Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Wd 73737 hdmi - Mitsubishi WD-52525 52" Rear Projection HDTV
2 Suggested Answers
SOURCE:
SD Tech
  • 14553 Answers
SOURCE: Mitsubishi WD- 73737 73 in. Screen if dim or dark. Changed contrast, brightness, and restored default settings but that didn't work. Help?
I am not sure about your model but a call to Mitsubishi to ask if the set has one or two mirrors would offer a possible explanation---the ones with two mirrors have a small one at the bottom--it gets coated with dust and brightness drops up to 75 percent----other possible reason is the lamp may be nearing the end of its life.
I would have Mitsubishi look to see if this model uses the two mirrors--if that is the case cleaning will cure this--if you find it has two mirrors I can tell you what is involved--on Vacation but do look here--let me know what you find.
Posted on Jun 26, 2012
Can all hdmi inputs go bad
Short answer would be yes. They are all on the same board.
Aug 30, 2014 | Mitsubishi WD-73737 73 in. HD-Ready TV
Error code 61 on WD 73737
Retired tech says, may be one of the fuses/resistor/transistor in unit blew out. reset won't work
Aug 28, 2012 | Mitsubishi WD-73737 73 in. HD-Ready TV
I have a Mitsubishi DLP WD-73737 65
What is the problem you faces with this set? Provide more details please.
Jul 16, 2012 | Mitsubishi WD-73737 73 in. HD-Ready TV
I have a Mitsubishi WD-73737 73-Inch, the picture format keeps changing automatically. for example, the format will be set at 720i wide and it switches back and forth to 720i normal. any ideas?
I've seen that happen on equipment that has automatic signal detection. Usually this option is available when connecting the equipment with an hdmi cable. The setting can either be on the television or the cable/sat box or both. You have to disable the automatic signal detection signal on both the television (if the television has one in the setup hdmi menu if there is one) and on the cable/sat box. Further you have to choose a resolution on the cable/sat box normally 1080i or 720p fixed. Disable the 4:3 override if there is one. Save and lock in the settings and you should be all set.
May 07, 2011 | Mitsubishi WD-73737 73 in. HD-Ready TV
The power light blinks and the welcome screen comes on for 20 seconds and it shuts off Model WD-73737
mine did this on jan 1st also... called mitsu and they sent me an e mail with an update to download and install for the tv.... 2 days later mines all fixed
Jan 01, 2011 | Mitsubishi WD-73737 73 in. HD-Ready TV
Wd73737 blinking green power light
my tv keeps turning off i have a mitsubishi wd-73737 what can i do to fix it?
Jul 12, 2010 | Mitsubishi WD-73737 73 in. HD-Ready TV
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
