Question about HP LaserJet 3050 All-In-One Printer
SCANNING ISSUE I have printer HP Laser Jet 3050. I would like to scan, but the scanner is not working, not set up on PC. I need help to set up scanner so I can save on my pc. Abdul Halani
    Novelist:
  • 102 Answers
You need to install the complete software from HP Website or use the link belows:
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=1140783&prodNameId=1140778&swEnvOID=2093&swLang=8&mode=2&taskId=135&swItem=ma-38114-4
After downloading and installing the complete software you need to set-up scanner.
Using steps and i m sure your issue will be resolved.
To program the Scan To button:
Select Start/Programs or All Programs (Windows XP)/HP/HP Laserjet 3050, 3052, 3055, 3390, 3392/Scan
Click the Setup to open the Scan To Setup Wizard.
Select the Change the destinations that show up on the all-in-one control panel when I press the <Scan To> button and then click Next .
Check the Allow me to scan by pressing the Scan To button on the all-in-one check box.
Choose the destination by moving them from the PC window (the left window) to the All-in-one window (the right window).
NOTE: The All-in-one window might contain items set up by other computers that are connected to the all-in-one. You cannot make changes to these items.
Click Update .
To Create a destinations:
Follow steps 1-2 from the above steps.
Select Create a new destination with settings that I will specify and then select Next .
Select the Save it to my computer and then press Next .
Select the scan preferences and then select Next .
Select the scan destination folder and file format type and then select Next .
NOTE: If you wish to use a custom folder for your scan destination, you will need to create the folder prior to this setup wizard in order to browse to it.
Select the quality level you would like the file to be saved as.
Name the new destination on the computer, check the Send this new destination to the all-in-one check box, and enter a name for the display on the all-in-one. Then select Next .
Confirmation allows you to verify your settings. Select Save .
Once the new destination has been saved, the new destination will be configured as one of the Scan To destinations on the printer.
Posted on Jul 02, 2009
Color laser jet 2840 is not scanning. It says: pc not set up. I have the connections in properly from my lap top to my laser jet. What is the problem
I had a similiar problem and was using Windows Vista which was not compatible with the XP Installation package. The onboard drivers would not work either. Check to see if your printer is compatible with your version of windows.
Sep 16, 2011 | HP LaserJet 3050 All-In-One Printer
How to scan a photo using hp 3050 laser jet
I'm running Windows7.
I click the start button.
I click All Programs
I look for and click Windows Fax and Scan
A window opens that is called Fax and Scan
I select new scan at the top. The PC connects with the scanner
Another window opens, and I select my printer scanner
And then I click Scan
This the easiest way that I have found to scan from my AIO
Jan 17, 2011 | HP LaserJet 3050 All-In-One Printer
HP Laser Jet 3055 is showing scanner error 6 and Comm. error 386, 232, & 388
This is due to a hardware failure, the scanner assembly and the formatter board will need to be replaced.
NVRAM INIT
1. Turn off the all-in-one
2. Press and hold down the * and enter buttons.
3. Continue to hold down the buttons while you turn on the all-in-one. Hold the buttons throughout the entire power-on sequence.
4. When Permanent Storage Init. appears on the control-panel display, release the buttons.
5. Allow the all-in-one to return to Ready before using it. storage init. appears, and then release the buttons.
if this does not work contact hp 1800-334-5144.
Al
Eliteprintersolutions@gmail.com
Jun 14, 2010 | Office Equipment & Supplies
Hp 3050 laser jet printer the fax page is black
The scanner in your FAX is nothing working -- i.e., "100%-black" or "100%-white", and so what is transmitted is what the scanner has scanned, improperly.
Dec 13, 2009 | HP LaserJet 3050 All-In-One Printer
Hi i have a problem..i want to scan 60 pages and i have the hp laser jet 3050.i scan the first page and then it shows a message to the screen of pc ''would you like to scan another page?'' and i have to go...
Rena,
Put ALLof the pages into the sheetfeeder all at once.
The scanner will automatically scan all pages.
The sheetfeeder may only accept 30 pages, so you may have to do two scan jobs.
-Gort.
Oct 22, 2009 | HP LaserJet 3050 All-In-One Printer
Scanned pictures are black and white
if the unit makes color copies correctly, the scanner is working correctly, the application you are scanning to sets the size, resolution, color/b&w, etc. you will need to enter into the application and set it for color.
if u have any ?'s let us know, we will Fix Ya.
clarkco
Feb 06, 2009 | HP LaserJet 3050 All-In-One Printer
HP3050 scan to pdf can't be opened
agalier is not alone. I have exactly the same issue with my HP LaserJet 3050 and pdf files. Once file is opened on PC than did the scanning and saved with a different name, voila the new file can be accessed without problem by another PC on the network. Bizzare!
Jul 30, 2008 | HP LaserJet 3050 All-In-One Printer
Scanning with Laserjet 3050 on IMAC with leopard
Correct me if I am wrong but doesn't this printer come with mac drivers? But I am not supprised to head that HP is alienating you. They do the same for Linux users. Although there is a growing base of support coming from HP. Maybe you should switch to Linux.
Jan 10, 2008 | HP LaserJet 3050 All-In-One Printer
HP LASERJET 3050 SCANNER: ERROR (not set up on pc).
Shirley,
If your still looking for a solution, or to those of you who have a similar problem, the following fixed my problem after trying to resolve the issue over the last year!!!!
I also received the "not set up on pc" message and tried re-installing the software numerous times.
Finally resorted to re-installing windows XP (because of this and other software glitches) and re-installed the Laserjet 3050 software again...but could not get the printer to install.
The problem was occuring while the software was asking to "plug in the usb cable", but would not complete the installation. It was not recognizing the device....the solution was to reset the laserjet 3050!!!!
to reset, push the "menu" button, < (left arrow), go to "service", "enter" button, > (right arrow), "Restore Defaults", "enter" button.
This should reset the factory defaults.
After this, I re-installed software, working!!!!!
Puas
Dec 14, 2007 | HP LaserJet 3050 All-In-One Printer
HP LaserJet 3050 All-In-One Printer Logo
691 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
