I have a Dometic A/C model 59516.531, the compressor will not start. The unit was working last week and this week not. The 3 year parts warranty expired on May 9th 2009. I have tried a new start/run capacitor and still the compressor will not start. The unit has the Comfort Control Module and the fan runs in all modes, H,M,L, and Auto. Any assistance would be appreciated.
There are a few more things to try, in the control unit of the AC there is Cold Control/Freeze Switch. Take down the control unit (inside unit, remove inner shroud) and remove the cover, The freeze control is plugged into the blue plug on the board. Remove the plug and install a jumper wire in its place. Does the compressor come on? If so, you have a bad freeze control. If not, then we need to check and see if your AC power module is sending power to the Compressor. Check power across the relay in the control unit, Black to Blue. If the blue wire is hot, then you need to go upstairs to the top of the compressor and check the thermal overload. If the blue wire is not hot, the comfort control center may not be sending a signal to turn the compressor on. If it is not, do a reset of the CCC. For a five button system, turn the tstat off and hold down the Mode and Zone buttons simultaneously. While holding them down, turn the CCC on and hold the buttons until FF appears on the screen. Release the buttons and try the AC. Four button reset - Depress MODE switch to activate annunciator light. Simultaneously depress the bottom two buttons (temperature UP and DOWN) and hold. While holding these buttons down, depress the MODE button once and release. Release the two buttons previously held down. Depress the MODE button once again. At this time the light should extinguish, and the mode should register “OFF”. If not, repeat Steps 2 through 6. Retest system ensuring that all functions are present and operational.
Check your voltage to the unit. You may have the 24 volts for the t-stat but not the volts you need to start the comp. Sometimes ants can get in the contacts and will not allow the unit to energize.
9,200 btu Coleman AC in winnebego era cannot adequatly cool coach. Can I install a 13,500 btu...
(More)
9,200 btu Coleman AC in winnebego era cannot adequatly cool coach. Can I install a 13,500 btu without any modifcations to the electric
green light beeps 5 times,c5 error, any quick answer to fix this ?LG multi type room, 4 mths out of...
(More)
green light beeps 5 times,c5 error, any quick answer to fix this ?LG multi type room, 4 mths out of warranty!!
have a rockwood 2001 27X bumber pull - and need a replacement AC cover. first how much do these cost...
(More)
have a rockwood 2001 27X bumber pull - and need a replacement AC cover. first how much do these cost 2nd the trailer is on the deer lease - how much trouble is it to replace
we have central heating and airconditioning both using the floor duct but the airconditioning has...
(More)
we have central heating and airconditioning both using the floor duct but the airconditioning has not worked since we have moved into the house but the previous owners said it did had trademen to look at it with no results the house is over 30years old but i think they were installed in 1980+ name of the heater is a vulcan and aircon is carrier can you please advice on how to ge the aircon working
