We couldnt cut the engine quick enough and the jet ski sank and was submerged for over 2 hours.we have dried everything out and it still wont start.do you have a manual you could e-mail me at michael@only-solutions.org
    President:
  • 987 Answers
Jet ski smoking
what colour smoke , correct fuel ??
Jan 04, 2014 | Yamaha Wave Raider 700 760 1100 Waveraider...
How to maintain my jet ski?
If you plan to store a jet ski in a garage, you will need to make sure it is dry and cool and with limited exposure to the sun. In general, you need to do what you can to prevent rust and other grime that eventually may cause mechanical issues.
Washing your jet ski is also needed after every use. You can use your car wash products. I also suggest to read the user's manual, it may include tips about maintaining your jet ski.
You can protect the engine with a special spray and water repellant.
If you plan to store your jet ski for a while, it is preferred that you will disconnect the battery.
Jan 17, 2013 | Boating
What oil and how to you check it in a 93 kawsaki 750 jet ski, not engine oil the transmission oil
Your 750 jet ski does not have a gear box. If you are referring to what looks like a filler cap on the front of the motor, that is the generator/flywheel cover and it is a dry compartment and should remain that way.
Jun 11, 2011 | Encore Software Kawasaki Jet Ski...
I sank my 91 toyota 4runner and have a knocking in the engine.
If by "sank" you mean submerged in water while the engine was running you probably bent a conecting rod or broke a piston. Water does not compress and if the engine ingested water you have done some major internal damage. No quick fix for this, the engine has to be rebuilt.
Jan 18, 2011 | Toyota 4Runner Cars & Trucks
Tokk the jet ski out yesterday and i forgot to close the 2 drain plugs on the back of my ski and now it wont kick over and all i can hear is a tick every time i go to tick over ive drained the ski ive...
Hello...could be you have water in your engine ,,,did it almost sink? Any way remove the spark plugs ASAP and see if you have water in your cylinders by hitting the start button ..Just as if you were trying to start it but leave the spark plugs out . If water comes flying out of the spark plug holes you now need to ,,what is called pickle youe engine . Water is horrible for the inside of the engine so lets see what happens when you do the above .If there is water crank it until it is no loger coming out and then fill the spark plug holes with oil ...any kind is fine and let it sit for a few hours then crank it again ,,,no spark plugs in it ! Then e me back for the final instructions ,,ok? Gelcoatpro @yahoo.com good luck! Pat
Nov 28, 2010 | Boating
If i fliped my jey ski the wrong way how do i fix it?
If you have a water drain knob for draining the crankcase (Kawasaki 2 stroke motor) ,pull the knob and drain the water. As long as you have not turned the motor over you are OK. Get the motor started and run it long enough to dry it out. If you filled the motor with water, turned it over and now it wont run, you probably have broken the reed valves. You will have to pull the carburetor, check the reed valves, and dry out the motor as quickly as possible. Be sure to fog the lower end as quickly as possible so the crank bearings and piston needle bearings do not rust. Replace the broken reeds, put the carb back on, and you should be back in business.
Aug 12, 2010 | Electric Eyeware Radio Control Electric...
Jet Ski Will not start when cold
If the teeter/totter needles are gummy or covered with moisture corrosion it could be the reason the machine is so hard to start. When storing the jet ski's syphon all the gas out and burn it in your car or truck. Even if you stabilize it it wont be good fuel in the spring. Your plastic tank will not rust so remove the fuel. You may be able to clean them up by running a tank of Chevron Techron through them. Before riding we charge are batteries and start are jet ski's on the trailer/lift before dropping in the lake. This saves the battery. It takes more juice to start the boat in the water.
May 25, 2009 | Encore Software Kawasaki Jet Ski...
No Spark to a 1994-1995 Polaris SL Jet ski
first have you done what is necessary for that such as draining the oil (unless it's a two stroke) draining the gas and refiling it with fresh gas and a couple bottles of gas line antifreeze (it sucks up water) ... for the electrical parts ... spray them with wd40... that will force out any moisture at all and oil does not conduct electricity.
Mar 16, 2009 | Interactive Toy Concepts Polaris Sportsman...
Computers & Internet Logo
Alun Cox
David Payne
David Payne
