Question about Frigidaire ATF6000ES Front Load Washer
Fridgidaire front loader wont go thru spin cycle
It goes thru all wash and rinse cycles and drains just fine. It just wont spin at all. It gets about 4 minutes into spin cycle and then the machine just shuts off.
  • stormkingbuc Jul 16, 2009
    It was actually the wax motor in the door switch.
    Genius:
  • 1,036 Answers
This sounds like it is either part of the motor that is burnt out, or a fault on the control board that controls the fast spin speed.
The motors have a number of coils, so a fault with one will cause problems at just one speed.
The power transistors on the control board can also fail - leaving one speed dead, so either of these faults may be the reason yours is not working.
#1 - Check all motor coils
#2 - Check operation of output Power transistors.
Above tests should be performed by competent engineer only.
There is also another fault concerned with an unballanced load - If it spins a few times and bounces a lot, then it will abort the spin cycle. This is usually the fault of the dampers - which are a cheap replacement.
Posted on Jun 28, 2009
  • Richard Perkins
    Richard Perkins Aug 07, 2009
    If it was just that, then the machine should not start at all with the door open ?
    Sorry - I would have expected a motor issue.
    Glad you have it sorted now.
The cleaning cycle wont work.
Did you tried with different load?
It could be the control panel which is not to cheap.
Mar 09, 2013 | Whirlpool GHW9150 Front Load Washer
Washer wont drain. fills with water. goes through wash cycle but wont drain. once it gets to the spin cycle, it spins for a few seconds and then stops and rinse light comes back on.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 21, 2011 | GE Washing Machines
Washing machine won't spin and drain
the drain pump is not working,after wash cycle the washer should drain the used water,if it does not function-all the next cycle will not commence.
Mar 19, 2010 | Washing Machines
Front loader won't spin, but it washes fine, drains fine
CHECK THE MOTOR. IF MOTOR GOOD, REPLACE MOTOR CONTROL BOARD.
BOYNISMO@YAHOO.COM OR 714-334-1998
Nov 27, 2009 | Frigidaire Washing Machines
Washer won't drain.
My washer fills up with water and goes thru the wash cycle but when it's time to drain, it just sits there and clicks.
Oct 17, 2009 | Tecnik TKL9260 Front Load Washer
My fridgidaire frontloader wont do a spin cycle
A lot of times it is the strainer clogged at the pump. That has happened to mine. Hope that helps.
Sep 06, 2009 | Frigidaire Affinity ATF7000E Front Load...
LG WD-8013F wont spin
Hi deppgirl,
I checked the lint filter at the front bottom left hand side and it was full of junk.  Once emptied it worked a treat.  Pull the flap down and turn the large knob anti-clockwise and pull to remove.  Good luck.
Mar 29, 2008 | Washing Machines
LTF2140E Front loader washer
My Frigidaire front loader washer model LTF2140E doesnt want to drain the water when set to wash (heavy-normal-quick selectors). It washes put thats it. I have to switch the selector to drain/spin then rinse/spin cycle to finish the load. I checked the drain hose for any clogs....everything is clear. Any suggestions? Also,iIs2.gif their any reset buttons for this type of washer?
Dec 13, 2007 | Frigidaire 24 in. FDB510LC Free-standing...
Frigidaire ATF6000ES Front Load Washer Logo
627 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
