Magnavox TV not working in the UK
I bought a LCD TV in USA and have got it back to the UK and bought an electricity converter which works fine. However i cannot seem to tune the TV in at all. I select auto tune and it dosent find any stations.
My question is: Does a tv bought in the USA work on a different frequency that in the UK (and therefore will not work in the uk)
There are several multi system VCRs that will convert all inputs to all outputs. If I remember correctly Samsung made an inexpensive one. Dont know if you will want to go this route vs buying a new PAL tv.
Posted on Jan 09, 2008
  • 3 Answers
You should be able to use this TV, but you won't be able to use the built in TV Tuner because it is in fact an NTSC tuner which does differ from PAL tuners. You'll need to buy an external TV tuner or just rent a cable box from you cable TV company or satellite provider. Then hook it up to your TV using the composite R/G/B connection on the back. This should do the trick!
Posted on Dec 31, 2007
    Brigadier General:
  • 6,966 Answers
To my knowledge, the UK Video Standard is PAL whereas the US Video Standard is NTSC. Unfortunately, each standard is incompatible with the other. All other technical specs are also incompatible such as TV bands used, frequency allocation, TV channels used (UHF only for terrestrial TVs versus VHF low & hi, UHF). A TV Channel represents transmitted frequency for video and audio which is also different.
Not unless the LCD TV is capable of multi system which you can verify with the Owner/User's Manual, then it will not work.
Hope that this be of some help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Posted on Nov 07, 2007
  • 121 Answers
I don't know about the frequencies being different or not, but to get to youse your TV you can use the tuner in an old VCR if you have one sitting around.
Will my toshiba tv bought in uk work in usa
There are two things you need to know regarding your TV.
Power requirements and broadcasting standards.
Look on the back of the TV and find the sticker or label that mentions the INPUT VOLTAGE.
If it reads 220-240V 50Hz then it will not work in the USA.
If it reads 110-240V 50-60Hz then it MAY work in the USA. At least you know it will work if you change the plug on the mains cable.
In the UK, broadcasts use the PAL system to display images on the screen. In the USA, broadcasts use the NTSC system to display images on the screen.
You need to check the manual that came with your TV to see if it is capable of receiving an NTSC signal. This signal is used in everything in the USA from PVRs, to DVD/HDD recorders, satellite systems, public access and cable systems.
If your TV meets the power and broadcast requirements then it should work.
May 24, 2015 | Toshiba 50H82 50" Rear Projection...
Please can you advise me; will my panasonic TXP42C2B TV WORK IN THE USA
This plasma tv has the freeview tuner.
The USA TV needs ASTC tuner.
The electrical power in the USA is 110volts at 60Hz
The electrical power in UK is 240volts at 50Hz
The broadcast signal encoding in the USA is ASTC.
The broadcast signal encoding in UK is DVB-T.
Feb 15, 2011 | Televison & Video
I bought a 26inch dynex lcd from the best buy in usa. i brought it back to nigeria. only to discover our voltage is 220 and the tv is 110. right now it's comes on and after 5mins it starts shaking and...
You need a step down converter. They are cheap. You might have already damaged your TV, though. The converters here say for Asia/Europe use but probably same plug for Africa. Verify that when ordering.
Jul 27, 2010 | Televison & Video
Ok my Magnavox digitla converter box has been
Something is wrong with the box, you most likely will need a new one.
Jun 08, 2009 | RCA Analog (RCA) to Digital (VGA)...
NTSC to Pal
it will not work with PAL, and I am not aware of a PAL converter. Sorry.
May 24, 2009 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Do UK and US tvs have different model numbers? I have looked at several tvs in UK stores and when I search for them online I can hardly find any reference to them. I thought this might be because most...
USA TV's have different model numbers to UK one's, because the USA uses different power voltages and colour system to the UK, so a USA TV in working in the UK would need a power adapter. Shipping costs would be higher and incresed risks of faults from transit knocks!
Amazon, Richer Sounds, and E-Buyer have good sets try them.
Apr 10, 2009 | Televison & Video
Televison & Video Logo
146 people viewed this question
Top Televison & Video Experts
