Hi, i have active speaker simbadda cst 5000. both channel work fine(satelite speaker) but the bass sound so bad/drop almost cannt hear it..
SOURCE: Klipsh Promedia 2.1
I was face the same problem 2 year's ago.This problem occur when you move the speaker's here and there.at that time speaker's wire diconnected in inside...please check the whole wire by electricians for where exactly it is disconnected...
Posted on Aug 25, 2007
  • 93 Answers
SOURCE: home theatre problems sound
Did you try to connect AUDIO OUT from your TV to AUDIO IN on your package?
Posted on Oct 04, 2007
  • 749 Answers
SOURCE: speaker problem
check for the connections! unplug and plug then back! test it! if it still have the same problem then it might be at the circuitry already! maybe some electronic components were busted or malfunctioned already!
if you happen to open it! check for bulged capacitors or loose connected components on the circuity!
Posted on Nov 15, 2007
CLUEPATEL
  • 138 Answers
SOURCE: Problem with sound
Its easy. Jus from task bar click on that Speaker Icon of sound. In that you can select the left channel, right channel or both! Keep the pointer in middle and you will get sound in both the channels! Enjoy
Posted on Jan 16, 2008
  • 132 Answers
SOURCE: popping sound from speaker when changing channels
This noise is normal with the cable box unless you set the cable box on HDMI sound
Posted on Feb 01, 2009
Hi i have recently purchased an rcf hc3200 and 4 x event 4000 speakers, these were all dommenstrated and shown to be working fine however when i connect 1 speaker to the amp (either channel) the sound...
Bass cancellation can occur if the polarity of one cable is reversed? Positive at the amp MUST go to the positive at the speakerS else one speaker will be pushing & the other pulling & the low frequencies get cancelled. You may also hear some strange imaging effects as you walk around the room - a bit like stereo from a mono setup.... check your cables :-)
Mar 23, 2017 | Rcf Hc 3200 Rcf Hc3200
Main Bass speaker not working!!
Hello Adam Hi, it looks like your main IC amplifier inside the main bass box is bad, need to replace that IC. What are your plans, do you want to do the repair or have it service by a tech guy.
May 06, 2010 | Bose Companion 3 Computer Speakers
Harman-Kardon HK695-01 Speakers Connection Quesion
According to the manual
http://tv.manualsonline.com/mdownloads/14ae515f-03bc-a2d4-8940-672bfa19f017.pdf
leave the black connector unconnected.
Hope that helps.
Oct 02, 2009 | Harman Kardon HK695 Computer Speakers
DVD plays partial sound
Check your speaker connections it sounds like you have a 5.1 or higher sound system. 5.1 means left front speaker, right front speaker, center speaker, right rear speaker, left rear speaker and subwoofer.
Voices in movies all get channeled to the center speaker (you can usually hear it a bit from the right and left front speakers as well). If your center speaker is disconnected or not working, you will only hear the background sounds.
Sep 20, 2008 | Compaq Presario 5000 PC Desktop
NAD C370 Right channel distortion
Sounds like you have lost the power amp transistor(s) or IC for this channel.
Aug 29, 2008 | NAD C370 2-Channel Amplifier
No output from Bose Lifestyle 12 system
Sounds like you have a problem in the circuits, which of course would take an experience technician to find and repair. But a 1994 electronic item has pretty much reached the end of its expected life cycle (sadly, compared to older equipment which is still working great). Basically, it sounds like the power amp circuit is shutting down a few seconds after startup. Might check to make sure no speakers or cables have shorts, which could activate a protection shutdown circuit. If any of the cubes don't hiss when you turn it on, that would be the first place to look for a problem.
Jul 01, 2008 | Bose Acoustimass 15 System
Yamaha rx 596 problem
ya bad ch unless u know how to work in ther best bet to buy new harmen kardon 7.1 or kenwood 7.1 thx on ebay 250 sound amizing clean warm like tube
Jan 20, 2008 | Audio Players & Recorders
Poping sound when channel is changing
hi, Jewtastik
well, is a generic problem to see ...but starting with your TV, hometheather, you should check if you have a lot bass on it, down a little the bass to see, and check if your sub is not bad.
I dunno know the brand nore the TV , so you should go and play a little with settings on sound fields on the hometheather.
good luck
Nov 18, 2007 | Durabrand 5.1 Surround Sound Computer...
Loss of Bass
Hi there, I would think that you have blown your bass drivers in the speakers. Sometime you may have a fuse which is blown in the speaker but this is not usual. Try on another speaker if you can.
Sep 25, 2007 | NAD C370 2-Channel Amplifier
Can i use small satelite speakers with my big front speakers?
Hi, I asume your setting up a home theater with five speakers a center left and right and rear surrounds don't know if you have a subwoofer. The large speakers in the front will work fine if you set the amp to large front speakers the bass will be sent to these. If you have a subwoofer set, the amp to small front speakers and the bass will be directed to it. Also try to get a center channel speaker that sounds somewhat like your large speakers.
Feb 14, 2007 | Yamaha AX-596 Amplifier
638 people viewed this question
 Grubhead
Grubhead
