Question about Opti ES1000C-RM (ES1000CRM) UPS System
In ES1000C-RM can i change voltage from 220v to 110v?
My ES1000C-RM work with 220v and i need that it work with 110 v in/out.
What can i do?.
Thanks
    Novelist:
  • 169 Answers
Unlikely without transfomers most small UPS systems are for either low or high volts eg 120 or 240, not possible to change.
Thanks for using FixYa, if you need more help please post again.
Posted on Sep 06, 2009
When traveling to countries with 220 voltage, is there any danger of overheating, or should I use a voltage converter?
You simply can't use any 110V device at 220V, be it a cellphone converter or a food mixer.. Some artifacts have a switch to be used at 110/220 and those, once changed to 220V, can be used.
Jul 01, 2015 | Food Mixers
Low voltage and hi voltage is just 220 and 110 can i still make the pump have two speeds
The 220v / 110v are the two wiring options on that motor. They usually come pre- wired for 220. The wiring can be changed to where it will run on 110. Be sure to get it right. if you wire a 110v motor to 220v it will go bang and die.
A two speed motor will have two hot wires, one common, and one ground (4 wires). Single speed will have three wires. You can't make a single speed motor a two speed motor.
Mar 01, 2015 | Pentair Pool & Spa
Moving to Canada Korg M50 - 220V to110V ?
110 will not damage it, just will not work, if built in power supply should say on the rating plate next to power input the voltage it is able to take, a lot of units are rated 110-240v some will have a small switch to change over from 110 to 240. Other than that, you will need to get a step up unit to supply 240 from 110 just a small transformer unit.
Mar 06, 2013 | Korg M50 61-Key Music Workstation Keyboard...
My name Devi from Jakarta , Indonesia, I was buying sewing machine Brother CP 7500 from amazon, i just want to make sure, in indonesia voltage is 220V, how about CP 7500 ? is the voltage 110V or 220V ?...
Amazon is in USA so item would probably be 110 V and not suitable for you. You need to buy a machine locally or from Australia with same voltage as you, 220V. If you try to use a 110V machine you will fry the engine and electricals.
You should be able to buy the same model, just buy it in your voltage.
Jul 26, 2011 | Brother CP7500 Sewing Machine
A friend from US gave me hp netbook-1103135- is it 110 or 220v please advise thanks
It most likely has a 110V plug on the power supply; however, all you have to do is buy the appropriate 220v cable for the power supply for your country, and it should work fine on 220V.
External power supplies are designed to use either 110v or 220v -- all you have to do is change the cable or use an adapter and you're good to go.
Dec 20, 2010 | HP Computers & Internet
Will my Logitech X-230 speakers work in a country with 220-240 V power outlets or would i need an adapter to use them there? If i connect them directly to the 240 V outlet, will they run properly or would...
Check the back of your sub to check your voltage range. You will see something like this: 110V-120V or 110V-220V. If you see the later, you are ready to go. If you see 110-120V only, you will need a power converter to power your speakers as well as any other 110-120V equipment. But no matter what, if it is 110-120V DO NOT PLUG DIRECT TO 220V!! It will blow your speakers. (I lived in Germany for 11 years.)
Aug 12, 2009 | Logitech Z-2300 Computer Speakers
Power conversion
Ram,
Good day mate, no problem you can plug your dvd direct to your outlet since it indicates 100 - 240V it only means your player is capable of having either 110V 0r 220V.
note: also try to check 1st if you will see a voltage selector at the back of your dvd player. it's either a slide switch indicating 110 or 220V. if no sign of this selector no problem you can plug your player straight to your socket.
cheers
mark
Jan 29, 2009 | Durabrand DVD-1002 DVD Player
Using dryer in 220V country
There are two systems in use in the states
110v dryers are available that fit a standard 11v 15a socket
110/220v fit the oversize 'dryer' sockets, and they are two 110v phases 90 degreees apart
the motor runs of a single phase 110v.
there is 220v between the 'outside', the active lines of the two phases, at any time, but it is not useable to provide mechanical power as a single service, due to the complicated shape of the wave form when you add out of phase voltages together, but is ok to drive the heaters, they have no mechanical efficiency requirement
A 2 phase 110v heater it means 3kw can be supplied without a 30 amp circuit
but it becomes difficult to use a single phase 220-240v transformer to provide 2x110v 90degree 2 phase current unless you specially buy one in. .
High power applications in 220-240v are generally supplied by 415v 3 phase 60deg supplies,
Any transformer would be onsellable at the end of your posting, to your replacement, who would doubtless be in the same boat as you, with a heap of 'stuff' that needs to run.
UK Aus NZ may be sources of transformers, or dryers to suit.
check with Australian UK NZ suppliers as well as local Indian ones, as those countries are also nominal 240v single phase home suplies and they may have (1) the dryer, or (2)the transformer to suit the 110 2 phase dryer
Sep 10, 2008 | Kenmore 62602 Electric Dryer
Hcd bc150 main power
Please check Input Voltage 110 ~ 240 volts AC at rear or bottm side of unit. If same is written there, its Auto Voltage Operatable and can be use on 220Volts.
Aug 31, 2008 | Sony DAV-BC150 System
Opti ES1000C-RM (ES1000CRM) UPS System Logo
91 people viewed this question
Top Opti Computers & Internet Experts
David Payne
David Payne
Are you an Opti Computer and Internet Expert? Answer questions, earn points and help others
