Question about Sharp R-1514 Microwave Oven
My microwave interior light turns on when i go to heat something up, but nothing is working. however, all of the exterior fans and lights are working. how do i fix this?
  • 82 Answers
U need a expert its sound like some thing on the high power circuit has blown need checking with proper meters
Posted on Jun 28, 2009
With the door closed, the oven makes a buzzing sound. If I try to microwave something, the interior light lights, the turntable turns, the normal fan sounds while the buzzing sound continues. No heat is...
You can possibly have a bad diode and or magnetron. When working on microwaves you have to be very cautious of what you are touching there is a capacitor inside that stores a voltage and can cause physical harm if not discharged.
Mar 21, 2015 | GE PEB1590SMSS Stainless Steel Profile 1.5...
Microwave light stays on and unit won't heat/run
If it's not heating at all, the magnetron is to blame.
May 26, 2012 | GE JVM1330BW/WW Microwave Oven
MICROWAVE DOESN'T WORK
32 years from a microwave!! Wow! Time for new. No parts available anymore. The smithsonian may be interested.
Oct 02, 2017 | Montgomery Ward Microwave Ovens
No heat, does not cook
Q - The microwave makes a loud "hum or buzz" noise but will not heat up the food?
A - 9 times out of 10 this is usually this is a bad magnetron, the other time is sometimes a bad high voltage diode. See components section.
Q - My microwave is running and sounds like it is working but will not heat up anything.
A - Many thing can do this but, common things are....loose high voltage wire.....poor solder joint on board.....magnetron.....power relay.....
Q - The microwave display counts down and the inside light is on,  but nothing is heating and the fan is not running.
A - This most commonly is a bad door switch, other possible problems are a faulty relay or solder joint on the power module, but a bad door switch is most common.
 Q - My microwave went dead when I opened the door ( same problem as closed the door ).
A - This often is a stuck or faulty door switch and it has blown the interior microwave fuse.
Q - My microwave is completely dead.
A - House fuse has blown or interior fuse inside the microwave has blown ( usually a part inside the microwave makes this fuse blow ) Sometimes a bad fuse holder inside the microwave cannot hold the fuse tight enough and the fuse will blow as well.
Q - The fan in my microwave oven is not running will this hurt my microwave?
A - YES, the fan cools the magnetron and electronics, take the microwave in for service, most fans are not too expensive to replace.
Q - My microwave blows the fuse inside itself as soon as I push the start button.
A - Usually a shorted high voltage capacitor...see components section.
Mar 01, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Does not cook - time counts down extremely fast
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes.
Then let us know if the hard reset does not fix it.
and please reply back with your brand and model number so we can help you.
Feb 06, 2009 | Goldstar MV-1526 Microwave Oven
Slow heating; sluggish fan; low interior light
The main power supply may have a fault. Also, the HV supply may be weak at the same time.
Jerry G.
Apr 01, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Doesn't heat anything anymore...
check highvoltage section and diodes and finally replace magnetron...
Oct 13, 2007 | Sharp R-1500 Microwave Oven
Sharp R-1514 Microwave Oven Logo
128 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
