Question about Durabrand DU1901 TV
Mine stereo will not turn on when i plug it in.
The clock still comes up with i plug it in, but when i push the power button i get nothing. and i can't change the time. it stopped working about a year ago, when i went to turn it on, it shocked me and there was a pop sound from the stereo. i know its probably a blown fuse, but i don't know how to fix it, or if i'm supposed to get a new one or what?
  • 1,056 Answers
A blown fuse is a result of a failed component it electronic circuits. Replacing the fuse wont do no good. I fix television, and I wish I could show you how, but it has too many terminology, and rquires at least basic electronic understanding. Electronic device are the only thing a really good handy man can't fix. They are extremely complicated.
Posted on Jun 28, 2009
I have a RCA DVD Home theater system and I plug it in and the blue standby light comes on, but when I push it or other buttons on the unit, it just powers off and then won't turn turn back on at all....
I am having the same problem...i plug it in the standby light xomes on but i press the power button and nothing happens...mine is a rca rtd315wr model
Sep 03, 2011 | RCA RT2360 System
Bought a car with the pioneer deh-p4300 in it and don't know how to set the clock,did not receive the paper work
I've had two Pioneer CD players and they both were set the same way. Turn it off then press and hold the AUDIO button if it has one. Then keep pressing it until it gets to the clock. I think on mine the hour starts flashing. When your done just turn it back on. == Answer == I had this problem too. In the far right corner is the "A" (Audio) button. Turn the stereo off and hold the "A" button until the clock comes on. The hour will be blinking. Use the up and down "Select" keys to set that. Then use the right "Select" key to switch to the minutes. Use the up and down keys to set the minutes. Push the "A" button when you're done.
May 17, 2011 | Car Audio & Video
The tv will not come on...when you hit the power button a red light flashes . but nothing comes on
Lets focus on the external portion of the TV set first (95 percent of all TV problems are related to things EXTERNAL To the tv itself) Check the physical CONNECTION of all cables by removing each wire bare or RCA and reinstalling it (Each power cable as well), once you have removed one cable, check it for fraying, and if it is already bare, splice a new fresh connection for it. 5. Check to make sure there are NO OTHER uneeded radios, system nearby. these systems, when powered on, will cause electromagnetic interference and prevent more than just severe tv interference SURGE PROTECTOR Surge protectors account for more than 75 percent of electric faults to stereo equipment. Lets start with your AC Wall outlet. It is standard in america that 220 Volts from out of these outlets. This implies that each device will be using 220 Volts (From within that grid zone). If anything including an alarm clock is plugged into any AC outlet socket in the vicinity of the stereo equipment/TV, it will cause electric outage, and prevent electronics from even turning on! Your TV needs dedicated electric power. If your TV is located in the living room then unplug everything else in the living room. Lets plug the TV set into a Dedicated socket. Check all light switches to ensure that power is on for that outlet. Check the TV cable for Fraying both on the ac wall end and where it plugs into the TV. Check all GFCI outlets to ensure that all red reset buttons are pushed in, check the circuit breakers for proper connection and they are turned on. Now, lets try the TV set without it connected to any cable services, vcr, dvd, stereo system, etc.
Jan 15, 2011 | Emerson EWC27T3 27 in. TV/VCR/DVD Combo
Do not have manual. Need to program tuner channels and clock.
For clock turn key on and stereo off. Press and hold the function button for 3-5 seconds. the clock should appear with the hours flashing. Use the up-down buttons to set hours. Push the right button to set the minutes. Now turn on the stereo with the source (or power) button and your done!
Remember key on stereo off. hold function, the rest will become second nature once you've done it a few times.
Tuner pre-sets are super easy. Tune to the station you want and then just hold the # button (1-6) that you want that station on for about 3 seconds. The channel your on, (e.i 104.9) will flash a couple of times and then stop flashing. When it stops flashing it's in the memory. Tune your next channel and hold # 2,3,4,5,6, If 6 isn't enough push BAND and your on FM-2 with 6 more pre-sets, Push it again for FM-3 with 6 more presets. Push it a 3rd time for the AM band with 6 pre-sets and one more time to get back to FM-1.
Apr 07, 2010 | Pioneer DEH-P3100 CD Player
Mine lookss like the above...just want to set the
some units have a display button, if you have one of these press it until the clock appears, if not you will have a menu button which you will have to push and then press the up or down buttons.
Feb 07, 2010 | JVC AM FM CD DET FACE CAR STEREO
HOW DO I SET THE CLOCK
I've had two Pioneer CD players and they both were set the same way. Turn it off then press and hold the AUDIO button if it has one. Then keep pressing it until it gets to the clock. I think on mine the hour starts flashing. When your done just turn it back on. == Answer == I had this problem too. In the far right corner is the "A" (Audio) button. Turn the stereo off and hold the "A" button until the clock comes on. The hour will be blinking. Use the up and down "Select" keys to set that. Then use the right "Select" key to switch to the minutes. Use the up and down keys to set the minutes. Push the "A" button when you're done. My stereo is older than yours but this is what someone who has one like yours told me to try and it worked
Jul 15, 2009 | JVC KD-SX650 CD Player
Toshiba Satellite A15-S129 PC Notebook will not turn on
I have the same problem. What I have found with mine is that if I can get the battery to take just a little charge then I can get it up and running. Here is how I do it. Disconnect AC power leave the battery in and start the laptop. As soon as thing start to run I plug the AC back in and it works fine from there on. Now mine is flashing as well now and I have a dead battery and it will not restart. Something I have noticed thought is it appears that the yellow light is blinking a code. This is what I have come up with. I appears to be flashing 323 as the code or could be 2 shorts 1 long then 2 shorts and then 3 shorts.
Anyone know where to find info on these flashing codes.
Thanks
Oct 30, 2007 | Toshiba Satellite A15-S129 Notebook
I can't set the clock!
Okay, I had the same problem as well. After reading some solutions that didn't work I figured it out. On the right side of the radio there is a "F" function button on top and "A" audio button on bottom. First turn the radio off. Push the clock button until it is displayed. Then push and hold the "F" function button until the radio comes back on, then release the "F" button for a second and push it again then relase. Now, at this time the radio should only display the clock with the hour blinking. Use the up and down select key to change the time. Then push the right or left select button to change to the minute which will start blinking, then again push the up and down select button to adjust the minutes. When the time is correct just push the clock button and it is set.
Jul 23, 2007 | Pioneer DEH-P4100
Televison & Video Logo
37 people viewed this question
Top Durabrand Televison & Video Experts
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
