#0778# Sim Service table
*#9998*782# show date and alarm clock
*#8999*638# show network information
*#9998*5646# change operator logo at startup
*#9998*76# production number
*#9998*968# view melody for alarm
*#9998*585# Non-Volatile Memory (NVM)
*#3243948# Digital Audio Interference Off
*#32436837# Digital Audio Interference On
SAMSUNG T100 SECRET CODES
*#06# -> Show IMEI
*#9999# -> Show Software Version
*#0001# -> Show Serial Parameters
*2767*3855# -> Full EEPROM Reset ( THIS CODE REMOVES SP-LOCK!!!! but also change IMEI to 447967-89-400044-0, you must use CHGIMEI to restore it)
*2767*2878# -> Custom EEEPROM Reset
*#8999*228# -> Battery status (capacity, voltage, temperature)
*#8999*246# -> Program status
*#8999*289# -> Change Alarm Buzzer Frequency
*#8999*324# -> Debug screens
*#8999*364# -> Watchdog
*#8999*377# -> EEPROM Error Stack
*#8999*427# -> Trace Watchdog
*#8999*523# -> Change LCD contrast
*#8999*544# -> Jig detect
*#8999*636# -> Memory status
*#8999*746# -> SIM File Size
*#8999*778# -> SIM Service Table
*#8999*785# -> RTK (Run Time Kernel) errors
*#8999*786# -> Run, Last UP, Last DOWN
*#8999*837# -> Software Version
*#8999*842# -> Test ********
*#8999*862# -> Vocoder Reg
*#8999*872# -> Diag
*#8999*947# -> Reset On Fatal Error
*#8999*999# -> Last/Chk
*#8999*9266# -> Yann debug screen (=Debug Screens?)
*#8999*9999# -> Software version
SAMSUNG V200 SECRET CODES
v200 Unlock Code-> *2767*7822573738#
*#9324# Netmon (press the hangup key to exit)
*#9998*JAVA# Edit GPRS/ CSD settings (S100 Only)
*#9998*Help# Help screen/ List of codes
*#9998*LOGO# Change operator Logo
*#9998*RTC# RTC Display
*#9998*Bat# Battery Status
*#9998*Buz# Turns Buzzer ON
*#9998*Vib# Turns ******** ON
*#9998*LCD# LCD Contrast
*#9998*9999# Softwre Version
*#9998*377# NVM Error Log (?????)
*#9998*NET# SIM Network ID
*#9998*778# SIM Serv. Table
*#9998*SIM# SIM Info
*#9998*PN# Production No.
*#9998*968# Reminder Tune
*#9998*NVM# Displays Non-Volitile Memory Status
*#9999*C# ???????????????????
*#06# Displays phones I**I No.
***/// ***/// NOTE /// *** RED COLOR , they appear serious !!! Use at
own risk !!!
*#9998*2576# Forces SIM Error
*#9998*DEAD# Forces Phone Crash
*2767*MEDIA# Resets the medis on the phone (deletes all downloaded
pics/tones)
*2767*FULL# Resets the EEPRON *DANGEROUS*
*2767*CUST# Resets the Custom EEPRON
*2767*JAVA# Resets JAV downloads (deletes all downloaded midlits)
*2767*STACKRESET# Resets Stack
*2767*225RESET# ????????????????? * Dangerous *
*2767*WAP# Resets WAP Setting & Deletes Favorites
SAMSUNG A800 SECRET CODES
The universal unlock code is *2767*637# do this with out your sim in
By default, the firmware (software) for x600 only receives java
apps and other applications like stuff by serial port.
but even for it, you have to enable the serial port, which also
causes
the closing of all other ports, even the IrDA too :-( ..
well, guess what, i have very good news for you,
do you know, you can increase the sound level,
the sound level for tones, speaker fone, etc,
can be increase even then if it is at max (level 4)
you still can do it,
just follows the instructions!
**************** HERE WE GO **************
Enter the following code:
*#8999*8378#
(You'll be shown menu, then ...)
then go to:
"H/W test"
then go to:
"Audio Settings"
then go to:
"Melody Gain"
There will you see a number.
there are five (5) Melody Levels" of it.
(and currently, you are at level 1 and after
pressing the "save" button, you will move to
level 2 and so on .........................)
you have to change the values of all the levels.
and as the resultant, it will give increase the
melody sound!, your tones will more louder,
even more louder then the max. ringing volume.
the level wise numbers are: (as its my setting :-) )
Melody Level 1: 13
Melody Level 2: 17
Melody Level 3: 18
Melody Level 4: 25
Melody Level 5: 31
you even can make your own combinations of level wise
sounding numbers that can change the sound level!.
if your combination cause more louder sound level,
then mine,
then do share it with the group! ... :-)
meanwhile, try my figured-out combination!
