Question about Dryers
The dryer keeps burning up the thermal switches
  • 1 more comment
  • mnganske Jun 28, 2009
    I have all ready went through and cleaned out the exhaust tubing and i have pretty good airflow to the out side. It seems to run good for about two months then it burns up the switches.
    It is a Kenmore Elite with a model number of 110.65922401
  • craig thorne May 11, 2010
    need make and model please
  • 97 Answers
Hello Friend, Your solution is simple. It sounds like your dryer is working properly, and your actual problem is a blockage somewhere in your 4 inch exhaust tubing. Check it and make sure it is not clogged up with excessive lint. Also if your tubing is clear you need to check your connection where it travels thru the wall etc. It would be a good idea to find the actual location where it exits to the ouside and check for good airflow. If you have poor or no airflow this is why your thermal fuse has blown out. Poor venting of dryer causes overheating and therefore blowes the thermal fuse. I Hope I have helped you, Tim. And please don't forget to give me your rating for my help. Thanks.
Posted on Jun 28, 2009
Dryer spns but there is no heat
probally the heeting element
Mar 10, 2015 | Samsung Dryers
Ler4634eq0
Most commonly it's the white thermal fuse in the back of the dryer, but it could be any number of things including a door switch, burned wire, bad motor, bad timer, etc. Try the thermal fuse first. It's easiest and cheapest.
Mar 16, 2014 | Whirlpool LER4634J Electric Dryer
Thermal fuse keeps burning out
clean out the entire dryer inside and to the outside vent on the side of the house,this is a major problem in most thermal fuse burn-outs it has to get air or it will overheat
May 02, 2012 | Dryers
Brand new dryer keeps shutting off. not tripping my breakers I don';t understand
There is a thermal cutoff switch in all hairdryers. If you by accident block the air intake or the filter is dirty, then the heat from the nichrome wire is not sufficiently cooled to keep the thermal switch from tripping. After the dryer cools down then the thermal switch resets and allows operation. Be sure the air flow into the dryer is not obstructed
Mar 25, 2011 | Rusk W8less 2000 watt dryer
The dryer will not start but the timer is working
If your dryer's door switch is defective, it will not allow your dryer to start. Test your dryer's door switch. If it is defective, replace it.
Test your dryer's start switch. If it is defective, you will have to replace it for your dryer to start again.
A thermal fuse is a heat-sensitive fuse attached to your dryer's exhaust duct (in most models) that is designed to blow if the dryer overheats. A blown fuse would cause your dryer to not heat, or to not work at all. Open up your dryer's cabinet and locate its thermal fuse. Test the component. If it has blown, replace it.
A defective dryer thermostat could be what is preventing your dryer from starting. Open up your dryer's cabinet. Test each of your dryer's thermostats. Replace any that have become defective.
A burned out motor could be what is keeping your dryer from starting. Test your dryer's motor and if it is defective, replace it. You will have to open your dryer in order to gain access to its motor.
May 21, 2010 | Whirlpool LER4634J Electric Dryer
If the thermostat is sticking could it cause my thermal cut off to keep going bad
That could be the case also if you aren't getting the proper flow out of the dryer because of lint build up could also cause the problem. The thermal cut off switch is activated when the temprature at the coils reach a certain heat limit then the switch burns out.
Hope this helped
Dave
Feb 24, 2010 | Dryers
No heat in dryer model # 96591420
Check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Jul 31, 2009 | Kenmore Dryers
Whirlpool Gold Electric Dryer.
Hope your sitting down. There is not just heating elements in the dryer there are thermal switches that turn heating elements off & on like your house thermostat clicks off & on. Also there are overheating thermal switches to keep the elements from setting the dryer, clothes on fire. More than likely you overheating thermal switch has tripped, from lent in vent or pinched vent tube or normal failure. Some of these switches can be reset, others replaced. If you can not trouble shoot electrical circuits leave it to repairman. Switch $20.00 to $42.00 Labor service call cheaper to buy cheap new dryer. Could be heating element but most use only one with different inputs for heat. If your getting some heat not likely element.
Mar 08, 2009 | Dryers
Crosley dryer
Make a jumper across the open switch, see what happens, if it works replace the thermal switch, the jumper is ONLY USED FOR TESTING,keeping the jumper on WILL BURN UP UNIT!!!!!!!
Jan 26, 2009 | Crosley CDE6000 Electric Dryer
Thermal Fuse
First of all stop replacing the fuses and using the dryer it could burn down your house. The problem is the vent is clogged (not necessarily in the dryer) make sure also that the vent flex is not excessively long behind the dryer and is not kinked when the dryer is pushed back.
Nov 19, 2007 | Whirlpool LEN2000PW Dryer
Dryers Logo
116 people viewed this question
Top Dryers Experts
