Unable to run due to MIDI.DLLs problem . How to correct the situation.
  • 21 Answers
Possibly the dll is corrupt, so go to this link to download the dll again.
I’m happy to assist further over the phone at https://www.6ya.com/expert/barbara_87cfe34e34050f26
Posted on Jun 29, 2009
Voyetra midi orchestrator
The only Voyetra Midi Orchestra Plus software I can know was written for Windows 3.1 and Windows 95. Thus there are several reasons for it to be incompatible with Windows 8. First, it was a 16-bit software; the most common Windows 8 installs use a 64-bit OS. This means that the OS has undergone a number of major changes. The installers are completely different (format/way of talking to the OS). The DLLs that communicate between the software and the OS have also changed. The drivers for MIDI devices will be totally different in the modern OS.
The documentation for Voyetra Midi Orchestra is available here: http://www.turtlebeach.com/support/files/241/ . It is a discontinued product and no one at the company that owns it will be writing a new version of the code for Windows 8. I'm not sure this software will work in Windows 7 32-bit. You might be able to use the software in a compatibility mode from a virtual version of XP. For Windows 7 Pro, Virtual PC and the XP mode package are available as free downloads and can be used if your hardware allows. Windows 8 Pro has Hyper-V but requires a licensed version of any Windows OS that you want to use. For non-pro versions of Windows software, you would need to buy a Pro upgrade. The alternative is to obtain another Virtual machine software (VMWare, for example) and a licensed copy of XP or an older version of Windows. (OEM Windows 7 Pro licenses are still available from many computer hardware vendors.)
I hope this helps.
(Many 32-bit device drivers don't work under Windows 8; older software that didn't run under Windows 7 have similar problems.)
Nov 29, 2013 | Yamaha Music
Fallout new vegas (0x0000005)
Drivers or DLLs are missing. Re install the programme.
Oct 25, 2013 | Computers & Internet
After installation SONY jam trax it display "unable to createaudio manager" , "unable to creatr midi manager"
right click to Troubleshoot Compatibility. follow instructions. will work if you Run it as Win XP
Jul 26, 2011 | Sony Jam Trax Full Version
I have a MIDI problem with the Obey 40 - basically it's very erratic in accepting midi instructions. I have about a dozen banks of scenes created and one chase and I'm trying to set up my MIDI files to...
I am assuming that you are imbedding the changes in the midi sound files themselves. They will need to be on a separate track with the correct midi channel assigned at the beginning of the track.
Dec 09, 2010 | Chauvet Obey3 3 Channel Dmx-512 Controller...
I connected my Casio CTK 496 to Fruity Loops DAW. I am unable to send CHORDS and note duration information to the DAW. If i press a note, while the Keyboard is connected to my DAW, my DAW outputs the...
Oh, oh... that is often called the "Dreaded MIDI Drone".
There ccan be more than one causes, however two of those are this:
1. The receiving device either does or does not respond to the note off command or only responds to the note on command with zero velocity, which is also now interpreted as note off. Check the MIDI implementation chart to determine this.
2. Two MIDI commands have merged without using a MIDI merger which makes sure ONLY complete MIDI commands are sent. If the commands are mixed, dreaded MIDI drone is assured.
Sep 07, 2010 | Casio Ctk 496 Electronic Keyboard with 61...
Blackberry Pearl 8100 (unlocked TMobile) camera exposure AWFUL
download the DLL drivers and dsktp-mngr should start working again and you can update your software, although for the camera, i think that might be a hardware issue compared to a software issue.
Dec 30, 2009 | RIM BlackBerry Pearl Smartphone
I get the following problem during installation 1607: Unable to install installshield scripting Runtime. please help me
Unable to continue or unable to install with this program are searching for support on it. Runtime errors are common in system registry which a certain is missing or broken.
There are some causes on it.
  1. Confliction with TSR or other running program.
  2. Software Issue
  3. Computer Virus
  4. and Memory Use.
To fix it here is a link to help you:
www.yboyandrei.com/runfix
This one can repair all broken DLLs in your system.
Please rate if i am helpful to you.
Thank you.
Sep 01, 2009 | Peachtree Software Accounting 2005 for PC
Dlls for kernel
Error Message:
Load needed DLLs for Kernel Translation:
Important Windows XP program files are missing or damaged.
Solution:
This error is confusing for several reasons. First, many users may not understand that the kernel is the main program file in WinXP, the heart of the operating system. Second, the term “load needed DLLs” is just ambiguous enough that you might not know how serious the error really is. Unfortunately, this problem cannot be corrected by just rebuilding the system Registry or restoring files from the WinXP installation CD. You’ll need to perform an “in-place install” of the operating system, which will destroy most of your settings such as Internet Favorites and all of your applications. The good news: An in-place install will usually not overwrite files in your My Documents folder and will keep other files located in other directories (as long as they are not operating-system-related). To perform an in-place upgrade, you’ll need to boot from the WinXP CD, which might require that you enter the BIOS (Basic Input/Output System) of your computer and enable the Boot From CD option. Then, when the install starts up, select the Install WinXP option and follow the remaining instructions.
Nov 07, 2007 | Compaq Presario 2100U Notebook
Computers & Internet Logo
98 people viewed this question
Alun Cox
David Payne
David Payne
