Question about HP Compaq Presario V2000 Notebook
Compaq V2710us shuts down randomly with a loud click
Compaq V2710us shuts down randomly with a loud "click" OR screen goes blank and PC cannot be revived w/o holding down the power button til shuts down and then re-booted.
Not consistent in lenght of time between start and failure.
I have cleaned heatsink/fan [there was dust/dirt] replaced heat sink and used heat sink compound [silicon/zink oxide Radio Shack brand...any better to use?] [according to another post, I may have used too much...will try lesser amount].
Also replaced mother board.
HP/Compaq is recommending BIOS upgrade and then HDD check...but unit doesn't stay up long enough to do. "BIOS upgrade interuptus" doesn't sound like a good idea!
Thanx,
Ray
Still shuts down.
  • rhemsher Jun 30, 2009
    Thanx for the lead on this problem.
    I checked with my daughter (it's her baby!) and there was a recent addition of RAM! I will get the original RAM that came with the laptop and try that.
    However, there are soooo many reports of the same failure on this machine, I believe there is another hardware problem...just can't put my finger on it!
    Regarding scanning for trojans and viruses...do you have any recommendation on what package I might use?
    Thanx,
    Ray
  • Robert Nyilas
    Robert Nyilas May 11, 2010
    verify memory modules, and also be sure that your computer hasn't trojans or viruses
    Sergeant:
  • 400 Answers
Loud click sounds like either a short or overload, causing ground default. recheck inside for any loose connections anything grounding out the motherboard.
Posted on Jul 10, 2009
Random shut off. Sounds like a relay click.
Could be due to getting too hot! Do you have it clear from any walls and or other PC products? If so give it some room to breath!! I have had my New Asus gaming tower turn off on me due to it getting too warm.
Dec 22, 2013 | eMachines T5048 PC Desktop
Compaq Presario Laptop half screen issue
no photos of the screen presented.
so all i can do is guess what it looks like,
its so old HP has no info on it. legacy PC, called retired.
i guess 10 years old
2007
so one side is dead, black screen right?
and if you shine flash light on the black side, is there data there or not?????????????????
the v3000 is a CCLF back lamps (edge)
and last 20,000 hours max, (very very short life)
so when one side fails. it goes black
the bulb does or its inverter, supply does.
all do this everyone,
all go dim
then blink
then die, or are random starting.
just like a florecent light in say your garage, same deal. same gas tube.
use the flash light, see its not really BLANK IS IT
only the black lamp quit.
endless post here on topic,
in the year 2010 most of these ended and are now all LED
ending all this pain.
Sep 20, 2017 | HP 435768-001 - Compaq Presario C300...
Laptop screen goes blank randomly
Hi you can try this in Vista
  1. Click Start, and then type cmd in the Start Search box.
  2. In the search results list, right-click Command Prompt or Cmd, and then click Run as Administrator on the pop up contextual menu.
  3. If you are prompted by User Account Control for permission, click Continue.
  4. At the command prompt, type the following command, and then press ENTER: powercfg.exe -h off
  5. Type exit, and then press ENTER.
Windows Xp;
Click Start, click Control Panel, click Performance and Maintenance, and then click Power Options. click the Hibernate tab and unckeck the box and turnoff monitor should be never
Sep 16, 2009 | Acer TravelMate 5520 Notebook
V2000 (2710US) shutting down randomly
try to use other hard disk. if it works on your machine then your OS is corrupted. You might need to reformat your hard disk.
Before reformatting your hard drive safe all the files first because everything will be deleted.
Jul 01, 2009 | HP Compaq Presario V2000 Notebook
My compac boots up ok but when im using the pc one of the web pages goes blank(white) and acts as a screen saver. cover the entire screen. covering all icons and margins. just a white screen..even when i...
i have the same problem,also bought new hp for grandson and it to has problem, tried hp help did no good, only cure i found is to hit desk button on keyboard and programs open and on the task bar it will show windows blank page and you can double click and close blank page. hope this helps. robert
Jun 27, 2009 | Compaq Computers & Internet
Random Blank screen at startup. All lights runed on.
shut it down properly from the command line or/and keep power button pressed for 5 sec's or so
Jun 23, 2009 | ASUS Eee PC 901 XP Notebook
Plasma tv makes loud static noise screen goes blank and shuts off
Take the back off and try to isolate where the sound is coming from.
Nov 24, 2017 | Philips 42PF7320A 42 in. Plasma HDTV
Hp dv5 laptop screen randomly goes blank.
Check your power management settings. Reset to suit your usage. This should fix it.
Mar 16, 2009 | HP Pavilion dv5000t Notebook
COMPAQ CQ60-104Tu goes blank... improper shutdown
It might be a problem with the computer. I would advise going back to where you bought it and returning it to either get a new one or a different one. Glad I Helped!
Jan 28, 2009 | Compaq Presario Notebook
HP Compaq Presario V2000 Notebook Logo
134 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
