Question about Samsung HL-P5063W 50" Rear Projection HDTV
Replaced lamp, tightened back plate, but lamp light still flashing and no picture.
  • 668 Answers
A Blinking Lamp LED is the most common failure indication. It can be caused by a bad lamp, a bad Ballast, Color Wheel not operating, Fans not turning, or even other defective Boards. I would suspect the Ballast or fan first though.
Hope this helps,
Skyassoc
Posted on Jun 29, 2009
How do I fix 62HM15 picture. Have sound-No Picture. Have red light steady and Green light blinks 8 times and cuts off and back on.
Usually 8 flashes means the lamp is not lighting.
When most lamps go bad , they physically crack because of excess heat.
The problem is probably the lamp or the ballast, which makes the voltage to light the lamp.
Replace lamp and remember to close the lamp access door after replacing, because the lamp will not light if the door is open an
Jan 23, 2015 | Toshiba 62HM15 62" Television
Lamp blew, picture went then sound also. Replaced lamp, now will not turn on. Red light flashing on front switch panel.
If the red light flashing 3 times the pause and again flashing 3 times, check and make sure lamp cover is installed correctly back on tv.
Sep 05, 2011 | Sony KS 50R200A Replacement Rear...
Replaced the lamp on Feb 5, 2011. Used the Tv throughout the week, next friday, no picture and green power light goes to flashing red lamp light
Remove the lamp.. and reinstall. MAKE sure you tighten the lamp door. IF the lamp door looks like it has been hot you need to replace lamp door. IF the door screw is not tight it will trip the lock out switch.
PLEASE LEAVE FEEDBACK
Feb 21, 2011 | Sony KDF-E55A20 55 in. LCD Television
I have replaced the TYLA-1000K lamp and housing, plugged the TV back in, turned TV on, pressed vol- & mute and nothing happens. The flashing green light comes on for about 3 to 4 seconds and then it...
amber is the colour...remove LAMP assembly...properly re-insert LAMP assembly back into TV...make sure it looks secure....close door and tighten screw.....door MUST be shut properly or TV will not operate correctly..it sounds too easy i understand TRY it you might be surprised!!!
May 19, 2010 | Televison & Video
THE TV PICTURE KEEPS GOING BLANK THEN COMES BACK ON ALL BY ITSELF. THERE IS A GREEN LIGHT FLASHING, NO RED LIGHT.
This is symptom of weak lamp in TV.
How old is this TV and did you replaced lamp recently?
If not, replace lamp in TV to fix this issue.
Lamp light does not lit solid if lamp is not broken or dead.
Lamp replacement procedure is easy and would written in user manual.
Thanks.
Jan 26, 2010 | Sony KDF-E50A10 50 in. LCD HDTV
Watching tv when the picture went black and now the green on light flashes for 30 times and turns off
A green flashing light for this model of TV indicates that the lamp cover is open on the TV.
  1. Unplug the power cable to the TV.
  2. Remove the 2 retaining screws on the lamp cover with a Phillips type screwdriver.
  3. Remove the lamp door completely from the TV.
  4. Remove the two retaining screws on the lamp case.
  5. Lift up the fixed wire handle of the lamp.
  6. Pull out the handle slowly and remove the lamp case.
  7. Insert the new lamp gently into the correct position. Make sure it is inserted correctly.
  8. Using a manual Phillips screwdriver (Do Not use an electric screwdiver), tighten the screws you removed in
    step 3.
  9. Replace the lamp cover and tighten the cover screws.
  10. Plug in the power cord and turn on the TV. After the initial warmup period (which may take up to several
    seconds for full picture brightness), the TV should operate normally.
If any of the following conditions exist, turn off the TV, unplug the power cord, and repeat steps 1–9 to ensure that the lamp unit and lamp unit
door are installed correctly:
  • The lamp indicator flashes green.
  • No picture
  • Dark picture
  • TV will not turn on
If, after repeating steps 1–10, the problem still exists, call Customer Service at 1-800-631-3811.
Source
Aug 31, 2009 | Toshiba 44NHM84 44" TV
My samsung dlp has no picture or sound. Model hls5066wx, power comes on lamp light flashes for 15sec and then the standby lamp comes on then it goes back to the lamp light flashing. It repeats this a few...
Chances are that the Interlock Safety Switch is not properly set. Remove the Lamp Door and then reinstall the door and tighten the screw. This will reset the Switch. If that does not fix the problem make sure that the Lamp is correctly seated. Beyond that you will need a trained samsung tech troubleshoot the set because it can be a bad Lamp Ballast,DMD bd,Main bd,Color Wheel. Also make sure you have the correct lamp. There is a Lamp Code sticker on the left side of the set. Match the code from the tv to the new lamp you purchased.
Jul 12, 2009 | Televison & Video
Sony wega 50 inch clicks and flashes 3 times and goes back onto s
If its model number is KF-50WE610, had you replaced its Lamp recently?
If Lamp is replaced, please check Lamp cover/ door that is not seated properly, make sure its fixed securely.
3 times light flashing shows Lamp cover error.
Jun 27, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
3 flashing red lights
3 times flash shows error in Lamp Cover. Please check lamp cover at back of tv and set it properly, if you removed it.
Let me know if
have query.
bye.
Sep 08, 2008 | Sony KDS-R50XBR1 50" HDTV
Hitachi model # 50V720
I have the same model and had the same problem after replacing the lamp. Turns out if the cover plate is not put back on properly, tv will not power on and lamp ligth comes on. To solve the problem all I had to do is tighten the cover plate screw. Hope this helps.
Nov 17, 2007 | Hitachi 50V720 Television
Samsung HL-P5063W 50" Rear Projection HDTV Logo
187 people viewed this question
Jerry Greenberg
Jerry Greenberg
