Question about Singer Featherweight II 117
Wont stitch i just got a toyota 6600 serger at a garage sale. i have threaded it with all 4 threads. i checked it twice with the book and am sure i have it threaded correctly. it says before you sew to run like a chain of stitches to check for length etc. it will not make the chain of stitches. please help
  • 136 Answers
If threaded correctly and it will not serge, you have probably just found out why it was in the garage sale. Take it to a qualified repair shop, mmost give free estimates, probably much more than you paid for it.
Posted on Jul 04, 2009
I have a YAMATA fy14u4ad, but I don't have the book to tell me the thread setting so what should the thread setting be for all 4 threads
Assuming this is a 4-thread serger. The thread tension setting will depend on which stitch you are making. A standard 4-thread overlock stitch would generally have the tensions set in the middle. FWIW, the tension in this setting is correct when the threads meet in the middle of the fabric. It should neither be off the edge of the fabric or so tight as to create a puckered edge.
Aug 10, 2017 | Yamata Sewing Machines
How do I adjust the tension on a Toyota Model 6600 serger?
Perhaps the manual will be helpful:
Toyota 6600 Instruction Manual
http://www.aisin.at/assets/manuals/SL1SL1TSL1T-XSL1A.pdf
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=5&ved=0ahUKEwiD8qWcttPQAhWCw1QKHax5CagQFgg3MAQ&url=https%3A%2F%2Fconreicrismor.files.wordpress.com%2F2015%2F11%2Ftoyota-overlock-model-6600-manual.pdf&usg=AFQjCNFtz0ger6dBipYmZbiLjYrsDWhSAw&cad=rja
Be sure to raise the presser foot during the threading process. Also, make sure to give each thread an extra little tug when threading the tension disk.
Dec 01, 2016 | Toyota Sewing Machines
Brother 1034d serger skipping stitches. Stitches are loose even when adjusting the tension.
It appears that there are two issues: skipping stitches, and, loose stitches. Let's deal with them individually but first some general points to check.
1. Change both needles for completely fresh ones out of the package. Make sure that they are inserted all the way up, this is very important. The right needle should appear longer than the left one. Make sure also that you are using the correct needles for your serger.
2. Use a good quality thread with very little stretch, almost no fuzzies, and in pastel colour. Dark thread ages quicker, therefore has a shorter shelf live. A good quality sewing machine thread is also acceptable.
3. Make sure that the tension dials are clean and free of lint or other debris.
4. Re-thread the serger in this order, keeping the presser foot in the down position at all times
a) Upper looper. Ensure that the thread is securely embedded inside the tension discs. Place the thread tail under the presser foot to 11:00 o'clock and place the presser foot down again
b) Lower looper. This is the difficult one to thread but make sure that all the thread guides are properly threaded as well as the upper looper elbow. Check that the thread is lodged between the tension discs. Once the lower looper eye is threaded, place the thread in front and over the upper looper and then under the presser foot to 11:00 o'clock and place the presser foot down again.
c) Right Needle. Thread the right needle path, again ensuring that the thread is between the tension discs. Place the thread tail under the presser foot to 11:00 o'clock and lower the presser foot.
d) Left Needle. Proceed as with left needle.
e) Double check that all tension dials have their respective threads embedded between the discs by pulling firmly up on each thread above the tension dials.
f) Check that the stitch length is set to between 2.5 and 3.0, differential to normal, blade position to middle, blade is engaged, and upper looper converter not in use.
g) Set tensions to recommended setting for 4-thread overlock.
g) Make a test stitch out. How is it? Still having the same issue/s?
If yes, continue with the items listed below, otherwise have a great time serging.
Skipping Stitches:
1. Check that the looper tips are smooth. Burrs will cause problems.
2. Check that the needles match the type of fabric being sewn.
Loose Stitches:
1. Double check threading.
2. Debris caught between tension discs will also manifest itself in loose stitches. Take an 8" X 6" piece of medium weight clean and lint free cotton fabric, fold it in half length-wise and pass the fold only firmly between the tension discs from top to bottom (with the presser foot up and no thread in the tension dials).
Re-thread and test stitch. How is it now?
Sep 30, 2014 | Sewing Machines
Serger is not stitching
... not quite sure what you mean by "not stitching", here are a few things to check. If the problem is more specific, please leave me a note with more details.
Let's start right from the beginning (for 4-thread overlock/serge):
1. According to the serger manual, ensure that the proper needles are being used. That they are inserted all the way up into their positions and that the flat side of the needle is facing away from you. The left needle will appear to be shorter that the right, that is OK, all is going perfectly.
2. Use four good quality spool of serger thread (good quality sewing thread is fine also) and place them on the spool or cone holders. There should be "little bucket looking things" that fit onto the cone pins to make the cones sit nice and straight, use them. Rattling thread will cause grief.
3. The first thread to be loaded onto the serger is the Upper Looper ...it is the big needle looking thing that swings left to right and back again above the sewing surface. Follow all the threading guided according to your manual, the threading guides are generally coded in a colour specific for this looper. Once the eye of the Upper Looper is threaded, place the thread under the presser foot and to the left. Presser foot down.
4. Next is the Lower Looper, the big needle looking thing that swings left to right and back again under the sewing surface. It can be a bit tricky in some sergers as the thread need to pass to the left and then back to the right under the sewing surface. Your manual should have a good diagram if you can not follow the threading guides on the serger itself. Again the threading guides are generally colour coded with a different colour but specific for the Lower Looper. Once the looper is threaded, it is important that the thread is placed directly OVER the Upper Looper as it comes out of the eye of the Lower Looper. Place the thread now under the presser foot and to the left. Presser foot down.
