Loud humming noise while rca Mod hd50lpw166 is running
I replaced bulb about 6 mons ago and TV has been running great. Now when we turn on TV, a loud humming noise stays on al the time while powered on.  Any suggetions? TV is RCA Model hd50lpw166
  • 668 Answers
There is a excellent chance it is the Color Wheel in the Optical Block. Some of the older models are not too bad to replace it, on the newer one though it is a major tear down. I would have a RCA Servicer come out to verify and get a estimate. Chances are do to the cost of Optical Block, it would be close to replacement of the Set.
Hope this helps,
Skyassoc
Posted on Jun 29, 2009
What can be causing a loud humming noise from the bulb area of a Samsung DLP television after replacing the bulb?
is the tv still coming on, if not its the bulb is broke, do not touch the bulb it damages it
Dec 20, 2015 | Samsung Televison & Video
My daughter has a 2006 nissan sentra about 6 months ago she hit a curb with the front passenger side tire we replaced the tire rim but its making a loud humming noise any advise would be greatly...
That loud humming noise you are hearing is the wheel bearing. After hitting the curb the bearing took a hit and became a little wobbly and over time the grease has seeped out and started causing the humming.So just replace the wheel bearing and anything else that might be loose or damaged like the tie rod and ball joints. if those issues are not corrected it might happen again down the road. good luck and glad to shed some light on your issue
Aug 02, 2011 | 2006 Nissan Sentra
I have a issue with my rca scenium hd61lpw164yx1 tv ...i have replaced the bulb about a year ago. my screen started not coming on instantly it started fading in and eventually would not come on at all.i...
When the color wheel starts to go there is a high pitched whinning sound, the humming could be from the light engine or ballast, which may or may not be related to the color wheel. I would have to see it and test things for a correct diagnoses, but it does at least sound like a color wheel in the last moments of its life
Jul 16, 2011 | Televison & Video
50 inch rca dlp tv. new bulb. makes a loud
Color Wheel needs to be replaced. Call PartStore.com
1-866-925-7278 For Part number go to Encompass Parts Distribution they will list part number.
Apr 28, 2010 | RCA HDLP50W151 50" Rear Projection HDTV
Tv turns on w/pic then pic dissapears light blinks 4 times
I have the same issue, we've had to change our bulb three times in less than two years. now we have 61" expensive paper weight. Our current bulb is less than 6 months old. The TV is only 2 years old and like i said this is our third bulb.
the blue light blinks 4 times. you get sound. then a few minutes the the picture returns... then it goes out, and the cycle goes on.
A solution to this would be greatly appreciated.
Oct 08, 2009 | RCA HD61LPW165 61" Projection HDTV
Heard a loud
Sounds like it could be your power supply board. Same kind of issue i had. Try unplugging your tv completely for an hour.
Apr 15, 2009 | RCA HD50LPW175 50" HDTV
TV making loud humming noise
Sounds like u need a color wheel
Apr 06, 2009 | Televison & Video
Have maytag neptune model # mde4000ayw.its elect.mod. mades loud noise when turned on and drum is turning.
IF IT IS A LOUD DEEP HUM WHEN YOU FIRST TURN IT ON AND GOES AWAY AFTER IT IS RUNNING, THE MOTOR BEARINGS ARE WEARING OUT AND WILL FAIL IN THE NEAR FUTURE.
IF IT IS CONSTANT SQUEALING NOISE, THE IDLER PULLEY OR THE DRUM SUPPORT ROLLERS NEED REPLACED.
Apr 06, 2008 | Dryers
Televison & Video Logo
258 people viewed this question
Top Televison & Video Experts
