Question about GE A730 Digital Camera
The camera doesn't start?
Even though the batteries are new, when I push the power button, the camera doesn't turn on.
  • 508 Answers
Did old batteries leak acid?if so it will short contacts that connect batteries try cleaning with rubbing alcohol and qtips and stretch springs a little bit with tweezers!!!!make sure good and dry before installing new batteries also test batteries should bo over 1.5 volts ive had bad new batteries!!!
Posted on Jun 28, 2009
4 Suggested Answers
  • 11967 Answers
SOURCE: My camera won't turn on even though the battery is
Could be a lens problem. Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Apr 20, 2010
  • 296 Answers
SOURCE: Moultrie digital 4.0 game camera wont power up!
TRY PUSHING TO AIM...IF LASER DOESN'T COME ON, SWITCH MAY HAVE SEPARATED FROM SWITCH TOGGLE
Posted on Feb 17, 2010
SOURCE: even though the battery is
No, the "Guru" is thinking of Canon problems (been there, lived it with my S3, often the ultrasonic motor's the issue). My "new" refurb W60 developed this glitch. I gently tapped the side against my left palm and it does fine now. Only have had it a few weeks, so I wait and see if it returns before pursuing exchange/return options. Good luck!
Posted on Oct 04, 2010
Kitchenaid dishwasher 577
Does it work though? If the light is staying on after you cut power then maybe a genie is living in there :)). Other than that it could be a bulb with bad or loose connection. I do know those touch pads behave weird if there was a power cut/surge. Mine did that bit it still works. I'm just waiting to see if a light blows or if some other short happens. Anthony
Jun 15, 2013 | KitchenAid Dishwashers
Camera will not turn on
Hello, You have either a bad battery connection or you have a more serious problem with the camera !! Check the contacts in the camera for obvious problems, Pray it is not the camera.
Best Regards, Russell
Jan 12, 2013 | Kodak EasyShare CX7430 Digital Camera
Lens won't close and On/Off button doesn't work
Even though the battery appears to be charging it may be shot. Some batteries if they run down too far can not be recharged. You need to try a new battery in the camera.
Jul 25, 2012 | Nikon COOLPIX S6000 Digital Camera
The camera will not turn on even though batteries are new.
Hi Kris - If the camera worked before changing the batteries, but now it doesn't; check the batteries for proper insertion. If just one battery was installed incorrectly, the camera will not power up. Also, check the charge of the batteries. If even a single dead battery was included in the mix of new batteries, the camera will not power up either.
If all these conditions check out ok, the problem may be related to defective hardware (power switch, lens, etc.). When the camera is powered on, it goes through a quick self test. If any of these self tests fail, the camera shuts off immediately. This will often require that the camera be evaluated professionally. Hopefully, you'll find the problem is battery related.
Nov 21, 2011 | Canon PowerShot S51S Digital Camera
My flipshare video has frozen-will not even turn off
Try holding the power button in for 10 seconds,this will reset the Flip usually.
If that doesn't work there is a pinhole in the bottom of the camera where the
tripod screws into,take a pushpin or something that small and push in for 5 seconds.
Then press the power button and it should reset.
It may be freezing because it needs the firmware updated,plug in your Flip camera to your computer and the Flipshare software will come up and check for new updates to the firmware.
Jul 14, 2011 | Cameras
I change the battery of my BMW F650GS 2001, because I can't start the engine, besides all the electrical parts were working good. Even though it was changed, I can't start the engine. When I push...
Check the connectors on the end of the battery cables,especially the one going to the starter motor.
If all is ok, you possibly need a new starter.
May 08, 2011 | 2001 BMW F 650 GS
Will not turn on
take the battery out for a few mins, press and hold power button, re-insert battery, worked for me????
Oct 07, 2008 | Jazz DV-179 Digital Camera
Canon 40D can not turn on
Same problem. Fully charged main battery. In my case, I hadn't used the camera in over 6 months. All I did was pull the main battery and then pulled the small CR 2016 button cell battery located inside the main battery compartment and re-inserted both batteries. The camera made a quiet click and then turned on with the main power switch and asked to reset the date and time. Works fine now. If this doesn't work just purchase a new button cell.
Sep 17, 2008 | Canon EOS 40D Digital Camera
GE A730 Digital Camera Logo
166 people viewed this question
Top GE Cameras Experts
Steven Wander
Steven Wander
jjanesic
jjanesic
Level 1 Expert
Are you a GE Camera Expert? Answer questions, earn points and help others
