Question about Flat Panel Televisions
Virgin media tv remote control
My volume + and - do not work on my remote my tv is by samsung and i have tried all codes from samsung but still it does not work my samsung remote works fine its just my virgin media remote that doesnt, please can you help
Re: virgin media tv remote control
What you have to do is ring virgin and ask then to send the code.
this code is done stight to your set top box
Posted on Feb 08, 2008
0 characters
3 Points
Virgin remote control code for volume on my 50" samsung plasma tv
To set up the volume control on your Telewest remote control, to be able to change the TV volume, please follow the instructions below.
1. Using the table below find your make of TV and the code which matches it.
2. Press and hold down Volume + and mute on your remote control at the same time for at least three seconds, until the green light in the top right-hand corner of your remote control flashes twice.
3. Release the buttons and enter the first four digit code from the table below. (You must do this within ten seconds).
4. As you enter the first three digits the green light on your remote control will give a short blink.
5. As you enter the fourth digit, the green light will flash twice to confirm that the volume is set.
If setting the volume is not successful, please repeat the above steps with the second or third codes from the table below.
Samsung 0065, 0584, 0037
Nov 18, 2011 | Samsung 50 in. Plasma TV
Will my virgin hd tv remot control be able to oporate the volume through its own amp or will i need to adust the volume with the toshiba tv remote on the tv itself
The easiest way is just to set the TV Volume with its own remote at the maximum level you'd want it and then use your Virgin remote to adjust the volume as and when required.
Jun 05, 2011 | Toshiba Flat Panel Televisions
I need a code list for my remote set top is for a panasonic viera 32inch lcd flat panel television.
Hello zaninc and welcome to FixYa. I'm not sure if you are referring to the codes for your cable box or your actual television so I have provided codes for both.
Panasonic Television Codes
0051, 0055, 0250
Panasonic Cable Box Codes
0000, 0107, 0021
Note if your remote control only accepts three digit codes you will have to take the first zero off of the codes that I have provided in order for them to work.
If these codes do not work for you please inform me of what make and model of set top box you own using the comments box and I will get right back to you. Thank you for using FixYa and good luck zadinc.
Apr 26, 2011 | Sagem Flat Panel Televisions
I have a Samsung 32 inch LCD tv that constantly changes channel on its own. I switched it on this morning and it was working fine then the volume went to max and I couldn't turn it down. I then switched it...
You say the remote doesn't work but it may well be the problem. Take the batteries out of the controller then try using the tv using the controls on the TV.
Dec 02, 2010 | Flat Panel Televisions
Virgin media remote control TV Control Codes Samsung LE37A558
just tried 0079 from another forum and it's worked for me!
Mar 11, 2009 | Flat Panel Televisions
Require tv code to use remote
For the V+ remote control (Virgin Media have a picture of it here - ) - the code is 0079.
To enter the code, hold down Volume+ and Mute on the V+ remote until it flashes red twice, then enter the code.
Jan 24, 2009 | Samsung LE37R72B 37 in. HD-Ready LCD...
Samsung le37a456c2d
For the V+ remote control (Virgin Media have a picture of it here - - the code is 0079.
Aug 02, 2008 | Flat Panel Televisions
LG 37LC2D TV Virgin Cable remote codes
I had the same problem with a LG42lf2500 I tried all codes that Virgin had listed none worked. I then started to program volume control stating at code 0001. 0007 worked for my LG TV LG42lf2500
Jan 08, 2008 | LG 37LC2D Television
Flat Panel Televisions Logo
829 people viewed this question
Top Flat Panel Televisions Experts
Are you a Flat Panel Television Expert? Answer questions, earn points and help others
