Question about Teac HD10U5/KIT 5 GB IDE Hard Drive
I bought a new harddrive
I just want to use this 1 fresh but after trying to boot up windows it needs to be partiioned well did that 3 different drive letters its a 320 gig and i formated all 3 but when i try to install windows again it keeps telling me that the partition is not windows xp compatible what does that mean
  • 317 Answers
Did you format the drive with the NTFS file system?
Posted on Nov 07, 2007
A dark screen saying disk read error occurred
This could be the result of a couple different things: 1) the hard drive has crashed and is no longer able to boot into your operating system, 2) the system folder to your operating system has been corrupted and missing the files to allow it to boot up, 3) the connector between the hard drive and the motherboard has something wrong with it and isn't allowing your computer to recognize that the hard drive is there.
Jul 02, 2010 | Sony Vaio P VGN-P530H Netbook
My harddrive went down I have been able to recover the data with the spotmau program but can not get drive to boot--what can I do the dardrive is a maxtor with xp os
Spotmau is a great program and not only for recovery so It's a great choice! However I had the same problem with booting. (I'm using Windows XP as well)
Here is what I did and I hope it will help you: 1. You will need to get an extra harddrive. 2. Boot and install XP on the harddrive. 3. Have both drives installed on your CPU. 4. Using Spotmau copy the recovered data from one drive to the other. 5. Boot the drive in the traditional fashion (data will now be lost). 6. Copy the data. on the fresh drive.
Hope this helps, Traian
Apr 30, 2010 | Microsoft Windows XP Home Edition
I want to be able to Mirror or RAID-1 on 2 different drives, then break the mirror and mark the second drive as an active boot drive. After looking around online, I realize that this process is more...
I understand now, and appreciate your taking the time to clarify.
1.Make a backup disk of the current harddrives contents. This is a Restoration Disk.
Has the basic needed files for the Windows O/S, (Repair), but will also allow for a Full Installation.
2.Desktop, not laptop:
Install two harddrives, put them in a RAID1 configuration. Forget about the 'mirror' image program. Leave them both in there in case of a harddrive failure.
3.Laptop, not desktop:
A.There are some laptops that you press a key, or certain keys, when installing a new harddrive, when the old one has hardware issues, or viruses render it unusable. These key/s are pressed, BEFORE the old harddrive is removed. Allows replacement of that harddrive.
There are some laptops that Do Not! There is a workaround.
The above is to replace that harddrive, and may be used to upgrade to a larger harddrive, IF, certain criteria is met.
B.Use an external enclosure, insert the new 2.5" harddrive. Connect the external enclosure to the laptop via the USB port.
Now use an image 'mirror' program such as DriveImage XML, (Free), to copy over the image of the old harddrive to the new one.
Insert the new harddrive into the laptop. You can use the old harddrive in the external enclosure as a Slave drive.
Still only allows THOSE harddrives, to be used on THAT laptop.
Don't be surprised if you have to Re-Activate the O/S on that harddrive. (New one)
C.RAID configuration on a laptop = No
You only have one interface connection for a harddrive, Generally.
(Some gamer laptops use two hardrives internally. These are already configured in a RAID 0 configuration. More storage space. However, if one harddrive goes kaput, all information is lost. I do not believe you are referring to one of these)
The above is only for reference. I have no working knowledge of this program, just know of it's existence.
Sep 23, 2009 | Microsoft Windows XP Professional
I have a dell inspiron 1525 model..............yesterday i connect it to a net to find the keygen of some software so i turn off my antivirus so viruses were come and c drive gets badly harmed ,,,,,,,,now...
First thing you needs to install new windows via boot able CD.
Please do not start installing windows while running ur old windows. i mean please not upgrade ur windows to newer once.
Steps for installing fresh windows :
1. Make bootable win xp disk.
2. Insert Disk into drive and boot ur laptop with CD drive (If unable to boot then change BIOS settings)
3.Setup will automatically detect ur previous version of Windows.Just ignore it and start fresh installation and alll Done.
May 16, 2009 | Dell Inspiron 1525 Laptop Jet Black
Replaced harddrive and dvdroom wont recognize in bios
Goto bios menu. And change the setting on hard drive and cdrom. It could be it still set in the old configuration. Try to set it in auto detect. Then save the setting. Then goto bios once again to check if the settings doesn't change. Restart again and wait if something you didn't expect still happens.
