Question about Brother XL-2230 Mechanical Sewing Machine
My macine is new and i cant fix the bobbin tension the stitches are very loose and the thread keeps getting caught. the upper tension is fine and the stitches look good. im about to loose my mind. thanks, denise. ps im only a novice sewer but really enjoy it,
  • 111 Answers
The problem is always on the other side of the fabric - if thread bunches up underneath, the top tension or threading is wrong
Posted on Jul 08, 2009
The top of the stitching is so loose, it can be pulled out with no effort. Have retreaded several times, used manual as guide. Tension is on 4, stitch length on 2.5 and stitch width on A.
Remove the upper thread. Install a brand new needle
RAISE the presser foot and rethread from the beginning--make sure the thread path is correct.
Set the upper tension at the midway point which is usually the factory standard. This is a beginning point. Every machine is different and may require some tweaking to get the stitch tension where you want it.
Make sure the bobbin is inserted in the bobbin case and turning the correct direction and the bobbin tension is threaded correctly.
Retest your machine.
If the bobbin thread is tight and still pulling the upper thread down, either tighten the upper tension slightly and retest. If it is still the case, then the bobbin tension probably needs to lightened up slightly.
The tension is correct when both threads meet in the middle of the fabric.
Sewing Lesson 10 How to Fix Tension on Your Sewing Machine
How to Adjust Sewing Machine Tension on Craftsy
Understanding Thread Tension Threads
Oct 15, 2016 | Sewing Machines
Top thread covers bobbin thread makes. Stitches very thick
Remove all the thread from the machine.
Install a brand new needle.
ALWAYS RAISE the presser foot during the threading process and rethread the machine from the beginning. (Check that the upper and bobbin threads are threaded correctly in your machine.)
Set the tension dial to the midway point. This is a factory standard setting but each machine may vary.
Test your machine. The ideal tension is when the upper and bobbin threads meet in the middle of the fabric. If the upper thread is showing on the bobbin side of the fabric, the upper tension is too loose. However, if the bobbin thread is showing on the top of the fabric, the upper tension is too tight.
Tension is not static--whenever you change projects, ie fabric, thread, needle, you may need to test the tension on some scrap project fabric first. Get the tension adjusted before stitching the project.
Make sure you clean and lubricate your machine regularly to keep it operating--consult your owner's manual and use only good quality sewing machine oil (NO 3-in-1, cooking oil, WD-40, or old brown stinky sewing machine oil).
If you are still having issues, take it for service.
May 27, 2016 | Sewing Machines
Why does the bottom tread come out loose and loopy
First, check the stitching to verify that it is in fact the bobbin thread that is loose & loopy. Usually, loopy thread under the fabric is the upper thread--which, if that is the case, is an indication it is either threaded incorrectly or the upper tension is too loose.
Make sure you are using a brand-new needle.
Always RAISE the presser foot and then thread the upper thread making sure that every guide and the correct path is followed.
Set the upper tension to the midway point between high & low number and re-test the stitching. Re-adjust as needed. The tension is correct when both upper and bobbin threads meet in the middle of the fabric.
If it is in fact the bobbin thread causing looping, it could be that the bobbin case is not threaded properly or the tension is way off.
Liz Kettle adjusting your bobbin case tension 1 wmv
Apr 11, 2016 | Sewing Machines
The tension on my Juki TL98E will not stay set. the top thread is really loose underneath, but if I tighten the top tension, it skipps stitches and the lower thread is not caught in the stitch.
Your top tension may actually be too tight! Try loosening it a bit instead. And check that the bobbin is correctly threaded and your needle in good condition.
Nov 25, 2015 | Juki Sewing Machines
The bottom thread is real loopy. I have adjusted the top tension and it helps a bit but still to loose
Remove all the thread from your machine. Install a brand new needle. Raise the presser foot and re-thread the upper thread, making sure you are following the correct threading sequence. Confirm that the bobbin thread is threaded through the bobbincase properly. Now, perform another test stitch. Is the bobbin thread still looping?
If you have already tightened the upper thread tension and the bobbin tension is still too loose, then you may need to tighten the bobbin tension. First, mark with a permanent marker where the slash of the screw head meets the bobbin case. This will mark where the screw was originally set before you begin making adjustments and allows you to return the screw to that position should you need to.
Set the upper tension to the halfway point between the high & low number. This is what would normally be the standard.
