Question about Kenmore Washing Machines
After machine stops spin cycle, tub does not stop spinning and there is a vibrating noise.
  • 15,935 Answers
It appears your clutch assembly has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!!!!!!!!!!!!
Posted on Sep 15, 2010
What causes my frigidaire top load washer to vibrate and make rattling noise during spin cycle
There are springs and bumpers/shocks in the machine that hold the tub. When they break or come loose, the tub wobbles.
Jan 03, 2016 | Frigidaire FAHE4044MW Affinity High...
At spin cycle, the tub spins out of its orbit hitting the sides, then it stops moving with an error on the screen. this is a maytag neptune 7AV6800AWW
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
Jul 10, 2011 | Maytag Neptune Washer
Near the end of the rinse cycle there was a load noise accompanied with a lot of vibration. I stopped it and took out the wet clothes and fininshed manually. To test i put the machne on spin cycle and...
if the clothes bunch up on one side the tub doesn't spin evenly and goes off balance,the tub will start banging all around,if this happens,open the lid and move the clothes around to even them out so all the wieght isn't on one side,it's a common thing mostly with a few items in the washer but can happen with any size load.if it keeps happening send the brand name and the model number.you should be fine.
Apr 17, 2011 | Washing Machines
On the spin cycle the machine is making a lot of noise. Could something be lose on worn to cause this. We have tried to stop the machine and reposition the load, but it did not help. The machine is just...
The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle.If the bearing is getting out of its way then its faulty weak motor causing this.Check out both the bearing and the motor. You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 31, 2010 | LG WD-3243RHD Front Load Washer / Dryer
Loud cliunking noise in beginning of spin then won't spin
get a flashlight and see if a foreign object has fallen down through one of the tub holes and is jamming the tub you have to look real close
Jan 11, 2008 | GE WJSE3110A Top Load Washer
Whirring noise on spin cycle
i have had this problem before you need to repace the tub bearing assembly which reqires special tools to do the job and the whole unit needs to be torn apart
Oct 19, 2007 | Maytag Performa PAV2200
Spin Cycle/Machine makes noise and moves
You can't tight up the tub. You should replace the damper pads that located beneath main support housing on base's machine. Goog luck !
Jan 15, 2007 | Crosley CAWC529JQ Top Load Washer
Washing Machines Logo
18 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
