Question about Xerox XA7-172i 17" LCD Monitor
Xerox xa7 19" lcd monitor
Whenever the computer or monitor are switched of on powering on the monitor again all i get is a brilliant white screen. i have to switch the monitor of about a dozen times before i get a picture. any suggestions??
the monitor is only 18 months old
  • Anonymous May 05, 2008
    I have the same issue
  • gamesue May 16, 2008
    have the same prob took back to pc world five days ago still waiting to here if it can be repaid or replaced let you know the out come as soon as i here anything
  • Xerox Master
  • 19,396 Answers
That means that you have a defective inverter board.
The inverter is a small power board that power up the LCD backlight lamp, determining light intensity, when it is like that, the inverter is defective and must be replaced.
Posted on Nov 27, 2008
Xerox lcd modle number 900p Power supply fault plz send pics of supply 1 ic burst i never know number
How-to Fix KDS K917s Model 900P LCD Computer Monitor ...
? 9:59
Jul 5, 2010 - Uploaded by X2YeZCAMCNC
How-to Fix KDS K917s Model 900P LCD Computer MonitorRepair Screen .... This screen has the exact ... Ac Dc Adapter Charger for Xerox Model 900 ... > ... > Monitors, Inc.... Model 900 Xl592ds Xg-90d Xl370b Xl-370b Lcd Monitor,xerox Xg-70d 17" Lcd ...Power Supply FOR Xerox model 900 XL592DS XG-90D XG-70D XG-71D ...
Nov 23, 2015 | Xerox Computers & Internet
When I power off my LCD monitor, the screen goes all white, but once I turn the monitor back on it goes right back to displaying whatever it should on the screen. Or when I shutdown the computer it also...
If this has happened to two monitors on the same computer, then i dont think the problem is with monitors, i think the problem is with the graphics on the computer, i suggest uninstalling the driver for the graphics card in device manager and then restart the pc to see if that makes any difference. The divice manager in in the properties of my computer icon, just right click and choose properties, then device manager.
Feb 06, 2010 | Sylvania L181 18.1" Flat Panel LCD Monitor
Xerox XA7
ccfl tube is destroyed or fuse on inverter board
Sep 01, 2008 | Xerox XA7-192i 19" LCD Monitor
My xerox lcd monitor is not working the power button is not lighting up
Computer Post / Beep codes The computer POST (Power On Self Test) tests the computer, insuring that it meets the necessary system requirements and that all hardware is working
POST troubleshooting steps. then this issue is not a NO POST but is an power related issue see document ... For users who are more comfortable working with the inside of their computer.
Good Luck, Please dont for get to Vote/Thank You.
Dec 22, 2007 | Xerox XG-91D 19" LCD Monitor
Blank screen for 15-20 minutes at startup
I have a Xerox XA7-19i. It has the same problem as described by many others - intermittent fault with the display that manifests as a white screen when the monitor is first switched on. After a few trys of switching on and off, the monitor works fine until left off for a few hours. Recently, the problem deteriorated to no light from the panel, and a flashing blue power light.
I opened up my monitor and removed the power supply board.
I de-soldered every electrolytic capacitor, and replaced them with new capacitors of the same uF and voltage rating.
I put the monitor back together again and switched it on - it worked perfectly!
Yes - these monitors have been built using sub-standard / under-rated electrolytic capacitors. After two years of use, the power supply board was unable to supply enough power to the logic board and backlight, causing the above-mentioned problems.
The repair cost me ~ GBP 15 (USD $30). It is not a difficult fix, but one only to be attempted if you have electronics knowledge. Careful, kids! you'd be playing with the power supply of a mains AC electronic device. That stuff can kill.
But - I saved myself (and the environment) from having to throw out a monitor and buy a new one. If you have a faulty xerox monitor and are getting no love from Xerox customer support, find an electronics geek and ask them to replace the electrolytic capacitors on the power supply board. (but be careful to get the right kind of capacitors, and to get the capacitor polarity correct. If you have any doubt as to you ability to do this, don't bother trying!).
Sep 02, 2007 | Xerox XG-91D 19" LCD Monitor
White screen on xerox xa7 19i
I had the same problem but fortunately I have two of these monitors so could fiddle with the menus on the working monitor until I could work out how to fix it on the one with the white screen problem. Here's what you do:-
With the monitor on and the white screen showing press MENU, then UP 7 times, then MENU and presto! Your screen will be back to normal.
What this does is change the input from ANALOG to DIGITAL (or vice versa!) either way this worked for me.
Apr 29, 2007 | Xerox XA7-192i 19" LCD Monitor
Screen goes blank also.
I too have an LCD Xerox - it worked fine for a while, then kept going blank and going onto standby. Unplugging and reconnecting from both pc and power seems to reset it. It hadn't happened for months but started again the other night when it occurred to me that I had just downloaded MS security updates - I've removed the ones that I downloaded just before it started happening again and the problem seems to be solved. Hope this helps someone.
Dec 19, 2006 | Xerox XG-91D 19" LCD Monitor
Lacie 19" Electron Blue - Black screen with a brilliant white line across
I have 2 of these monitors and have this problem. I was so frustrated turning the monitor off and on until the white line disappeared that one day, I punched the screen. And it worked! So now whenever this happens (about once every other day) I use my palm and smack the lower left corner of the monitor until the white line disappears. I like the color on these screens so I don't want to replace them until I have to. I will NOT buy another Lacie though.
Sep 13, 2006 | LaCie Electron 19" CRT Monitor
Xerox XA7-172i 17" LCD Monitor Logo
315 people viewed this question
Top Xerox Computers & Internet Experts
Jack McCann
Jack McCann
Are you a Xerox Computer and Internet Expert? Answer questions, earn points and help others
