Question about NEC MultiSync FP1355 (White) 22 in.CRT Conventional Monitor
My monitors light is blinking all the time n no pic Nec Multisync FP1355
    Scholar:
  • 106 Answers
There is a setting you can access from the monitor menu button. make sure that the monitor is set for the cable you have running to it.
If you are using DVI use the digital setting.
Anything else, use the analogue.
Posted on Jun 28, 2009
How Do I REPAIR MONITOR NEC MULTISYNC LCD1830 CAPACITOR FUSE
the best way to tell is look for an ovel head as they are flat normally.see pic
Jun 21, 2017 | NEC Computers & Internet
The orange light continuously blinks on my NEC MultiSync FE990. I'm thinking it might possibly be the video cable which is attached to the monitor. If this sounds like the problem, how would I...
It could either be the Monitor has gone bad, the video card in your tower, or the cable connecting the two, the orange light signifies that the system is not getting the signal from the tower. Try replacing the VGA cable, if this is not an option try using the monitor on a different computer, if still no picture then the monitor is no good, if you get a picture try a second monitor with your desktop. If you get no picture then it is time for a new motherboard or graphics card. As far as replacing the cable if it is one piece with the monitor, it isn't recommended unless you a very comfortable opening the monitor up, in which case you risk causing more damage.
Aug 01, 2011 | NEC-Mitsubishi NEC Display Solutions...
NEC MultiSync LCD1765 won't power on
Look for bad caps with bulging top in the power supply first, post back what you see inside so we can guide you further, see example of failed monitors due to bad caps (after about 2 years): http://s807.photobucket.com/home/budm/allalbums
Feb 15, 2010 | NEC MultiSync LCD1765 17" Flat Panel LCD...
NEC MultiSync LCD2060NX does not power up
Not user servicable and with the low prices of new monitors - not worth the cost of the part.
Oct 29, 2009 | NEC MultiSync LCD2060NX (Bezel) 20" LCD...
Hi I just bought 7 NEC Multisync LCD1550v monitors and they all have the same problem. when plugged in all i get is a blinking power light. 1 of them showed signs of life for just a second but that was it....
You buy a new LCD Monitors, now still not working., if that new LCD Monitor is OK, then check your VGA Card, its inside the CPU maybe its broke or not connect properly inside. This are the cause of not displaying in your LCD Monitors.
If you here some beeps of your CPU then find out how many beeps and tell us here immediately.
Aug 03, 2009 | NEC-Mitsubishi MultiSync LCD2170NX (Black)...
No picture on monitor - green power light blinking
There's an internal electronic part/s of your monitor that is cold soldered / defective. I suggest to bring the unit to an authorized service center to properly diagnose & fix the problem. regards
May 28, 2009 | NEC MultiSync 75 17 in.CRT Conventional...
Touch system not working NEC multisync 1550v
You have to install the nec driver for this monitor. I have the same monitor. Im looking for the driver now. There are 2 versions of this monitor with the same model # . You will need to find the driver to the touchscreen model.
May 03, 2009 | NEC MultiSync 1550V 15" LCD Monitor
NEC Multisync 1760NX malfunction
I repaired mine by replacing C807, 22uF 50V capacitor in the power supply.
Monitor Mike
Nov 07, 2008 | NEC 1760NX-1 (White) 17 in. Flat Panel LCD...
NEC MultiSync FE2111SB 22in monitor problem
a blinking green light usually indicates no video signal. check your cables, and if you have another computer, try it on that. otherwise, carefully check your vga signal cable, and the connections on the neck board [where the crt plugs into]
Aug 11, 2008 | NEC MultiSync FE2111SB 22" CRT Monitor
Power light steady green but monitor goes dark after 4 secs of video
The video card in the computer could be going bad too or the driver for the video has corrupted. Try reloading the video drivers in the PC first.
Mar 29, 2017 | NEC MultiSync LCD1770V - Flat panel...
NEC MultiSync FP1355 (White) 22 in.CRT Conventional Monitor Logo
102 people viewed this question
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
