Question about 3M Computers & Internet
3m 800R Tape Machine
The top assembly remains up. Regardless if the machine is on or off. As long as the air supply is on - then the top assembly is as high as the tape machine allows. We replaced the push button that raises the top assembly as the box enters the tape machine however that was not the problem.
Does anyone have any ideas?
I was told that by 3m that it might be this?
http://3m.hillas.com/pc-21511-2341-3m-distributor.aspx
but after spending $56 on the piece they recommended replacing I rather get a second opinion...
  • 158 Answers
SOURCE: ejecting of tapes
this sounds like the sensor that when you put a tape in then it places it over the sensor saying tape in then takes tape in ready for play and band maybe streached if machine is over 1 year old open case and load tape in and see whats going on if the tape is getting through the guide loading to drumhead and look to see if drum is turning if it is and guides come out to drum then it ejects tape have a look to see if any object is jaming the pinch wheel if pinch wheel is clear then when tape is removed from loading bay use a cotton bud to clean the pinch wheel from dirt as this is the take up side and spindle then try tape again if same resaults clean the sensor where tape sits if same again screw lid down and take for repair but if in 1 yrs warranty take straight for repair. good luck
Posted on Aug 15, 2007
  • 274 Answers
SOURCE: tape won't load
There are different designs on how this works. One design there is a small pin inside that detects if you have the right tape installed. It has a very small spring which allows it to move back and forth it may have broken with normal use. (it happens) With a small flashlight look very carefully inside. You may or may not be able to see it. It may be located under the alum carrier and hidden. Worth a look. If you find it try to reattach the spring if in fact you see it. But I doubt you can because you need to get goo access to it. In any case, you most likely will need to take it in for repair. The tape carriers for these cameras are fragile and easily damaged. Wish I could give you and easy fix.
Posted on Sep 16, 2007
jmgldsmth
  • 2005 Answers
SOURCE: Panasonic VHS Won't eject Tape
unplug then remove the top cover press down on the cassette release and remove the tape then rewind the part of the tape still sticking out by hand push in the button on the side of the cassette to open the cassette cover
Posted on May 21, 2009
Bat1956
  • 585 Answers
SOURCE: replaced the capacitors, but still the same problem
Check your soldering, and also make sure that you didn't leave any stray solder, like a splash, where it could cause problems. Clean your work with a solvent to get a good look at your connections. Flux can hide a solder bridge.
Posted on Feb 03, 2010
  • 83 Answers
SOURCE: I Have an XPS M1530 which won't switch on.
replace the motherboard. You can find the part cheaper than dell here at
www.partpeople.com they specialize in dell replacement parts.
Just type in XPS M1530 in the search box to see if they have the product,
Also if they dont
then contact Dell Spare Parts Division
1-800-456-3355
Posted on Apr 14, 2010
Teac a 2340 developed squeezing from supply reel. Motor is lubricated so do think it is that. Squeal stops when supply tension arm is disengaged.
Squeal of tape can be due to sticky tape such as Ampex 406, 456,or 3M 807 and 226 or any tape with the H binder formula. I do not think the machine is at fault because of the squeal it is the tape. I am a past Teac Lead Service Technician so I have 40 years experience at this time. If the machine squeals with no tape on it then you may need brake pads
Oct 26, 2013 | Audio Players & Recorders
Tip
How to clean a VCR tape machine.
You just rented a tape and your VCR will not track properly or you tried to record a tape and it would not play back. You have a dirty machine.
Remove the power. Remove the top cabinet by removing all the screws on the back and probably a few on the bottom. Once the top is off look to see where the video tape comes into the machine. Directly ahead of the input is the video drum assembly. It should be about 2 or 3 inches in diameter and be directly in front of the tape slot. It is very fragile and should never have any cleaning device moved up and down on it.
Once you locate the video drum you should saturate a cotton swab with a 100% alcohol solution and while turning the drum slowly with the swab pressed against the video drum you should be able to clean the heads.
The heads are very small and very fragile. Any vertical movement will break them. After cleaning the video heads move to the erase head, CTL head and audio head.
The erase head is located to the left of the tape path entry to the video drum assembly. The CTL head is located with the audio head on the right side of the tape exit from the video drum assembly. Using a swab saturated with alcohol clean all these heads.
You should also clean the tape path and load mechanism ( the tracks that the tape guides slide on). Clean the pinch roller and capstan.
All cleaning supplies such as 100 percent alcohol and lint free cleaning swabs are available at http://www.mcminc.com .
This should complete the cleaning of your VCR. If all went well the unit should now work.
Thanks for using FixYa and for the great rating.
hardrocko
on Sep 12, 2010 | Televison & Video
What means F1
Keypad/User Interface Failure
A fault code of "F" then "1" flashes when there is a primary control failure.
You will need to replace the machine/motor control assembly.
Page 14 and 16, in the manual link below will help you with this.
HE Top Load Washers
Models:
F1 Error Code
WTW6200S WTW6300S WTW6400S WTW6600S WTW6700T
MTW6300T MTW6400T MTW6500T MTW6600T MTW6700T
Serial Numbers: CT01 - CU52
There are four areas of concern that can cause the F1 Error Code. Each area must be sequentially addressed to ensure
that the diagnosis is correct and the proper repair is completed.