Then gently turn the bobbin tension screw to the right 1/8th of a turn at a time. Then test. Keep adjusting until the bobbin thread tension is correct. The tensions are correct when the upper thread and the bobbin thread meet in the middle of the fabric.
Nov 15, 2015 | Sewing Machines
How to fix bobbin thread on computered memorycraft 9000 sewing machine ?
1)Check that your bobbin does not have a nick in it where the thread can catch and won't feed smoothly.2) make sure the upper and bobbin threads are the same.3) pull out the bobbin case and chect to see if there is a clump of lint.4) make sure the feed dogs are moving the fabric through smoothly,some fabrics can get caught on the dogs and make the bottom thread get loopy.5) check your needle,if it's bent or has a bad tip,it can mess up the stitch.
Aug 15, 2014 | Janome Memory Craft 9000 Computerized...
How to adjust tension on lervia sewing machine
Tension is a balancing act between the upper tension and the bobbin tension. Balanced tension (which is not always necessary) is when the two threads meet between the layers of fabric. Not all unbalanced stitches are a tension problem. You can have loops under the fabric from a failed take up lever, improper clearance between the positioning finger or even a burr or lint. First I check the upper tension. If you can not make the upper tension normal pinching the thread after it comes off the spool will act as a tension device. If this solves your problem then start with cleaning.
You may have lint between the tension discs at the top next to the take up lever. Clean this out with the presser foot up. Next install a new needle size 80 and thread the machine. When you lower the presser foot and pull the thread the spring steel the needle is made of should bend 1/8 of an inch at normal tension. Between 3-5. If this does not happen turn to a larger number on the tension assembly. If this does not deflect the needle as you pull the thread to the left rear of the machine your tension assembly needs repair or replacement.
The bobbin tension is controlled by a spring on the bobbin case or bobbin basket (depends on the sewing machine). This spring can also get lint under it. The lint can hold the tension discs open causing no tension. This may be the problem if you see the lower thread pulling up to the top of the fabric. Normal tension on the lower thread is usually 150-200 grains. That may not mean much to you and you may not have a scale to measure that. One simple trick is to take a wooden clothes pin and glue 3 pennies to it. I then use this as a weight to set the bobbin tension. I clip the clothes pin to the thread and set it on the work bench. Next raise the bobbin case or bobbin basket without touching the thread or bobbin. Then tighten the tension screw on the bobbin case until the clothes pin lifts off the work bench.
This gives you a good place to start on balancing the tensions. Set up a straight stitch at the mid range of 2-3mm long and sew. Turn the upper tension dial to the mid range 3-5 and observe the stitch. If the bottom of the fabric shows too much top thread tighten the upper tension. If the top of the fabric shows too much lower thread loosen the upper tension. I recommend playing with your tensions to learn what too loose and too tight a tension look like. Sometimes we want the upper tension really loose to do a basting stitch. If you want to pucker (gather) you can create a long stitch and play with the tensions. A tight upper tension will pucker thin fabric. You can also gather fabric manually by using a long stitch and a loose upper tension then bunch the fabric together on the loose threads.
After all that it may be easier to take this to your local dealer and ask for advice.
Have a great day and keep on sewing.
Jun 22, 2014 | Sewing Machines
My bobbin wont engage with the stich. it just keeps getting jammed up. i lost the manuel i have no idea what to set the tension.
Try these solutions
* Un-thread your machine and remove your bobbin. Clean any loose thread or lint out of your
bobbin case. Re-thread your machine, reinsert and re-thread your bobbin.
* Change your bobbin. There could be a nick along the edge of your bobbin spool that’s catching your thread as you sew.
* When you start to sew a seam, Hold the upper and bobbin thread tails back and out of the way as you sew your first couple of stitches. This will keep them from getting caught in your machine.
I hope this helps.
Dec 24, 2009 | Sewing Machines
The bottom thread gets all knotted up when I sew... everything locks up and there is a mess of thread on the underside of what I'm trying to sew. help?
The tension in the top thread is controlled by a dial, and the tension in the bottom thread is controlled by a small screw on a spring on the bobbin. The tensions are supposed to be exactly equal in order to make the stitch perfectly in the middle of the cloth. Uneven tension will pull the stitch up or down from there. You can tug on each thread to feel how much tension there is. Often the bottom will get too much tension by just inserting the bobbin upside down. Leave the bobbin door open, and watch the operation. The top thread is pulled down around the bobbin. See if it is getting caught on anything?
Dec 18, 2009 | Singer 3116 Simple
Brother XL-2230 Mechanical Sewing Machine Logo
506 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
