Question about Hamilton Beach 950 Stand Mixer
Motor does not run need to replace
Would like to know where to purchase it
    President:
  • 3,433 Answers
Braun Coffee Grinder Mill Part - theEssentials.com Shop theEssentials.com for a wide variety of
Posted on Jul 14, 2009
My Hamilton Beach model 63220 mixer won't mix motor is running but mixer is frozen and will not turn
If mixer is locked in down position, and you hear motor running, the problem could be worn gears in mixer head. Check warranty and return to place of purchase or take to small appliance repair shop for estimate.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Apr 20, 2016 | Hamilton Beach Food Mixers
Motor replacement
The motor is not a single part, you test the components and purchase only those that are faulty. You will need to dismantle the unit to test everything but you should be doing your checking with your eyes and a meter as you strip it down. You may locate the fault before it turns into a major repair.
Sep 25, 2014 | KitchenAid K45SS Classic Stand Mixer
Why My Hobart A200 20 QT Mixer ML #104858 Motor Is Smoking?
I think... without knowing that motor... that the capacitor is a start capacitor, and that the start switch may be trying to "start" the motor full-time instead of switching it out of circuit after it figures that the motor has spun up. I may be wrong - that design may be a capacitor-run motor (similar to a three-phase motor) - but I'm betting it's a start-only capacitor.
If you know someone with a capacitance meter, you could check the capacitor - for both capacitance (to be sure it matches the label) and leakage. Easy way to write that one off. Alternatively, you could rig it such that after the motor's wound up you could manually disconnect the capacitor and see what happens - either the motor stops or else the smoking issue stops.
Whatever you do, don't let it smoke very long. The varnish on the windings is only so thick.
Jul 31, 2014 | Hobart A200 Stand Mixer
Kitchenaid kp26m1xer won't turn on
If the mixer died completely and no noise at all comes from the machine you need one of three things.
1. New brushes2. new speed control switch3. a new motor.
The KP26 is a 6 quart mixer of the new design, post 2002, it is easy to work on and relatively inexpensive for parts if it turns out to be the motor that will be about $100.00, the speed control about 30.00, the brushes on this mixer cannot be replaced you have to install a new motor, sry about that. Hope this helps let us know. But first check that the electric outlet you are working from has not tripped the breaker on the circuit too. I know I know it's silly to say but check the outlet first before you spend a dime on anything.
Mar 11, 2013 | KitchenAid 32685 Mixer
Won't turn on
Get a copy of the Repair Part List for your model at Kitchenaid.com
On each side of the Motor Housing(1) is the large black Brush Motor
Cap(23). Each Carbon Brush(19) is keyed (one corner is not square)
and is designed to go into the Motor Housing slot but only one way.
Each Carbon Brush must make contact with the Motor Coils. The
motor will not turn if one or both does not come in contact with the coils.
If the brushes are too worn out, of course they won't touch the coils
neither and your motor will not run. You can purchased new brushes
on Ebay if they need to be replaced.
Jul 15, 2011 | KitchenAid Artisan KSM150PSAQ Stand Mixer
I have a sunbeam mixmaster from an Aunt that is at least 30 years old and it recently just stopped working. I assume that the motor is blown. Is it possible or worth it to fix it ?
If the motor is blown it will most likely cost more to repair or replace the motor than buying a new mixer. However, It could be a break in the electrical cord or at the plug. Is there a 'burnt' smell in the mixer? If not, have the electrical cord checked by someone in the know before purchasing a new mixer.
Please don't hesitate to ask me should you need any more info.
Best wishes,
Graeme.
Nov 30, 2010 | Sunbeam Food Mixers
Hobart Mixer A200 buzzing. The motor not moving
Have you try to run the motor without engaing of worm gears? The worm gear 15T assembly need to remove in order for motor to run freely. check worm gear attach to motor shaft for any damaging.
Mar 24, 2010 | Hobart A200 Stand Mixer
Smoking Kenwood Chef A901
I have just had the exact sme problem.
It is caused by a 1 watt resistor on the board.
You will also find that very possibly the large capacitor, a 0.1uF, has aso burnt out. This capacitor would have cracked open down the side and that is where the smoke came from.
parts can be replaced by a repair man and possibly a better solution is to have the board replaced, They are availiable still.
Apr 02, 2008 | Kenwood KM800 Major Classic Stand Mixer
Converrt USA electronic to european electronics
I have the same mixer and I moved from the States to the UK.  I just bought a really good power step-down converter (has to be step-down rather than a standard adapter, and watch the wattage of the adapter).  It worked fine.
Jan 15, 2008 | KitchenAid KSM50PR Professional Series...
Motor runs paddle does not move, oil from attachment port
I think this link will help you understand what is needed to fix your mixer.
You will need to purchase a gear. Here is link MarBeck should have it.
You may need to replace some grease. Make sure to use a non-toxic food grade grease.
Dec 14, 2007 | KitchenAid K5SS Heavy Duty Commercial...
Hamilton Beach 950 Stand Mixer Logo
85 people viewed this question
Top Hamilton Beach Food Mixers Experts
Andrew Taylor
Andrew Taylor
Ruth summersides
Are you a Hamilton Beach Food Mixer Expert? Answer questions, earn points and help others