5. Thread the right needle front to back and place the thread under the presser foot and to the left. Presser foot down.
6 Thread the left needle front to back and place the thread under the presser foot and to the left. Presser foot down.
7. Hold the four thread ends firmly in the left hand and give each thread individually a good pull down over the serger and behind, this will ensure that the threads are all engaged in the tension dials.
8. Set the tensions to the middle number, although this may vary with the brand and model of your serger. If you have the manual check for the correct settings specific to your unit.
9. Set differential to 'normal', or '0' (if your unit has one)
10. Set stitch length to about 2 1/2 to 3.
11. Make sure that the blade is in cutting position. We can trouble shoot blade position later if needed.
12. Make sure that you have the overlocking plate installed ... not the rolled hem plate (if your serger has two plates). Some sergers use the same plate for both functions.
13. Using two layers of medium weight fabric do a test stitch, what is the result? Is a chain forming? Are there stitches on the fabric? Are they looking the way they should?
Hopefully this has helped you, please let me know.
Cheers.
Sep 01, 2014 | Sewing Machines
Have an Toyota 6600 model Serger. The knives won't cut, won't stitch and tread keeps breaking from the right hand needle...
you might want to replace the knives
you might have the serger checked for a timing problem
Serger thread breaks
1. Is the serger threaded correctly?
2. Is the needles inserted correctly?
3. Is one of the needles bent or damaged?
4. Is the tension adjusted too tightly?
5. Is the tension adjusted to accommodate thickness of thread being used?
6. Are you using inferior quality thread?
7. Is the thread feeding of the cone/spool freely?
8. Is the needle size correct for the type of fabric being used?
9. Are the needles being used the correct one for the serger?
10. If all of the above suggestions don't help then the serger needs to be checked for a timing problem at a sewing machine repair shop.
Nov 05, 2013 | Sewing Machines
Do you have a manual, project book or anytrhing that gives information on how to use the features of the 936 surger?
I would suggest that you contact Husqvarna Viking to purchase a manual for your 936 serger, their contact details are here.
http://www.husqvarnaviking.com/us/406.htm
You could also get lots of general sewing info from Debbie Cosgrove at http://sewing.about.com/od/sergersoverlock/ss/serger.htm sewing.about.com is a fantastic source of information on sewing techniques, sewing machines, sergers and projects too.
Sergers are quite differernt to a sewing machine and there are plenty purchased, used once or twice, then put away or sold because they are a bit difficult. But like any new skill learnt, taking a class and learning hands on is so much better than trying to figure out from a manual so if you can find a local Husky dealership, I'd enquire about an "intro to serger" type class, well worth the money and time.
Yours will probably do a three thread overlock, 4 thread overlock and rolled hem stitch, these three seams will cover a variety of sewing tasks and applications. You can seam knits and lycra with the 4 thread, and neaten the raw edges of just about all fabrics with a three thread. The rolled hem allows you to do a small covered edge which covers the fabric cut edge wrapping the thread around it closely. Beautiful on very light weight fabric edges like ruffles and frills where you have yards of fabric to neaten, much quicker than turning edge twice and straight stitching it.
There are other techniques with a serger such as sewing stretched elastic onto fabric, sewing over nylon fishing line to give a fluted edge or stitching over a string of beads. These are best done with a special foot for this purpose, elasticator or beading foot. You can also use decorative threads through the loopers to give an attractive finish.
There are several good sewing with a serger books on the market, Singer does one but there are other great ones too. You could always borrow one from the library before committing to buying it.
Jul 07, 2011 | Sewing Machines
I just changed my Kenmore serger's needle and it stopped making the overlock stitch. I rethreaded the machine twice and make sure the position of the needles is correct but it didn't help
Hi
If you have the operators manual for this serger, you should be able to follow the threading from the start successfully. Some machines have a better threading diagram on the machine itself.
The needles should have the groove facing the operator's position. They should also be fully inserted in their mounts. Most sergers do not release the thread tensions when the presser foot is raised, therefore, you must zero the tensions to make sure the threads are fully entered into the tensioners when threading anew. After threading, you must readjust your thread tensions to the desired tensions for the set-up you plan to use. Thread tensions should be recorded for each stitch set-up because each serger tends to be a bit different, and therefore, allows you to quickly adjust for the desired stitch needed. The different stitches are adjust and fine tuned by each individual thread tension.
Hope this helps
Ray
Dec 22, 2010 | Kenmore Sewing Machines
Problems threading my janome serger
One critical hint:
You must thread the loopers BEFORE the needles, otherwise it won't stitch. Begin with upper looper, lower looper, right needle then left needle.
Jan 16, 2010 | Sewing Machines
White speedylock 7340 loose/missing stitches, up.looper unthreads
All tensions should be on 4. Also, make sure the threading is done correctly. Or if you wish; You can contact me on other sergers for sale. "Best prices guaranteed"! rick_coccia@yahoo.com
May 21, 2009 | White Sewing Speedylock 1600 Mechanical...
2nd needle/4th thread - threading confusion
With some sergers, but not many (singer 14u64 comes to mind), the top of the stitch will be an overedge that mates with the right needle thread, and the left needle thread will appear as a separate straight stitch. When you look at the underside of the stitch, the overedge will go all the way over to the left needle (the full width of the stitch). This is normal if you have this type of machine. Another stitch some sergers do (2/4 thread sergers) is a 2 thread chain thal looks like a lone straight stitch on both sides, and a 2 thread separate overedge.
As far as the threading of the takeup, it totally depends on your model. Always post your model number when you have questions as sergers vary greatly in design.
Mar 11, 2007 | Juki MO-644D Mechanical Sewing Machine
Singer Featherweight II 117 Logo
261 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
