Question about Scotsman DCE33PA1BC 15in Built-in Automatic Ice Machine/Maker w/ Drain Pump, Black
Our Scotsman ice maker is making ice but is not
Our Scotsman ice maker is making ice but is not retaining the ice for long.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 102 Answers
Is the drain running clear is the condenser clean and are both spray nozzles in place?
Posted on Aug 06, 2009
The water pump is bad or the resovoir is not holding water
Posted on Aug 11, 2011
  • jim george Sep 14, 2011
    Just repaired one of these, check the amount of time it takes to make a FULL cube. should be about 30 minutes. Also should discharge all of the ice from shoot before water pump starts again. If you are having problem with both of these low freon is probably the answer.
    The timer is controlled by temperature. of the cube. Add a piercing access valve and add freon.
    Jim
Scottsman SCE170A-1B how can i have to make ice faster
The only way to make ice faster for this machine is done with cooler ambient room temperature and colder water temperature from supply water before it reaches water sump tray.
Jun 06, 2014 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Why won't Ice maker make ice?
Scotsman Prodigy - bad Ice thickness probe
May 10, 2014 | Prodigy Scotsman CU1526MA-1A Ice Maker...
Scotsman ice maker cme1356 remain on harvest
Check bin full sensors make sure that the wires are making good contact on the board and make sure they are working run your hand between them you should see the bin full light come on the board if not replace the bin full sensors. If the light comes on then replace the board.
May 25, 2012 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Scotsman dce33pa1bc not making ice
I will be here on Fixya or HERE if need. click here to download adobe acrobat just make sure you uncheck the Google toolbar download if not wanted. Many Answers are in this Service Manual and should you have questions please let me know, Thanks Sea Breeze
Scotsman DCE33PA1BC Service Manual
.PDF
If helpful please rate this solution..Thanks
Oct 19, 2011 | Scotsman DCE33PA1BC 15in Built-in...
Does not make ice power supply is good refrigeration light is blinking
Shawn,
Check you drain system, does the unit retain water inside the unit at the storage compartment? Normally the cooling system will not function if the unit can't empty all the water using and external drain system. Good Luck...
Jul 12, 2011 | Scotsman CSW45 15" Ice Maker with 26 lb....
My Scotsman is making ice but the level at which the bin retains ice is getting to be less and less. The drain is clear and the hose is connected. thoughts? TK
Clean condensor and evaporator. Check spray nozzles clear. If you can lower the room temp and it produces better then likely a dirty machine, low on charge or weak compressor.
Aug 01, 2010 | Scotsman DCE33PA1BC 15in Built-in...
Making and dropping ice, but not retaining ice...evidently melting...feels cold, but no accumulation. Is the white tube hanging down supposed to be connected to the drain line in the bottom?
yes to drain line. Clean the condensor and evaporator first. Check the spray jets to see it they are clogged. There is a screen on the inlet water valve as well. Check door seals and cabinet tight.
All else fails look for oil around the hot gas valve.
Jul 06, 2010 | Scotsman DCE33PA1BC 15in Built-in...
Brand new Scotsman DCE33 ice maker melts ice
Check that the condenser is clean, the plastic sheet is hanging over the opening and trhat both spray nozzles are in place.
Jun 19, 2009 | Scotsman DCE33PA1SC 15in Built-in...
Scotsman DCE33PA1BC 15in Built-in Automatic Ice Machine/Maker w/ Drain Pump, Black Logo
2,474 people viewed this question
Top Scotsman Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Tim Whalen
Are you a Scotsman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