A) Air leaks in the air pressure (switch/sensor) hose.
a. Inspect the hose for cracks, pin-holes or loose connection.
b. Replace the hose and harness assembly (W10058730) if it is compromised.
B) Moisture in the air pressure (switch/sensor) hose.
a. Inspect the hose for evidence of water.
b. Replace the hose and harness assembly (W10058730) if water is detected.
C) Lint or flashing in the air dome hose connection port.
a. Inspect the air dome hose connection port for lint or flashing.
b. Use a small round device (small screwdriver) to ensure that there is nothing blocking the air dome outlet on
the tub.
D) The control needs to be replaced.
a. Replace the control only after you have completed steps A - C above, and verified that there are no issues
with the air pressure system.
F then 2 flashes when in:
Diagnostics Test mode if a stuck key is detected.
Standby mode if there is a user interface mismatch.
DISPLAY (Saved Code) EXPLANATION AND RECOMMENDED PROCEDURE
Console and Indicators
This test is performed when any of the following situations occurs during the Console and Indicators Diagnostic Test:
None of the indicators light up No beep sound is heard Some buttons do not light indicators None of the indicators light up:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P11 connector is inserted all the way into the machine/motor control.
2. Visually check that the user interface assembly is properly inserted in the console assembly
3. If both visual checks pass, replace the user interface assembly.
4. Plug in washer or reconnect power.
5. Activate the Console and Indicators Diagnostic Test mode to verify repair.
6. If indicators still do not light, the machine/ motor control has failed: Unplug washer or disconnect power. Replace the machine/motor control assembly.
Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
No beep sound is heard:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P5 connector is inserted all the way into the machine/motor control. If visual check passes, replace the user interface assembly.
2. Plug in washer or reconnect power.
3. Activate the Console and Indicators Diagnostic Test mode to verify repair.
4. If replacing the user interface assembly failed: Unplug washer or disconnect power. Replace the machine/motor control assembly. Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
Some buttons do not light indicators:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the console electronics and housing assembly is properly inserted
into the front console. If visual check passes, replace the user interface assembly.
To Access/replace the CCU:
#1
Unplug the Whirlpool Cabrio power cord from the wall outlet. Turn off the water supply to the washing machine. Pull the washer away from the wall so that you can access the screws behind the control console. Remove the hex head screws securing the control console to the washer with a nut driver. The screws are on the lower rear edge of the control console.
#2
Lift the control console up, and rotate the console forward so that the face of the console is resting on the top of the washer. Locate the interface board cable connector to the right of the plastic tube on the back of the console. Pull the end of the connector straight out of the control console. The primary machine control is the box that the plastic tube connects.
#3
Place small pieces of masking tape around the nine wires connecting to the primary machine console. Label the wire locations onto the masking tape with a pencil. Grasp each wire at the connector with your fingers, and pull the wires away from the primary control. Pull the plastic tube out of the primary control.
#4
Locate the nut toward the bottom of the primary control. Remove the nut with a nut driver. Lift the front of the primary control slightly, and slide it down to disengage the retaining clips. Pull the primary control out of the control console. Insert the new primary control into the control console. Slide the primary control up to engage the lower clips. Secure the primary control to the console with the single hex head screw.
#5
Push each of the wire connectors into their respective positions on the primary control until they lock into place. Push the plastic tube hose over the port on the right side of the primary control. Remove the small pieces of masking tape from the wires.
#6
Position the control console back upright on the top of the washer. Secure the control console to the washer with the three hex head retaining screws. Slide the washer back against the wall. Turn on the water supply and plug the washer into the wall outlet.
TECH SHEET LINK: http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208567037.pdf
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!@#$
Sep 29, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer reads f1 when filling
HE Top Load Washers
Models:
F1 Error Code
the tub.
#1
#2
#3
#4
#5
#6
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!
Sep 26, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
My whirlpool cabrio top loader waher keeps giving me the f1 signal. i have unpluged it, hit cancel restart and still same thing. once i finally get it to go, it washes fine. can you please help me/ thanks,...
HE Top Load Washers
Models:
F1 Error Code
the tub.
#1
#2
#3
#4
#5
#6
Sep 18, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio top loader not starting properly
HE Top Load Washers
Models:
F1 Error Code
the tub.
#1
#2
#3
#4
#5
#6
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.&%^
Feb 18, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio WTW6600SBT Top Load Washer always stops while washing and displays F1? What is the solution?
HE Top Load Washers
Models:
F1 Error Code
the tub.
#1
#2
#3
#4
#5
#6
Feb 14, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
During the fill cycle and all other fill cycles,I get an F1 error message. I pause the machine for a few seconds and continue.I do this several times and it finaly catches.
HE Top Load Washers
Models:
F1 Error Code
the tub.
#1
#2
#3
#4
#5
#6
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.&$%#
Jan 08, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
3M TR1 cartridges - what reads them?
That's obsolete 20th century technology. I just discarded a Zip drive.
Sep 21, 2017 | 3M Imation Travan Storage Media
Computers & Internet Logo
59 people viewed this question
Top 3M Computers & Internet Experts
Raj Patel
Tom Chichester
james laughton
james laughton
Are you a 3M Computer and Internet Expert? Answer questions, earn points and help others
