Question about Boating
Motor runs fine at first but when you go to full throttle the motor stalls and will only keep running at a lower idle? seems to be fuel related so I checked the fuel filter its cleen. I then found a fuel pressure gage and checked the fuel pressure in idle and full throttle. after priming before starting 10-12psi. in idle 4-5psi. in full thottle drops to less than 2psi. I do not know what is the correct psi. per condition? how should I proceed?
    Problem Solver:
  • 5 Answers
I'm not too sure but it sounds like theres a problem with the actual throttle. there could be a pressure release in the throttle line thats not working right or like in a car the pully/lever like system that controls the throttle is messed up. i would check to make sure your model has a pressure release or is known for falty throttle gauges. hope that helps
Posted on Jun 28, 2009
Rough idle, bogs when I give it throttle then dies
Brad:
Go back to the carburetor adjustment screws and snug them down gently. Do not use force on those screws or you'll damage the needle valve seats. Turn both screws out one and a quarter turns out and start the saw. The motor should stay running.... if not adjust the screws until it stays running. Turn one screw in until you hear the motor start to stall, then turn that screw out just a little bit. turn the other screw in until the saw starts to stall, then turn that screw out a little bit. Now if the saw bogs at full throttle, turn one screw out one quarter turn. See if the saw runs at full throttle... if not turn that same screw in to where it was and try the other screw the same way. If you're good, you can adjust the screw while the saw is running to get the best full throttle run. This is not an exact science, and it takes time and many adjustments to get the saw to idle and run at full throttle. Good luck... and have patience.
Oct 03, 2015 | Garden
1987 60 hp mariner idle & high idle great, stumbles/ stalls in gear on take off, head gasket or poor idle adjustment?
Clogged idle circuits in your carbs. Clean jets and passages.
You can try suck dirt out, therefore: Screw the idle mixture screw out ( almost totally ), give full throttle ( 1 second ) and then hold your hand against the carb air intake.
This will give maximum suction and can suck the dirt trough tje circuits.
Also, first drain the carb(s) to be shure there is no water in it...
Aug 22, 2017 | Light Boating
1995 chevy tahoe 4wd. 5.7 liter when cooled down, starting is normal . Right after, engine almost stalls but Idle air control kicks in and keeps it running. eventually it is idling but rouph. On...
If your vehicle has one, and I think it does, check your EGR system. If the egr valve is full of carbon, it can be partially open, creating a vacuum leak. If the egr valve solenoid is bad, it could be opening the valve at the wrong time, also creating a vacuum leak. Unplug the egr vacuum hose, plug the open end of the hose and start it and see what it does. A picture of the egr is below.
Mar 11, 2017 | 1995 Chevrolet Tahoe
1999 Toyota Camry V6 idles rough and stalls after starting. No check engine lights and runs fine otherwise. Has only happened three times in the last two months. After keeping the idle up and running car...
yes it could be a fuel related problem, when was your last tune up, it could also be a spark issue, old or corroted spark plugs will sometimes not put out the correct amount of heat to ignite the gas correctly till it runs for a while, if the check engine light isnt lit, it will almost have to be something simular to this
Mar 19, 2010 | 1999 Toyota Camry
40hp 1987 yamaha outboard motor will run for 30-60
Sound like the fuel pump is not keeping up with the engine's demand. Check it out. Good luck. Hope this helps.
Apr 27, 2009 | Boating
Rough idle stalls at low rpm's
check your transmission fluid,the motor will stall when fluid is low
Dec 06, 2008 | 1996 Jeep Grand Cherokee
Rough idle
Have you had the throttle valve cleaned?
Here is the most common cause of surges and stalls, it is the idle speed control air-bypass valve and throttle valve, they get full of gunk over the miles and cause idle issues (stalls) like yours, Get a can of intake cleaner from any local parts store, not carb spray, intake cleaner, it is made by a company called CRC, remove the air intake hose to the engine, hold the idle high so the engine won't stall, then spray the can of cleaner into the intake while keeping the engine running, use at least 1/2 the can, shut down the engine and disconnect the battery for 5 minutes, then restart and complete a number of mixed driving cycles, town, freeway, stop and go etc., after a few days the problem will go away as the system will relearn to the clean intake.
Oct 20, 2008 | 2001 Mercury Sable
Boating Logo
167 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
