Question about Sony KP-41T65 41" Rear Projection Television
Sony Rear Projection KP-41S4U
The TV is approx 10 years old and there are distroted horizontal lines running through it that blur picture quality is it worth repairing?
Re: Sony Rear Projection KP-41S4U - Sony KP-41T65 41" Rear Projection Television Projection Televisions
Change the rgb ic thats the stk ic
Posted on Nov 07, 2007
0 characters
3 Points
Sir Myself Raj, My Sony Tv Projection Model is kp
Sir Myself Raj, My Sony Tv Projection Model is kp -es53me1. We are using this tv since 8 years. Now recently we are facing a problem with it. The problem is, The Picture quality is not good. Total screen & pictures are appearing as blur. Would you please give the solution for this?
Oct 10, 2013 | Projection Televisions
Poor picture quality, the picture is blurred and
You have problem with convergence. Have you tried adjusting in the users menu. This is a common problem in this type of TV, usually two convergence amp need to be replaced and sometimes sets of resistors are also to be changed.
Mar 02, 2010 | Sony KP-43T70 43" Rear Projection...
I have a sony 50 in rear projection. 9 years old
Sounds like the CRT tubes are going out which is fairly common on Sony. Inside the back of the TV there are 6 knobs - 2 for each is for focus - dont touch - the other for brightness...turn down the brightness just a hair untill the lines go away.
Dec 01, 2009 | Sony KP-51WS510 51" Rear Projection...
What can cause horizontal white lines in a projection television? The TV is about 10 years old, and I am told it may be the internal power source. Could that be true?
can you see a pix or is it all white with lines running diagnally about every 1.5 inches--if you do not have a pix only lines problem is the 200 volt line feeding the crts(off flyback transfofmer)
Sep 02, 2009 | Sony KP-61XBR300 61" Rear Projection...
Sony KP-43HT20 Projection TV
5 times blinks is error code for No Good White Balance and you said that picture is very green.
As you know TV is approx 7 years old so it needs RGB gain adjustments.
If you are TV tech person or know about TV repair, let me know to guide you further. Or contact local TV repair shop to fix it.
Oct 26, 2008 | Sony KP-43HT20 43" Rear Projection...
most sure your tv is getting sick, just kidding
probably convergence problem you may need to call a tv tech
Aug 06, 2008 | Sony KP-51HW40 51" Rear Projection...
Sony KP-53V85
My unit is 9 years old, almost 10 (in 2 months) and started the same a couple of months ago. The only way to fix it is to have them serviced by a tech and replace the projectors. Its just the age/use of the unit catching up with it.
Many resellers sold them with an offer to sell you an optional maintence service where they would fix/clean/replace the projectors for upto 5 years after purchase. I'm not sure if they even have the parts anymore since these tv's are no longer produced. After market repairs are likely to cost as much as or nearly as much as buying a new flat screen tv.
Oct 18, 2007 | Sony KP-53V85 53" Rear Projection...
Green lines on my Sony projection
Those are called retrace lines and they are the result of the blanking pulse not having the desired effect. This could denote a problem in the Horizontal section of the TV. In this case the green gun is not being turned off as it goes back to the left side of the screen.
Sep 20, 2007 | Sony KP-57WS500 57" Rear Projection...
Sony KP-41T65 41" Rear Projection Television Logo
124 people viewed this question
Top Sony Projection Televisions Experts
Steve Sweetleaf
Steve Sweetleaf
Jason Harris
Jason Harris
Are you a Sony Projection Television Expert? Answer questions, earn points and help others
