Question about Kyocera Mita KM-3035 All-In-One Laser Printer
Printing problems the printer only prints one copy of work at time
  • 56 Answers
If is problem when printing, reinstall drivers.
Also replace toner.
Check settings under driver-RAM Disc ON,ammount of RAM DISC must be same as amount of ram disc which is under settings in copier control panel.Ram Disc must be on.
Posted on Nov 07, 2007
I have used a HL-2140 for a long time without any problem printing multiple copies.
What kind of problem are you having printing multiple copies?
Mar 07, 2011 | Brother HL 2140 Laser Printer
How to set a printer to print only 1 copy no matter what # is put
You cannot do it -- when you request '3' copies, the computer sends 3 times as much text & commands to the printer. So, the printer cannot tell when the 2nd and 3rd copy begins.
Sep 14, 2009 | HP LaserJet 1200 Printer
HP L7780 printing white streaks on all print outs and copies. Diagnostic tool says printer head problem. KY. Have cleaned print heads 3x through the auto program, aliegned the printer, calibrated feed....
My HP L7580 has been doing the same thing, and I've followed the same steps you describe above, with the same result. Have you resolved the issue? I'm about to give up on the printer AND Hewlett-Packard.
Aug 03, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
Printer prints more copies than indicated. Driver reinstalled multiple times.
I don't know if this will help but I have had similar problems. I would notice that one or two particular programs would print more than one copy and others were just fine. Try checking the preferences on the actual programs. Some programs retain their last qty request and don't change unless you change it. For instance, you request a program to give you two copies of a particular document and everything works fine. Then a day later you are in the same program and need only one copy of a document and you get two instead. This is because there is something set in the program or the preferences of your printing device that causes it to retain the last requested quantity for printing. Next time you print check the print dialog box and see how many copies it is showing will be printed. Hope this helps.
Jun 01, 2009 | Computers & Internet
Difficulty printing
First of all, delete all the copies of that printer in the folder and try again. If possible delete them all and reinstall the printer.
Apr 21, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Printer problem
try to un-install the printer and re-install it again and see if this will work with you
Feb 09, 2009 | Canon Office Equipment & Supplies
Trying to print multiple copies and only one copy prints
Hi, my name is Juanita and I will try to help you with your problem.
What kind of printer do you have? And when you say you can't print multiple copies, is it the problem with setting the number of copies in the print dialogue box, or is it the problem for printer settings?
For this problem, I contacted the Inti Prima Karya. It is a cheap printing solution for all your printing needs. It would be much cheaper to use their offset printing solution.
Nov 05, 2017 | HP DeskJet 6122 InkJet Printer
Printer and Making Copies does not work!
Will the machine run a paper path test?
This sounds like it could be a sensor indicating a paper jam, if this is the case, it won't run anything through the paper path (not even a blank page).
Nov 26, 2007 | Sharp UX-B20 Plain Paper Inkjet Fax
Dear, after changing the cartridge, printer print a test print. OKAY. Take that test print and put it on the scanner (printed area should on the side of mirror) then press "scan" button on your printer "bottom left". When the light stop fluctuating. Keep out the paper from the scanner. After this Printer will work properly
Sep 09, 2007 | HP PSC 1315 All-In-One InkJet Printer
Your ink cartridge had developed a problem with its delivery system. Install a NEW cartridge and you should be back printing again. I repair these printers and see it all the time Let me know what happened Ed
Jun 01, 2007 | Dell A940 All-In-One InkJet Printer
Kyocera Mita KM-3035 All-In-One Laser Printer Logo
82 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Henry Gertcher
Adorjani Laszlo
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