Leave a comment if this solve cd rom detection.
May 12, 2009 | Gateway M-6750 Notebook
Computer keeps re-booting while installing any operating system
Were the two power supplies you tried inclusive of the original failed drive or not. In other words did you try a total a 3 power supplies including the one that failed?
If not, please do so. That is, immediately analyze the original known part failure, the power supply or its connection to the board(s) you have tried.
Congratulations for such an exhaustive process of elimination.
Apr 21, 2009 | Tyan Trinity S2090 Motherboard
I have a dell dimension4700, trying to replace the hard drive.
ata is a big flat cable whereas sata is a newer thin flat cable. it really depend on your motherboard and if it accepts them. if you could plug it in then it means that it accepts the connection. you can use any harddrive as long as it has the ata or sata connection and also if it can plug in to the mobo (motherboard).the windows insatllation may not be recognising the newer drive or the original one. make sure you have the jumper pins on your original drive set to master and the ones on the new drive set to slave. then as the pc boots up repeatadly tap the delete key and you will eventually go into dos. in dos go to peripherals or boot devices (different with some) , it may be called something else but find the boot sequence and set your cd drive to 1st boot device then your old harddrive to 2nd boot device then 3rd to your new drive. or if you have a floppy drive you can set that to first and then cd to second and master drive to third. if you want to only use the new harddrive then you will have to set it as master on the jumper pins and then 2nd boot device in dos after your cd drive and floppy drive. then you would have to do a fresh install of windows on the new drive and not use the restore disk.then you would have to transfer your files off your old drive which you would have to set as a slave drive on the jumper pins. if you do a fresh install of windows then you could download it. if you still have problems then write back. if you do get it to boot up it may not recognise the new drive, i would recommend checking the jumper pins on the harddrives and then reinstall windows. and format your new drive.
Apr 05, 2009 | Dell Dimension 4700 PC Desktop
Swaping hdd
You have half a dozen reasons why this will not work. The Operating system (XP) does not recognise the different hardware, the Bios doesn't recognise the MBR (the file structure of the harddrive) and you have all the wrong hardware drivers installed.
There is a way to do this if you have the original XP installation disk, install the harddrive, put the XP installation disk in the CD/DVD drive and set the machine to boot from the CD/DVD first. When the machine boots up and goes to install XP follow the instructions as if you are doing a fresh install, when SetUp attempts to format the harddrive it will discover you already have a version of XP installed and will give you the option to repair it, go ahead with the repair and MAYBE SetUp will be able to see and install the correct hardware drivers. If not you are looking at Slaving the harddrive, saving your personal files and then formatting the harddrive and reinstalling XP fresh.
Oct 31, 2008 | Dell OptiPlex GX110 PC Desktop
Xp pro repair/reinstall problem
check the connection of your hard disk, its properly conect or not
change the cd of windows and check it,
Sep 28, 2008 | Maxtor Hard Drive
What cable?
This message is displayed the motherboard attempts to preform a PXE boot. In otherwords, it is attempting to boot from the network.
This message is displayed under the following conditions:
1) No boot device (i.e. harddrive, cdrom) was detected. (Remember, even with a fresh harddrive you will get this message because the harddrive does not have an operating system tellling the BIOS it is bootable.)
2) The BIOS is configured to boot from LAN (PXE) before the hard disk drives.
To fix:
1) Power down your computer and check all power and data cables (ALSO JUMPER SETTINGS!) leading to the HDD, CD-ROMS, and other drives.
2) Hold down the key to access your BIOS while turning the computer on from a powerless state.
3) Change the boot order putting LAN (PXE) boot last: I would do CD, HDD, LAN.
4) Exit and save the changes.
Sep 19, 2008 | Intel Computers & Internet
Teac HD10U5/KIT 5 GB IDE Hard Drive Logo
82 people viewed this question
Top Teac Computers & Internet Experts
Starnley Johnwells
Starnley Johnwells
Computer Links
Are you a Teac Computer and Internet Expert? Answer questions, earn points and help others
