Question about Coleman Powermate Powermate 5000W Generator
Where is carburator on Coleman portable generator «powermate 3750
«i don«,t know where the carb is so «i cannot clean it.<
doesn't start and we will be flooded if «I cannot start the generator for use on the sump pump. help !!
  • 98 Answers
Send me a picture of the engine from the (pulling handle side)...and i will help you...
P.S. you will receive my reply immediately...
sal_kh_sab@yahoo.com
Posted on Oct 15, 2009
  • 332 Answers
If it has been submerged in water you wil not be able to start it, once water gets in it will corode the piston and rings and will never work good again,, but the carb is behind the little filter on the side next to the fuel line,, take off the filter and it will just be a little hole with a butter fly flap for the choke and a needle inside of it the needle is where the gas comes in and that adjust the fuel air mix,, csn you run an extension cord to the pump?
Posted on Jun 30, 2009
My Coleman 3750 generator normally starts on the 1 st or 2 nd pull. It will not keep running unless continue tom choke it?????
You have a lean fuel condition. Your carb is slightly clogged. By choking the unit you are manually changing the air/fuel ratio to richen up the mix. Your carb needs to be removed and cleaned. Hope this info helped.
Sep 07, 2013 | Coleman Cable COLEMAN POWERMATE PM0433750...
My coleman powermate 5000W generator is very hard to start. When I squirt gas in the carburator chamber it will start for a about a minute and then it dies. It acts like it is not getting any gas. I...
The carb. has a nut holding the bowl on.Remove this nut and you'll notice a hole in in it that goes from side to side.You'll also notice one through the center that connects to the other.Make sure these holes are clean.Use a small pin..etc.Chances are it will stay running when you assemble the carb again.
Oct 14, 2010 | Coleman Powermate Powermate 5000W...
Carburator flooding
Then there likely is still trash in the carb.
Or, it could also be that the tank vent is clogged, and not letting fuel vapors be expelled from the tank. As fuel heats up, vapors are created, which pressurize the tank, which can force fuel through the carb past the float / needle.
Dec 29, 2009 | Coleman Powermate Premium Plus 6250W...
My generator run roughly and will not put out any electricity
Try getting a rebuild kit for the carb. Also change the spark plug. I know you cleaned the carb, but sometimes you will need to change the gaskets and filters in the carb.
Mar 14, 2009 | Coleman Powermate Powermate 5000W...
Coleman powermate 3750 watt brand new I started it
Check the oil level & try again to start many times until it became loose because the engine became stock up for long time not use.
Mar 12, 2009 | Coleman Powermate Powermate 5000W...
Coleman powermate 2500 won't start and gas is leaking out of the
it sounds like mine I think it is the carb is clog up
I am still working on mine
Feb 04, 2009 | Coleman Powermate Proforce 2500 Generator
Coleman Powermate Powermate 5000W Generator Logo
252 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
