Cars & Trucks Logo
John Scott Posted on Jul 08, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I remove external door handles from a Holden Astra 2008?
Astra AH - I need to remove external door handles to do some panel Beati. I have removed trims, but do not know how to get the door handles off the outside panels. Can anyone help?
Stan Ford
Level 3:
Genius:
  • Holden Master 3,131 Answers
  • Posted on Oct 02, 2014
Stan Ford
Holden Master
Level 3:
Genius:
Answers
3131
Questions
Helped
904497
Points
9078
Screws behind remove door glass
5 Related Answers
A
Anonymous
  • Posted on Nov 04, 2008
SOURCE: Remove left front inside door panel
http://www.bodyshopzone.com/archives/trim/door_panels/Chevy/Equinox_2005/dp_front_rear.html
Anonymous
  • 253 Answers
  • Posted on May 05, 2009
SOURCE: driver door panel removal and re-connect door pull
You most likley have a damaged inside door handle. To remove the door panel, you must first remove the handle bezel. The trim piece around the handle. It is held in place by 4 retainer tabs, take a small flat screw driver, insert it between the bezel and handle. Gently pry away from the handle. If you look in the crack around the handle you will see the tabs. When you get that off, remove the switch assembly by prying up on it gently, unplug the wiring. There are 2 screws in the door panel where you pull the door shut, remove those also. Start at the bottom front of the door panel, pull outward firmly, but not violent. The retainers will come out, you will most likley break some, this is common. The inside handle is about $45 from your dealer. If it is the handle it is held in with 1 rivit, drill it out with a 3/16 drill. Replace the handle, reassemble. Good Luck.
emissionwiz
Marvin
  • 85242 Answers
  • Posted on Jun 01, 2009
SOURCE: how do i remove interior door panel & trim
Answer There is a small black plastic piece that surrounds your door handle. You MUST take that off, I find a small flat tip screw driver works best. The plastic cover that goes on the inside part of the door where your mirror is should be removed, makes it a lot easier to remove door trim: No screws on that part just grab from both sides and pull. 3 screws on bottom and 1 screw inside the armrest. The window crank, easiest way tried and true, shoestring, pull handle towards inside of car until you have enough room to fit the shoestring between crank and plastic washer. Give it a pull back and forth and it'll pop right off; clip should stick to shoestring as an added bonus.
Anonymous
  • Posted on Jul 28, 2009
SOURCE: 2009 Honda Odyssey Sliding door panel removal
Hidden screw underneath the power window switch, you have to remove, use a dull knife to gently pry up on the plastic molding, it should pop out with relative ease then you will see the screw.
Anonymous
  • 1986 Answers
  • Posted on Aug 14, 2009
SOURCE: Removal of door panel/trim
You'll need to remove screws that are by the door handle, arm rest, under door and side of door and then gently pull back on the panel as there will also be retaining clips attached and you don't want to break them. If needed, you can pull back the weather seal (can't reuse it, but it's not that important) and you will be able to access everything inside the door
Where is the fuel pump relay located on a 2006 cdx holden astra?
Hi not sure if your vehicle is an Astra G or an AH.
the Astra G relay should be in a covered box under bonnet.
There should be a longish round electrical connector in front of it.
Remove cover there should only 2 or 3 relay positions. It may be Violet in colour, if it has 2 relay positions I think its the front relay.
If it has three positions (it still may only have two relays fitted) it should be the one at the back.
Please be aware I am going by memory as I have not been involved with Astra's for some years.
The Astra AH, unfortunately I really don't remember.
Good luck
Need to install mp5 stereo to holden astra 2005 ah, need wiring components, as adaptor has been cut
Go to Repco, they sell adapter kits for nearly every Australian car to fit nearly every stereo.
2answers
2008 Holden Astra, I locked the doors with the central locking but the central locking won't open them again. The key will open the drivers door but not open the other 3 doors.
My 2007 astra central locking went crazy doors not locking some wouldn't unlock ,tail gate not latching, hole locking system not working, no indicator flashes when pushing remote, wires from body to door inside rubber boot were broken , very hard brittle plastic coating on wires where they need to bend n flex
NEED TO GET INTERIOR DRIVERS DOOR PANEL OFF FOR 2008 ASTRA SATURN
You need special tools to get the fasteners out of the door or you'll permanently damage the door panel. there are hidden screws on the arm rest and door latch handle. Let a mechanic with the tools do the job.
1helpful
How do I remove the external door handles of a Holden Astra AH 2007?
There are two studs on the backside of the outer handle, where it mounts on the door. They stick through holes in the door, and a nut on the inside holds it fast to the door.
First, or next, you have to release the plastic retainer clips on the rod(s) to the handle. Push the retainer clip off and away from the rod, and the rod should come out of the hole in the handle . Then you can remove the handle from the door.
How to chang fog light holden astra ah ?
unscrew lens. take out bulb?
some lens dont, come off, and at Rear is a socket you un twist.
all cars all lamps like this. just looking a moment this comes to mind.
ah no screws. whats behind here, ah,, ,there.
Astra aircon switch
1.remove the audio system.
2.remove cig lighter
3.remove lower compartment door and assembly under radio.
4.remove compartment under radio
5.then remove all necessary screws that hold the plastic panel on.
6.once all screws are removed and you can either lift the panel up enough or remove it total depending on you.then you will have easy access to the switchers..
1helpful
My wife has a holden astra TS 2002 and i'm trying to get the window winder off the door to remove the inside door skin
you will have to puchase a window handle removal tool from your local parts store. KD makes a good one but you wiil have to use this tool to remove a clip that holds the "winder " on.
Top Holden Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Holden Expert? Answer questions, earn points and help others
