Question about Frigidaire FMV145K Microwave Oven
Amana ZCO1860AS does not heat up food, turtable works and the lights
    Problem Solver:
  • 7 Answers
You gotta get a new fuse and take the button pannel off. it might be hard but keep pushin' ( with a flathead.) it'll snap back on. the fuse is behind that.
Posted on Jun 28, 2009
Is it safe to use an epoxy grout in my Amana RSW458P microwave oven? About an inch of the grout in the bottom back corner, where the bottom meets the side wall, has peeled away.
this must be an oldie cus im not in the knowlege of any microwaves that are sealed with grout , most all today are heat sealed using an ultrasonic weld that i know of
but i caution you using non food grade materials inside any oven, heat generated by cooking may leak out chemicals in sealers and "grout" that are not designed for food and poision the food inside id contact Amana directly and inquire about them selling you a tube of this sealer ?
Sep 09, 2014 | Amana Microwave Ovens
My microwave oven wont heat everything else works
maybe you have to adjust the temperature (if there's any) or the time you need to heat the food. or check for damage within the appliance
Apr 03, 2012 | Amana Microwave Ovens
Inline bus fuse continues to blow
The magnetron in the microwave oven is shorted, "heats food"
Mar 25, 2012 | Amana MVH230 Microwave Oven
Our commercial amana microwave model number rcs 10 mpa 1000 watt is not heating/cooking food. The power, lights, fans , display and everything else works fine. I would like to fix this myself. What part...
can be many problems. a defetive magnetron. worn door switches and its bracket/levers. circuit board issues. oven cavity thermofuse. etc.. good luck.
Aug 03, 2011 | Amana RCS10MP Microwave Oven
Will not heat or cook food
HI.usual problem if it does not heat food is the MAGNETRON.It is a filament that is responsible of producing heat.You have to open the bottom part of yuor oven and chec\k this filament if it is still working.You can check the continuity of the filament if it has.Using a MULTITESTER set it to OHMS value.Connect it to both ends of the filament and then check if pointers moved.If it means it does works but if its not either its defective.You need to replace it with a new one..Hope this helps..
Jul 13, 2011 | Amana ACO1860 Microwave Oven
Amana microwave - everything working but not heating food
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
[]\]\=0=0
Nov 26, 2010 | Amana ACO1860 Microwave Oven
Microwave works but doesn't heat food.
check if it heats through a different outlet by its self if not element is shot but if it works you need a better electrician unfortunately because you might have a new fire hazard with incorrect wiring but thats really only way to find out
May 07, 2017 | Amana MVH210W Microwave Oven
Amana microwave is loud and doesn't heat. Light
Magnetron went out causing a short-circuit of sorts. Replace magnetron.
Jun 29, 2009 | Amana MVH320 Microwave Oven
No heat
The most common causes are a bad door switch, a loose connection at the magnetron terminal, a bad magnetron, a bad high voltage diode, a bad connection on the control panel, or a bad relay on the control panel. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk Or call 877-477-7278 M-F 10am - 9pm Eastern time. If you're not interested in doing it yourself, you can find a local Amana / Maytag servicer here: http://www.maytag.com/support/service_parts.jsp
Aug 27, 2007 | Amana AMV1162 Microwave Oven
Frigidaire FMV145K Microwave Oven Logo
161 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
