Question about Philips DVDR70 DVD Recorder
How is possible to receive the DVB-S channels?
How is possible to receive the all DVB-S (SAT) channels in the analog tunner of the DVDR70?
I tried with a IF to RF cable and just a couple of the channeles are received(the one that my TV recognize a troguht SMARTLINK are downloaded to DVDR70) but allways the same channels, I am oblied to change the channeles troughts receiver's (SKYMASTER DXL 9400) remote control.
Thanks in advance
Carlos Bastos
  • 1 more comment
  • carlos_basto Jun 28, 2009
    Thanks for your prompt answer.
    Does it means that connection this appliance will it be possible to change the channels torught my DVDR70 internal TV tunner using my DVR70 remote control and programming the timer selecting the specific channel name to save programs?
    Will it be recognize by my internal tuner from my TV Set and then via SMARTLINK downloaded the channels name and numbers to my DVDR70?
    Best regards,
    Carlos
  • carlos_basto Jul 07, 2009
    The Digital Converter Box Receiver Digital to Analogic you mentioned has only RF Antenna connector an not IF SAT Connector. How can it be possible that I connect the cable that come from Dish and then a cable from the Digital Converter to Antenna In from my DVR70?
    Can I change the SAT channels from my DVDR70 remote control or I have to do it with Digital Converter´s remote Control?
    Regards,
    Carlos
  • carlos_basto Jul 08, 2009
    OK, but which converter box has a IF SAT in and RF Antenna OUT interface?
    Regards,
    Carlos
  • 221 Answers
I don't know who you are being fooled by.
There's no chance that SAT chanels wil be encoded by any receiver other than DVB-S. You can build an encoder yourself, but buying the DVB-S receiver vould be easier, and cheaper. To be able to use the existing remote, you'll need some electronical knowlege to ad additional coded IC to be able to recognise the sygnals sent by your original receiver. all your situation requires quite much work, and would be cheaper to purchase SAT receiver with remote.
But if you still want to go for it drop me a line, and I'll give you some more info and materials.
Best of luck
Gee
Posted on Jul 09, 2009
    Top Expert:
  • Philips Master
  • 80,339 Answers
These signals are digital so you need to decode them to analog with a converter box that changes digital to analog, there is no other way to get the full spread of channels.
Posted on Jul 08, 2009
  • 294 Answers
Yes connection this appliance will make it possible to change the channels torught my DVDR70 internal TV tunner using my DVR70 remote control and programming the timer selecting the specific channel name to save programs
dont worry it be recognize by my internal tuner from my TV Set and then via SMARTLINK downloaded the channels name and numbers to my DVDR70.
Regards
Posted on Jul 05, 2009
  • 15,935 Answers
Yes - that is correct.
THanks for using FixYa!!
Posted on Jun 29, 2009
  • blueextc3221
    blueextc3221 Jul 08, 2009
    if you have a converter box, the channels can only change via that remote.
  • 3,230 Answers
Follow the below link -
http://www.summitsource.com/digital-converter-box-receiver-digital-to-analog-sansonic-ft300a-converter-box-d2a-high-definition-to-standard-definition-offair-digital-tv-signal-receiver-part-ft300a-ft300a-p-6774.html
you need to purchase a connector from that link, that helps u to connect that analog to digital.
Good Luck!!
Thanks
Posted on Jun 28, 2009
Have had a DMR-EX75EB for a couple of years - great bit of kit but for some reason, the digital channels have all dropped out and i cant seem to get them back. I know the aerial feed is good because we...
It is possible that the built in DVB tuner of your DVD recorder has failed, since your TV still has its DVB receiver working fine. I suppose if you have tried to reset the recorder numerous times, and it still has not found any DVB channels, then yes, the DVB tuner has died - probably not economical to replace that as a separate component, since it is hard-soldered to the motherboard, making the overall replacement cost-prohibitive.
But if you want to do so, you can submit your recorder to any authorised DVD service centre for a quote, as well as a detailed description of the problem(s) (assuming the tuner is found to be the culprit); this will help you to make an informed decision as to whether to go ahead with the repair or not. Up to you.
Presuming your unit works otherwise, you should not need a new one (but an external set top box connected via the recorder's inputs may be required if you need to record channels) - but get a couple of quotes from service centres FIRST before doing anything else ((you can always say no to the quotes if they are too high).
Jun 08, 2011 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
I have moved to Greece and brought my tv with me. It works perfect as a tv but cannot use the freeview box. Is there something that has to be done to the tv to allow it to be used in Greece or is that...
if greece has dvb transmissions broadcasting then it might be able to be used. But if they dont, then i am afraid its useless, you dont say what country you have moved from, but wherever it is you wont receive the channels you got back home on it anyway. Only channels you will receive are greek channels. Try entering the menu on the tv and tell it to autoscan for analogue and digital channels and see if it picks up anything. If you want the channels you had back home , your only option would be to purchase a sat reciever and use that
Apr 22, 2011 | Televison & Video
Denon avr-1804/884, speakers Bose vcs center, Bose acoustimass 5 series 3 speaker system, Bose 201 series 4. All speakers play in test mode, with tuner, dvd, phono, cassette. The left side speakers will...
You don't say how "TV audio" is entering the system.
My guess is you're using analog audio Out from the TV into an analog input on the Denon. One channel failing would probably be the Left Channel cable failing or not seated.
