Question about Tecumseh Garden
Took carb off tecumseh LEV100 3.8 hp push mower and cant get linkage back on. got a diagram?
rwvanlue
  • 486 Answers
SOURCE: looking for governor linkage set up took apart
cc4d3bd.jpg hmsk linkages
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Posted on Nov 22, 2009
Testimonial: "Just what I needed. Thanks"
rycgl
  • 1545 Answers
SOURCE: Bolens MTD push mower with B&S 4.5HP
This is probably not a blown gasket issue. A bad head gasket can allow oil to enter the cylinder head/combustion chamber if it's not sealing off the valve area. A simple suggestion is to check on the engine opposite the carb side for the oil/crankcase breather. It will have 2 screws holding it onto the block. It has a type of filter media in it that traps excessive oil and oil vapors from the engine. It is also connected by a tube to the air filter housing. When you tipped, you probably put too much oil in the breather and it was inducted over to the air filter/carb intake side.
Clean or replace the breather after checking it and also make sure you haven't overfilled the Briggs with oil and only use SAE 30 in the engine. Muti-viscosity isn't recommended in summer unless you run synthetic, then it is OK.
Please vote on this solution.
Posted on Sep 05, 2010
Testimonial: "Thank you - sounds like excellent advice and I'll sure let you know what I find."
SOURCE: carburetor linkages for riding lawn mower
Go to a tecumseh website and get a breakdown of the parts list and that should help a bit. Good luck.
Posted on Mar 26, 2009
  • 246 Answers
SOURCE: tecumseh engine #143.985510 - carb linkage hook-up
Hello:
The Carbuertor Throttle is Held in the Full Open Position Until the Engine is Started and Running, then the Governor and Spring Work together to Keep the Engine RPMs to the Desired Setting.
The Following is an Explaination on How the Governor System on Small Engines Function.
>>The Governor System behaves like an Unending Tug of War between One of Two Governor Springs, which Pull the Throttle Toward the Open Position, and a Spinning Crankshaft, which Tries to Close the Throttle. When the Load on the Engine Increases - a Typical Example is when you Move your Running Lawn Mower from the Driveway to the Grass - Crankshaft Revolutions Drop. But the Governor Spring is Still Tugging, Causing the Throttle Plate to Open. In Response, a Larger Volume of Air-Fuel Mixture Enters the Carburetor, Increasing Engine Speed to Compensate for the Increased Load. The Crankshaft Speeds Up, and the Tug of War Resumes, until a New Equilibrium is Achieved. With Each Change in Load, the Tension Between the Governor Spring and the Load Brings about a New Equilibrium, known as the Engine's Governed Speed. Neither Side Wins until the Engine is Shut Off. At that Point, without the Crankshaft Spinning, the Governor Spring Pulls the Throttle to the Wide-Open Position. Two Types of Governors are Common on Small Engines - Mechanical and Pneumatic.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 13, 2009
SOURCE: i have an MTD 3.5 hp Tecumseh lawn mower. The
WHAT KIND OF OIL DO I NEED FOR THE LAWN MOWER
Posted on May 14, 2010
Where can I get a diagram of carb choke and throttle linkage set up?
I bought a brand new 13 hp Tecumseh on my rider,was trouble from day one,fought it tooth and nail,finally took to shop,they put a brand new Taecumseh carb on it,couldn't get it to run,went to a dinky lawn mower shop,was told the carb was not the right one,wow,they sold me a used one that looked way different,but it worked super,so try another non-tecumseh carb or fight it forever.
Jun 07, 2015 | Garden
I cleaned my Toro Proline Carburetor and now I can NOT figure out how to re install the linkage. I need a diagram.
That sucks. I know. I'm guessing you have the standard Tecumseh set up that's on all the Toro's I work on (sideways carb setup). I've learned the hard way to take photos; I'll post the one I took. I apologize for the quality; the next one I do, I'll take a high res one but hope this helps ya out. I mean Toro Push Mowers. James
Aug 21, 2011 | Toro Garden
Tecumseh TVS90 43710M 3.5 HP enginge. I was
the rule of thumb applies to your certain problemif you carefully inspect the throttle plate you can view which hole it belongs in by visually looking for any wear or paint removal around the holes the one with wear of use will be obvious
Jul 30, 2010 | Garden
I have a 9hp Tecumseh engine on my Sears chipper vac. I rebuilt the carb and forgot how the governor and throttle linkage hooks up. Could you send me a diagram showing what holes these linkages go in? The...
I will try again here.
1 wire link from the top hole in the governor arm to the throttle on the carb. There should also be a wire link with a spring that goes from the Governor arm to the speed control handle.
Oct 21, 2009 | Craftsman 6.5 Hp Chipper Vac
Need instructions for reinstalling throttle linkage for tecumseh vantage mower 1990's vintage
You have to take the carb and exaust intake off (they should be attached anyways) so you can turn the carb at the right angle to reinstall the cable.
May 05, 2009 | Mtd 22" Yard Machine Push Mower
Garden Logo
3,038 people viewed this question
Top Tecumseh Garden Experts
Mike Squire
Jim Parker
Jim Parker
lnbn1975
Are you a Tecumseh Garden Expert? Answer questions, earn points and help others
