Question about Frigidaire PLMV169DC Microwave Oven
My Frigidaire PLMV 169 DCD has stopped working. The turn table rotates slowly, lights are lit but no cooking being done. The fan is off and no sound at all from within. What could have happened?
  • 6,784 Answers
HI, have the power sector tested. test the HV capacitor for its operational value. this may be the actual issue but, testing is needed to confirm. there is a running diode as well on the noise filter board. have it tested as well. replace both componets if found to be defective.
Posted on Jul 22, 2009
I have a frigadaire microwave model FMV156DS ... it just quit working. I thought it was the breaker tripping but it wasn't any clues?
Posted on Aug 08, 2009
My frigidare microwave model #FFMV162LB (about 5 years old) stopped working. I was cooking last night, and in the middle of it, the table stopped turning and the heat stopped. The timer still works and the...
After 5 years of service, there could have been a magnetron failure but the door interlock (latch) could have failed which would acccount for the turntable failure.
Feb 13, 2014 | Frigidaire FFMV162LB Microwave Oven
Frigidaire microwave doesn't work
Don't have a fix for your problem, but my Frigidaire microhood just did the exact same thing--about the same age, started cooking some food and it worked for a few minutes and then just stopped--time kept going, light stayed on, but turn table stopped and fan noise cut out. I tried it a few more times and it seemed to fade in and out and then stopped trying.
Nov 30, 2009 | Microwave Ovens
Microwave seems to run, but won't heat.
We have a similar problem! It sounds like a problem with the microswitch inside the unit that the door is suppose to engage when closed. If not engaged properly, it will not cook. We had the switch replaced last March but it has started acting up again. We can press in on the door and/or lift it slightly and it will cook. Try putting time on the counter and hit start. It the word "cook" appears then try moving the door slightly and see if the turntable starts turning. If not, then you may have a more serious problem. Good luck!
Oct 09, 2009 | Frigidaire FMV156DC Microwave Oven
My Frigidaire microwave stopped working while cooking food.
All lights are operational. Model number is FMV156DBC.
Aug 29, 2009 | Frigidaire FMV156DC Microwave Oven
Microwave door handle came off how do I take door apart frigidare model # plmv 169 dcd
The frame around the door can be gently pryed off and under there you will find the screws you need to remove to replace the handle.
Aug 03, 2009 | Microwave Ovens
Lights, fan,etc work but turntable does not rotate and oven does not cook.
Sounds like the table motor may have an issue. You might want to consult you local repair depot for an estimate. Sometimes the repairs are more than the appliance...beware!
May 25, 2009 | Goldstar MV-1501 Microwave Oven
Sharp Carousel R-530CW
Hi, I am not sure of the cost concerning the control board, however, it does sound like a control board problem, or a door switch problem, I would need to see the specific unit diagram to know for sure, but many microwaves, not all, but many, have a door switch related to that part of the circuit, usually the fuse would blow at that point, but there again, it depends on the circuit. I would suggest you get the unit checked soon however. Hope that helps somewhat, and thank you.
Jan 24, 2009 | Magic Chef MCB780W Microwave Oven
Frigidaire PLMV169DC Microwave Oven Logo
613 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
