It ran out of gas and it's the first time so I had some gas put in it but it wouldn't start , than t hough it was the battery so I had a new battery put in it, and still won't start, has new plugs put in a few days before to help it run but it just won't start.please help i don't know , can anyone help. Thanks
Paul is on the right ball - it sounds like fuel - turn over the engine with the pipe disconnected until the fuel comes through - if you don't succeed, consult a reputable shop - you need someone that knows what they are talking about to physically look at the car to solve the problem - this will save you a lot of time and expense. ?
No engine option stated.
you said GAS so i must assume its not the Diesel.
is the immoblizer lamps and secuity lamps happy? in the dash cluster
if not, BINGO>. (oper. guide tells how to start the engine and that)
next for Gas engine,s is to check spark after you check the fuses
in the fuse box.
2.0L Theta 143hp I4 petrol
2.4L Theta 138-162hp I4 petrol
2.4L Theta II 175hp I4 petrol
2.7L Delta V6 170hp petrol (2005-2006)
2.7L Mu V6 185-194hp petrol (2007-2010)
2.0L CRDI VGT 140hp I4 diesel
Take the fuel feed pipe off after the filter and prime the fuel up till the fuel comes out and then you know the filter is full and then the fuel pump will take over !
x2 , prime it, but do be safe, fuel leaks are nasty around sparks.
but was 169 days ago , id bet its either fixed or sold. i bet holy got is serviced.
holly, if still here, bet not, running the tank dry is bad the fuel pump is fuel lubricated and fuel cooled, so running any car dry (EFI) invites blown tank pump or a very short life. operators guide does warn of this.. weakly.
