Can't boot up Dell 5100 Dimension, plugged in power cable, heard one click and then amber light flashes.
Comments:
Jun 28, 2009
- Sorry kind of confusing... the power button had amber light flashing and codes show 1, 2, 3 and then it becomes quite..
Jun 28, 2009
- I tried again and now not even see error codes on the panel, just the power button has amber light flashing, fan is not running, so quite, not evening hearing click any more.
When you mean the amber light, is that the blinking hard drive access light or the power light? Different cases have different colors on it. Mine has blue and green lights.
If you see the boot screen (bios) and then after it goes to boot, does it blink and hang?
This could be a simple operating system issue, hard drive or hardware/motherboard issue. If you could provide more information, that would help.
When i turn the tower on the fans start then a little red light flashes but then it turns off after...
(More)
When i turn the tower on the fans start then a little red light flashes but then it turns off after few seconds ? please help it is a Packard Bell
i hv window 7 installed on my computer, i hv made 6 partition on hard drive... i dont know what...
(More)
i hv window 7 installed on my computer, i hv made 6 partition on hard drive... i dont know what happend today... when i try to open the G: drivemsg displays>> ''Access is denied''. i m not able to open the drive. in its properties 0 byte free. Any help??? plz. my all important data is saved on this drive.
recieve error message when trying to setup zune system to dimension 5100 0x8007063 what wrong is it...
(More)
recieve error message when trying to setup zune system to dimension 5100 0x8007063 what wrong is it something i need to add to pc
I CAN play MP3s and CDs and hear the music on my myspace page when it loads. I can hear music on...
(More)
I CAN play MP3s and CDs and hear the music on my myspace page when it loads. I can hear music on other people's myspace pages when it's imbedded into the page as an mp3; however I cannot hear the music on peoples Myspace Music Players. This started late yesterday afternoon and of course I presumed this to be a myspace problem and didn't give it much thought. When I turned on the computer today something visually went by fast (maybe a small gray java window) like it was installing something (maybe windows haha) but it may have said Windows Media Player. When it finally came up I opened Windows Media Player and tried to play an MP3 and it said I was missing a codec and provided a proper link. I clicked on the link and immediately got the codec and now the MP3s play. But still Myspace Music Players don't play. Here is the bad part that made me realize it wasn't a myspace problem. My midi files do not play nor do any of my webpages play the midi files on them. The only change I made was yesterday I deleted X-Vid codecs that I had downloaded months ago and did not use. I used add/remove programs and removed X-Vid. Anyway I did a full Nortons scan and was clean. Then I ran a full Ad Aware Scan, and ran CCleaner as well and nothing is very wrong with my system other than no sound with midis. I finally decided to do a full system restore to yesterday that failed as it said I had made no changes. Then I tried a system restore to last Sunday and it said there were no changes made and so no restore would be made. So it probably wasn't the X-Vid delete that caused the problem. In troubleshooting in Device Manager I tried to update ALL the audio drivers and it said I had the best (latest)version of all the drivers. I clicked on everything individually and then ran the troubleshooters which took forever. I have no yellow exclamation points and it says all things are working properly. except for one thing. when I click on Unimodem Half-Duplex Audio Device it says this device is working properly. When I click on properties and then again on the tab that says properties and then on the words Modem Wave Driver it says Status:Driver is enabled but not functioning properly. Yet previously (higher up) it said it was fine. (this is device 5.3.2600.2180) Also if I click on Control Panel, Sounds and audio devices,sounds tab.... and click on a sound.... it used to let you preview the sound but now the tab is gray. I don't know what to do next. If my sound card was unseated my mp3s wouldn't play. I have rebooted several times. I have tried reading Dell forums (I have a Dimension 5100) and I have read forums for Unimodem half-duplex audio device and forums for Sigma tel High definition audio codecs although that one says its working properly. Since it seems to only be Midis affected and it is called a Modem Wave Driver, could the dial up modem be unseated? could it be that simple?
