My hotpoint AQXXD169PM frist said the pump was
My hotpoint AQXXD169PM first said the pump was blocked which i unblocked then it said F11 what does this mean?
  • 15,935 Answers
F11 - No hot fill.The ambient temperature is likely to be below freezing possibly due to the pipes being frozen. Also check that the taps are on or if the drain hoses are kinked.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 11, 2010
Hotpoint aquarius 7kg wmf 760 washing machine door wont open
the pump filter is blocked you need to pull the washer out and tilt back the door should open but there will be water in it unblock the filter should be ok
Nov 29, 2012 | Hotpoint Washing Machines
F-11 error
F11 - Pump cannot be activated. it looks like the pump has gone one thing to check is that it is blocked if not then pump gone also something to try is resetting it switch off at plug for 5 mins then back on and try again hope this helps.
Sep 28, 2010 | Hotpoint Ultima WF860 Front Load Washer
By hotpoint ultima ctd80 tumble dryer has error code f11. What does this mean?
F11 - No pump connection. the pump that pumps the water up to the draw has gone wrong. hope this helps.
Sep 26, 2010 | Hotpoint Ultima WF860 Front Load Washer
Hi I have a hotpoint ultima it is showing f11 could you tell me what it means Thanks
F11 - No pump connection.The drain pump is either blocked or drain pump is loose or drain pump hoses are loose .Or the drain pump connections are faulty. The error f-11 is related to drain pump and its connections,. ----------- You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 27, 2010 | Hotpoint Ultima WF860 Front Load Washer
My hotpont tumbledryer keeps flashing up f11 its a hotpoint ultima ctd85 pls help
Fault code F11 means that the pump is not working,check the pump connections and the pump itself.
Please leave feedback.
Thanks.
Nov 12, 2009 | Hotpoint Dryers
My Hotpoint Ultima super silent is occasionally showing the warning sign F11. Can you tell me what this sign means?
F11 means the pump cannot be activated.You may have a loose conection or faulty pump. For Hotpoint error codes go to http://www.selfix-uk.co.uk
Jul 08, 2009 | Hotpoint Ultima WF860 Front Load Washer
REMOVAL OF BLOCKED PUMP ON WASHING MACHINE
Remove the lower portion of the front panel. 3 screws.
Twist the pump filter and pull to remove it.
Mar 17, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint wd640 f-05 and f-11 error codes washer does not empty
f05 say pump blocked or pressure switch fault. whereas f11 say pump cannot be activated... so either an open circuit pump or fauty pcb..
Oct 14, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint ultima wt741
f11 keeps flashing door won't open
Sep 01, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Aqualtis Error code F11
please could someone help as i have the exact same problem with my aqualtis zqxgf149,exactly as above,fitted new pump myself and its now emptying the water but wont spin and in wash cycle f11 comes back up
Jun 27, 2008 | Washing Machines
Washing Machines Logo
314 people viewed this question
Top Washing Machines Experts