************ CAUTION ************
if anything goes wrong,
then you can apply the master reset code,
that will NOT delete anything, ANYTHING from your
cell fone, but set each and eveything to its
default/standard setting ...
(likes, factory settings :-) )
the master reset code is:
#*7728#
I take no responsibility of these codes are working or not,
or its effects on your cell fone
but i have tried these codes on my cell fone.
and i bet, nothing goes wrong,
but even then of my words, be carefull!,
The code: *#8999*8378#
as i regarded it a informative code,
will tell you each and everything about your cell fone.
and in the "H/W test",
there are lot of other Audio settings,
each of them having five (5) levels,
you can change the combination, but before doing anything,
do write the defult number sequence to some place so that
you'll be then able to invert it again! .. :-) ...
#*2558# - Time ON
#*2527# - GPRS Switching Set to class {4/8/9/10}
#*4263# - Handsfree Mode: ACTIVATED
#*53696# - [Java dnload] WAPSAR mode
#*536961# - WAPSAR enable HTTP disable
#*536962# - HTTP enable WAPSAR disable
#*536963# - SERIAL enable Others disable
#*5663351# - [Phone Model] SAMSUNG SGH-X100
#*6420# - Mic off
#*6421# - Mic on
#*7632# - Sleep mode
*#8999*523# - Main LCD Brightness
*#8999*3825523# - (?) External display
*2767*3855# - Full EEPROM reset(Reset all type of locks)also you'll
lose pictures and java not melody
Remove camera sound:
On main screen type:
*#8999*8378# --> Test mode
H/W test
Audio Settings
Melody Gain
Then replace 6 by 0, it'll show 12 but it's OK
Press back until main screen
Then press key volume to minimum and let's try !!! no more sound
tip by C-Quest
*2767*688# resets the phone
Have Fun ;)
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #4
posted on Jun 24, 2009
Somewhat Helpful)
muthumadhu
Rank: Wiz
Rating: 84%, 33 votes
U can get the unlockcode for Your mobile in the site unlockguide
Was this helpful?
Yes
No
Popular Solutions for Cellular Phones
Questions and Unsolved Problems for Cellular Phones
Answer
I locked myself out once because I needed a PUK code for the Samsung Impression, I called customer... (More)
Answer
My nokia 5220 is showing message ''contact service'', and dissapeare then mobile turnd off ..what do... (More)
Answer
I have a ''Samsung U700'' mobaile . i just cann't recive or call any phonecalls !!! it happened to... (More)
Answer
Hi, I have a K810i. It is becoming more and more difficult to hear the person on the other end... (More)
15 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Dec 04, 2008
can u plzzzzzzzz tell me the unlock code
Comment by Guest, posted on Nov 05, 2008
i have the same problem too, im trting to do this for my boyfriend
Comment by sly_0014, posted on Sep 11, 2008
its sayin network lock n i wanna unlock it to use my sim card
Comment by Guest, posted on Sep 06, 2008
samsung sgh e250
Comment by jonty123, posted on Jun 09, 2008
mines on o2, want t mobile pwease =P
Comment by Guest, posted on Mar 27, 2008
SAME
Comment by Guest, posted on Mar 03, 2008
iv got a samsung sgh e250 wanna unlock it from tmobile to any sim card, but iv got an orange sim so even jus that'l do. iv manged to do the same with a nokia before but it seems much more troublesome with samsungs. any ideas would be greatly appreciated. p.s iv already reset the phone by typing in a code
Comment by Guest, posted on Dec 13, 2007
i have same problem if u find help please help me.
Comment by cioby, posted on Dec 08, 2007
My samsung sgh-e250v is freezed and I forgot the password
Comment by Guest, posted on Nov 10, 2007
I want to do the same, did you ever manage to resolve your problem? if so how.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Cellular Phones:
Top Cellular Phone Experts
Rank: Guru Guru
Solutions: 554
Experience: Experienced a lot in computer troubleshooting. Knowledgeable about cellular phones.
Ask Me
Find more Cellular Phone Experts
Top Cell Phone Repair
CPR
(800) 818-8800
We offer hight quality OEM such as travel charges,...
CPR
(918) 955-1100
The Cellular Phone Repair Center opened in March...
cellularphonerepaircenter
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
