E1 appears and wont spin - Washing Machines
  • 82 Answers
Need the make and model please
Posted on Jun 28, 2009
What does E1 code indicate?
Your Air Conditioner Displays E1 (E2, or E3) In The Display ...
support-us.samsung.com/.../pop_troubleshooting_fr...
Samsung ElectronicsJul 8, 2010 - Home > Operation? > Your Air Conditioner Displays E1 (E2, or E3) In The Display Panel And Won't Turn On Share on Google+ Share on ...
How To Clear Sharp Air Conditioner E1 "Clean Filter" Error ...
sci.tech-archive.net > Archive > sci.electronics.repair > 2005-08
Aug 5, 2005 - Owners of Sharp air conditioner models ... the error code E1 will appear... following procedure to clear the nefarious E1 indication, and obtain
Oct 27, 2015 | Heating & Cooling
E1 flashing on my telman washing machine
I found my manuel. It means somethngs stuck in the pump or pipes
Dec 03, 2009 | Washing Machines
"E1" problem
I would request you to please check at both ends of the drain hose and confirm that you do nit have a leak. Also, please confirm that water is not leaking directly under the dishwasher.
If you are certain that you do not have a real leak, check the impeller (under the mesh filter in the sump area beneath the lower dish rack) is not damaged and is firmly in place.
The E1 error code is a Leakage Error, detected by the motor spinning faster than it should if the unit is filled with water.
Hope this helps resolve the issue.
God Bless
Jul 09, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
E1 code appears seems to be overheating
The "E1" error code means the thermistor is open and has to be replaced.
Jul 07, 2009 | Kenmore Dryers
I used the self cleaning oven and now it wont unlock and it keeps beeping f5, e1 what does this mean and how can i unlock the oven?
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.&URTGF
Mar 27, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Simplicity air conditioner
I had an e1 error, the fan was spinning but the compressor dosen't.  I don't know witch step i made fix the problem but try it.  I unplug the air conditioning for few minutes, unplug the control panel, get every things  back and it's work fine.I wish that can help youFrançois
Jul 10, 2008 | Kitchen Appliances - Others
Washing machine just keeps spinning
al indesit washer have a reset pattern
switch of with on/off button
turn selector to a large 'off dot' position
wait a couple of mins then switch back on
wait 2 mins
then switch off again and turn selector to a cycle start position
wait 2 mins turn back on and let it run the FULL cycle do not mess it about.
Sometimes it takes 2 or3 attempts so be patient
If there is a fault it will appear again within the cycle and give you an error code eg E7/E1 etc note this and call a repair man he will track it from this code.
Jan 22, 2008 | Indesit W 123 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
