It does not spin
My washwer sometimes does not spin at the end of the cycle.
  • 508 Answers
Clutch going bad!!
Posted on Jun 28, 2009
Washer will fill with water and then pops the circuit breaker
see the causes:
t doesn't pump or spin
frozen puller+ belt broken replace
It pumps, but doesn't spin
lid swithc broker or open,motor coupler broken,belt broken, and clutch worn,drive motor defective,transmision not shifting properly,basket driven worn.
It spins only with the lid closed lid switch prevent the action to start.
see the diagram
Jun 19, 2012 | Washing Machines
My Kenmore washwer does not spin. belt seems loose
unless your washer is older than 1985 it has a motor coupling which is broken and no belt
Jul 18, 2011 | Kenmore Washing Machines
At the end of the cycle prior to spinning the washer sometimes doesn,t start to spin, it just makes sounds like it,s trying to spin but won,t catch. If I open and close the lid it begins it,s proper cycle....
The timer is not allowing a cycle stop for the neutral pack to drop. Replace the timer and you should be in good shape. The whistling sound is likely something in the pump.
Kelly
Mar 21, 2011 | Whirlpool Washing Machines
Sometimes it does not finish the cycle and stops before spinning. Is there a way to continue with just the spin cycle without going through an entire cycle?
Place the timer toward the end of the cycle. If the pressure switch is working - it will drain before spinning out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 08, 2009 | Kenmore Washing Machines
Kenmore 80 series washer wont spin
do you hear a clicking noise when you close the lid if not check the lid switch if so then check the coupler it is the plastic and rubber piece in between the motor and the transmission
Dec 29, 2008 | Kenmore 22422 Top Load Washer
WASHING MACHINE NOT SPINNING AT END OF CYCLE AND SOMETIMES REPEATS THE CYCLE.
check the turbine blades, maybe the wer'e loosen up. Try to refit that one.ok??
Jan 29, 2008 | Washing Machines
Kenmore 12502 won't spin
The lid switch is broken......
Oct 05, 2007 | Kenmore 12502 Top Load Washer
Spins when it feels like it
Popcorn, sounds like you are having trouble with the lid switch. The plastic housing in which the screws hold the switch to the cabinet may have cracked, or came loose. If the lid switch is not making correct contact the result is no spin, no drain. The switch actuator on the lid itself may need adjustment. The lid switch is mounted to the cabinet on the back right side under the consol. The lid switch part number is 8054980. But check the actuator first. Catriver..post back.
Oct 04, 2006 | KitchenAid KAWS850L Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
Marvin
Marvin