I always recommend bypassing the TV audio entirely if the programming comes from somewhere other than its own antenna, as TV audio electronics add nothing good to the process.
If you're using cable box, sat box, game, whatever, ITS audio is best sent directly to your Denon's specialized audio hardware - digitally, if possible, to preserve multichannel possibilities.
You could also run standard analog audio from the cable box to the TV analog Audio IN if you just want to watch news and weather on TV speakers without the Denon involved.
Jan 11, 2011 | Denon AVR-1804 Receiver
Can I install a TV Tuner Card into my MD7818U
It has nothing to do with hard drive space. What kind of expansion slots are available on the computer?
The newer TV tuner cards are most likely AGP or PCI-E. Unless you have a vacant slot for one of these cards, the answer is "no."
Mar 03, 2010 | Computers & Internet
Hi ive been offered a techwood twp4210 plasma tv and i have a couple of questions can you advise if this is hd ready also how old are they, have also been advised that on start up it shows green sparkles...
The unit was being manufactured in the early to mid 2000's but I believe is not out of production. It is NOT an HDV. Here are the specs for the TV.
Product details Manufacturer Techwood Built-in Sat-Tuner No Compact Flash Card No Digital Tuner without Digital Tuner DVD Player / Recorder No HDTV Norm No Loudspeakers without Loudspeakers Memory Stick No Multi Channel Receiver without Multi Channel Receiver Type No Multimedia Card No PCMCIA Interface No Common Interface Slot No DVB-C No DVB-S No Screen Format 16:9 Screen Size in cm 106 cm DVI Interface No Electronic Program Guide (EPG) No Screen Size in Inches 42 in Secure Digital Card No Energy Savings Trust Feature No HD Tuner No Smart Media Card No Type of Monitor Plasma Display, Plasma Horizontal Resolution in Pixel 852 PC Interface No Vertical Resolution in Pixel 480 Brightness in Candela/m² 650 HDMI Interface without HDMI Full HD without Full HD (1080p) DVB-T without Digital Tuner HD ready Not HD Ready LED Backlight without LED Backlight DLNA certified No Energy Saving Trust Feature No HDMI No HDTV No Internet Access NO WEB CONTENT ACCESS EAN 5017416142205, 5017416183666
Nov 19, 2009 | Televison & Video
I am unable to tune in my mother- in- laws Sony Trinitron television Model KV-M14u as she has mislaid the operating manual when she moved down from Manchester. We have the remote but not the instructions...
Most Trinitrons use the menu button on the remote to set up funtions.Chanel Line Up, or set up chanels is under one of the funtions.Be advised that here in the US the switch to DTV requires that you have a DTV Tunner to receive over the air Broadcasts,Analog tuners no longer receive chanels(you need a converter box and anntena,Cable/Sat work fine.If this is an older model you need box.Try to get into menu,setup,chanels.Good Luck.
Sep 08, 2009 | Televison & Video
Loose sound when changing channels
If your using HDMI. The HDMI technology in version 1.1 & 1.2 was riddled with problems. Check your owners manual for version.Or, try the Coaxial Digital or optical output from your sat receiver to your Yamaha receiver, go into "GUI" "Menu" not sure which on the HTR series and Lock the audio input to Coaxial or Optical on CBL/SAT. Then Test. If it still has issues, check the settings for Audio on the SAT receiver and make sure they are correct. If you still have a problem, use a standard RCA from the sat receiver to the Yamaha. At this point audio should be rock solid on analog. Look on the back of your DSS receiver for the model # & write it down. Then go into the units menu "SAT" and check it's firmware version for version and date. It may need an update. Go to your Sat's website, Directv or Dishnetwork and go to support, enter model # and look for any updates that may apply. Hope this helps
Jun 11, 2009 | Yamaha HTR-6140 Receiver
No channels after scanning analog cable on Hauppauge 1600
I have exactly the same problem with the very same equipment but I may have found a solution. Try scanning for DVB-T channels and you may find some success. I also recommend printing up the WinTV user manual and reading it. I'm not big on reading manuals but this one actually has a lot of useful info. I will try to fix my setup and let you know if it works. Today it is recording all 6 Star War episodes till 2 am plugged in through the set top box (can't interupt)
Feb 05, 2009 | Hauppauge WinTV HVR-1600 - ATSC HDTV...
Want to use my old dish set top as dtv tuner
The antenna ports on these receivers are only analog pass thru's they will not convert to digital.
Nov 16, 2008 | DISH Network 301 DTV Receiver
Get closed captions on some channels, but not all, even though it is CC
RCA have choices for different methods of CC in user CC menu. Labelled T1, T2, etc. . Different selections are for different types of close caption. Tune to a signal (on your other TV) that has closed caption working.
Tune your RCA to the same signal. Change the T1,T2, etc settings until the closed caption for your signal appears.
If this doesn't work, try connecting analog video or VHF channel 3 (or other specified channel) to the TV. check CC. When TV stations, sat channels, sat receivers, cable boxes etc, convert analog video signals to HD, problems can result. Some equipment causes RCA TVs to do unexpected things with sound and closed caption.
If you use RF or video output, old analog video may look better on CH3 or video than on HD input and the CC will work more consistently. Watch HD signals on HD input, Analog signals on Video in or through the TV tuner . Many HD channels and programs are converted analog video and look poor on TV HD inputs.
easyab
Nov 03, 2008 | JVC AV-48WP30 48" Rear Projection...
Philips DVDR70 DVD Recorder Logo
117 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
